News
488 OEM WHEEL WEIGHT COMPARISON
Discussion in '458 Italia/488/F8' started by Exoticar Auto, Nov 15, 2017.
  1. Exoticar Auto
    Exoticar Auto F1 Rookie
    Sponsor
    Dec 17, 2004
    2,565
    Tampa Bay FL.
    Exoticar Auto
    #1 Exoticar Auto, Nov 15, 2017
    Wanted to do a 488 OEM wheel weight comparison, so here you go. In the past we did the 458 and lso a F12 comparison (see links below if interested). This is using our cheep shipping scale but it seems to be pretty accurate. We put a 15lb barbell on the scale to check accuracy and it was 15lbs dead on.
    458 OEM wheel weight comparison, see here
    https://www.ferrarichat.com/forum/threads/ferrari-458-factory-wheel-weight-comparison.525346/
    F12 OEM wheel weight comparison
    https://www.ferrarichat.com/forum/threads/ferrari-f12-factory-wheel-weight-comparison.522950/
    Here ya go for the standard 488 wheels made by Speedline wheels of Italy
    Specs
    Front 9J X 20 ET 44.7, Rear 11J X 20 ET 38.5 mm
    Front wheels 28lbs
    Rear wheels 32lbs
    120lbs total
    Next up we have the optional forged wheels made by Super Alloys of Taiwan
    Specs are the same
    Front wheels 25lbs
    Rear wheels 27lbs
    104lbs total
    So with the forged wheels on the car compared to the standard wheels, you save 16lbs of un-sprung weight.
    *That's going to help in steering, handling, braking and acceleration.
    We have both styles in multiple colors in stock if anybody would like to go either way. When I get my hands on another set of the 488 accessory wheels, I will weigh and add them to this thread. In my experience the accessory wheels are usually heavier then the forged wheels.
    FordGTDriver and 100badboy100 like this.
  3. spyder625
    spyder625 Formula Junior
    584
    NJ
    wow,, thanks for info
  4. Baitschev
    Baitschev Formula Junior
    Jan 8, 2017
    260
    Vienna
    Hi
    Do you have the weight of the tires
    Micheline vs pirelli its also very intresting!
  5. Exoticar Auto
    Sponsor
    Dec 17, 2004
    2,565
    Tampa Bay FL.
    Exoticar Auto
    #4 Exoticar Auto, Nov 19, 2017
    Tire weights can be found on tirerack.com under the specs tab for a brand, model and size.I did a quick look.
    Michelin Super Sport in 488 sizes
    245/35/20 fronts 23lbs
    305/35/20 rears 31lbs
    108lbs total for all 4 tires
    Pirelli P Zero in 488 sizes
    245/35/20 fronts 25lbs
    112lbs total all 4 tires
    RayJohns likes this.
  6. Dicecal
    Dicecal Formula 3
    1,412
    Phoenix, AZ
    Rob
    Any idea what the 488 accessory OZ wheels weigh?
    Or what the weight of HRE P107sc in OEM sizes, any ballpark numbers?
    Gonna do something different on my F8 when it arrives...
  8. bosss351
    bosss351 Rookie
    May 8, 2013
    1
    anyone know the weight of the wheels 488 pista ?
  9. Dicecal
    Dicecal Formula 3
    1,412
    Phoenix, AZ
    Rob
    OP has not responded further to the tread, check the one on F8 wheel options. There are some numbers there, as well as the best prices I’ve found on Pista wheels:
    https://www.ferrarichat.com/forum/threads/f8-rims.614389/
  10. Exoticar Auto
    Sponsor
    Dec 17, 2004
    2,565
    Tampa Bay FL.
    Exoticar Auto
    #8 Exoticar Auto, Nov 28, 2020
    Sorry it took us a while to get a hold of the Pista wheels but have now had 5 sets. On my same scale as used above I got the following results.
    Made by Apptech of Italy
    Specs are the same
    Front wheels 20lbs
    Rear wheels 22lbs
    84lbs total (save 36lbs. un-sprung weight off the base wheels, that's huge)
  11. mdrums
    mdrums Formula Junior
    Jun 11, 2006
    910
    Tampa
    More info...here are some weight from replacing my stock forged wheels with HRE P107
    Stock
    9x20 et44.7 w/ Pirelli PZero 245/35/20 50.4lbs.....added Hill Eng 11mm spacer 51.2lbs
    11x20 et38.5 w/ Pirelli PZero 305/30/20 55.4lbs....added Hill Eng 15mm spacer 56.6lbs
    HRE P107
    9x20 et3 w/ Michelin Sport Cup2 245/35/20 46.3lbs
    11x20 et21 w/ Michelin Sport Cup2 305/30/20 53lbs
  13. Il Co-Pilota
    Il Co-Pilota F1 Rookie
    4,364
    Hopefully some place nice.
    A.B
    What is the front offset of your HRE? Do you think a wider front and rear tyre would clear with your offsets? Thinking 255 and 315.
    Would be interested to know if you have any rubbing on track.
    Get us some pics:)
  14. mdrums
    Jun 11, 2006
    910
    Tampa
    Front is 9x20 et35....sorry typing late at night on iPad. I have not crawler under the car to see the clearance but knowing the wheel is outset 10mm more I would imagine a 255 would clear.
  15. Il Co-Pilota
    4,364
    A.B
    I think you misunderstood me. I was thinking more about if the tyre would clear the outer fender lip. But I was thinking that your front offset was more like 30-32. But with a change of 9.5 mm, a 255 would fit no problem.
    mdrums likes this.
  16. mdrums
    Jun 11, 2006
    910
    Tampa
    I got ya...yes there is room on outer fender lip. I did not push the wheels outward a whole bunch just a nice slight outer offset.
    Basically from stock the HRE's are offset like having 10mm front and 15mm rear spacers.... HRE said I could go 15-17mm front and 22mm rear but to me that is too much...maybe for the street crowd looking to do 21/22 wheels and sludge the tire past the fend or right to it...but that is not me. ;-)
  17. Il Co-Pilota
    4,364
    A.B
    I know it's not. You like to properly drive your cars;)
