488 Pista Battery | Page 3 | FerrariChat
488 Pista Battery
Discussion in '458 Italia/488/F8' started by MuratC, Nov 21, 2018.
  1. Dylie
    Dylie Rookie
    Dec 20, 2017
    1
    New Pista died today after 2 hours with door ajar. Dead dead, no lights, nothing. An hour on the battery tender and it was back in business, fired up cleanly, no errors/warnings. This thread was very helpful.
    SECRET likes this.
  2. I hear you on that.
    Leaving the door ajar even for 2 minutes will throw up error codes.
  3. Twosherpaz
    Twosherpaz Formula Junior
    Feb 25, 2014
    930
    Thermal, CA
    Private
    I have two Pista. One charger is fine the other won’t start charging. I’ve tried pressing reset but the first charge light just blinks. Nothing seems to work to get the charger to see the car and start charging. I have swapped chargers between cars and same thing results so I think I have isolated it to the charger, not the cars. Anyone figure this out yet?
  4. I'm still trying to figure out how you got two Pistas.
  5. SECRET
    SECRET Formula Junior
    997
    296 GTB
    or why...
  6. Twosherpaz
    Feb 25, 2014
    930
    Thermal, CA
    Private
    I’m sure you would have a lot of questions about my garage then. Why a Pista coupe and spider? Because they are amazing cars.
    On the battery note, it seems that one is simply defective. Few dealers have extra Lithium battery tenders in stock yet, but I have a parts manager ordering one. I think this will be covered under warranty given how new the tender is.
    Or why? Man that’s a weird comment to me. Now, why five 16M’s, or three F12 TdF’s? That question makes some sense perhaps. Lol
    488Julius, Bundy, LARRYH and 2 others like this.
  7. XSQF
    XSQF Rookie
    Apr 5, 2019
    39
    Get rid of the factory charger and grab any ctek with recond function.
  8. Caeruleus11
    Caeruleus11 F1 World Champ
    11,485
    I know this is very very basic, but have you tried cleaning the terminals on the tender as well as the car? I had this problem with my cars and I went through the same process and then one day I thought- why not try the obvious- I'll try cleaning the connections- and it worked! Even though one tender worked on one car and didn't on the other... If you haven't tried it, its at least an easy thing to try... Good luck with it and yes, these are AWESOME cars!!
    LARRYH likes this.
  9. Twosherpaz
    Feb 25, 2014
    930
    Thermal, CA
    Private
    I have not found one with the reverse magnetic Ferrari adaptor yet. I bought one on EBay and then he wrote to say he was out of those adaptors.
  10. SECRET
    997
    296 GTB
    Cool story.
    Anyway, back to the topic at hand. There is a Pista CTEK adapter on eBay that I'll order after I hear back from the seller on whether this part different than the Portofino or 488 GTB adapters they sell.
  11. Twosherpaz
    Feb 25, 2014
    930
    Thermal, CA
    Private
    Omg. I did it one day but less diligently. Really wet it down and rubbed with a towel. It works. Thank you!
    Bundy and Caeruleus11 like this.
  12. Caeruleus11
    11,485
    Another silly thing:
    The magnets on the car side of the connector on my 812 are stronger than the other cars, I had been pulling on the end of the connector to remove it, well this added resistance meant that my usual method of pulling on the wire instead of the rubber/plastic connector meant I stripped the wires right out of the connector! Fortunately its very easy to fix.... adventures in charging land lol.
  13. Darrmill
    Darrmill Rookie
    Jul 2, 2018
    47
    Darrel Miller
    I don't know if it will solve your problems, but it seems like it will..... there is a company called Antigravity Batteries who are doing some killer stuff with Lithium. They have BUILT-IN WIRELESS Jump Starting! So you don't have to jump start the battery and CAN'T be stranded... the battery won't allow it, it goes to sleep mode if over-discharged. And has all the other protections.
