488 Spider engine pulled to replace head gasket - concerns? | Page 3 | FerrariChat
Discussion in '458 Italia/488/F8' started by brettfolkman, May 5, 2025.
  1. Abowabah
    Abowabah Rookie
    31
    Jacksonville, Florida
    Karl
    Surprised your warranty covered a thing after installing a tune..
  2. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    494
    Victoria, B.C, Can.
    John Glen Wesanko
    I don't understand why a Ferrari that has been designed to easily accommodate "engine out" maintenance is so feared ? I own a 348 and can have the drive train out in 6 hrs myself. Once removed everything is easily accessible and all work carried out. Also a perfect opportunity to do all the other "while it's out" jobs like cleaning, inspecting, repairing wiring, changing coolant hoses, etc. I would expect a model requiring this level of scrutiny should be considered not a headache but the "gold