    I have a GT3 and bought one last year... been flawless. Tested the Wireless Jump Starting when I first got it.... freaking worked like they said, but didn't ever have to use it since. Just tested it by draining it. I was surprised to see people talking about Braille and Super B and nothing about Antigravity. When I did research I found Braille and Super B didn't have protections and cost a lot more... then when they had the Wireless Jump Starting and it was about $800 dollar less than same size Braille I bought it. My Battery is a OEM fit for GT3 was H6 size...though they make a lot of size. They are big on the Porsche side of things... at Rennlist there is tons of info on Lithium batteries and them.
    I bought it here... https://antigravitybatteries.com/productline/starter-batteries/automotive/
    They have a video here about it...
    Gh21631, kussetimii and mdrums like this.
  14. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,292
    Tampa FL
    I second the Anti- Gravity battery..I do not have one but I know guys that use these in ther Porsche and are very happy no issues with these lightweight Lithium batteries.
    Question though...is there an issue with the Ferrari Battery Tender that came with my 2019 488? Do they not work correctly or well?
  15. ROBOS
    ROBOS Rookie
    Nov 24, 2012
    4
    Pista battery gone flat after 3 days. Plugged the Ferrari charger in and green light just flashing.....any suggestions please?
  16. Twosherpaz
    Feb 25, 2014
    930
    Thermal, CA
    Private
    Best advice is really clean the contacts on the car and charger. Unplugged, use wet towel and make sure they are clean.
    If that doesn’t help, try holding down the reset button on the charger until it like reboots. One time that did the trick.
    Finally, battery is behind footwell passenger seat. I have successfully jumped a couple of my Pistas on the battery using Lithium jump starters.
    Lastly, or if not in a hurry, you do have free roadside assistance with the car. Sometimes it is just a bad battery. I just haven’t had one myself. I killed it once keeping it on in auxiliary mode. Another Pista I think I just left unplugged for too long.
  17. SoCal to az
    SoCal to az F1 World Champ
    15,045
    Arizona
    I would love to see a picture of your garage. Please post some pics and let me drool. :)
    LARRYH likes this.
  18. Art138
    Art138 Formula 3
    Nov 22, 2007
    1,531
    Ft. Lauderdale
    After reading about the potential Pista Lithium battery problem,I installed a NOCO Eyelet cable adapter to plug into my starter pack. As you can see from the pic,the eyelets fit well into the positive and negative cable bolt clamps. I am using a LITHIUM compatible NOCO starter pack. Image Unavailable, Please Login
    zstyle, Bundy and MANDALAY like this.
  19. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,459
    AUSTRALIA
    ANGELO
    Every 488 , Pista owner should have a starter. Fact is the chances you need it one day is 100%. Don't um ah about it BUY one today unless you already have on. Boy oh boy I really wonder what the SF90 and LB will be like
    Bundy and Art138 like this.
  20. C50
    C50 Formula 3
    1,731
    808
    Anyone tried just disconnecting the terminals if no tender is available? Since no parasitic draw, maybe it won’t drain as quickly?
  21. TAM340R
    TAM340R Formula Junior
    Jul 26, 2015
    264
    Hi Art ,
    Sorry for my bad English ,
    I would like to ask you 2 things
    Is the eyelet cable adapter coming out permanently from behind the plate in front of the Baterry in order to be immediately accessible , at the top maybe..?
    What Noco starter pack would you recommend?
    Thanks and have a nice day
    Tamas
  22. Fixer03
    Fixer03 Karting
    Nov 1, 2015
    219
    I had the same thing, plug in as normal and keep your finger on the rest button for 20 secs or more and eventually it'll tell the battery to kick in and brings back to life.
    These battery's have a 10% safe mode to protect them from running all the way down and when 10% is reached it cuts power to the whole car, holding the reset tells the battery to reconnect and it'll start to charge again.
  23. F12london
    F12london Rookie
    Aug 3, 2013
    24
    London
    Hi Art,can you give me the Noco model that is compatible with starting a lithium battery,when I contacted Noco recently they said none of their existing products were compatible.
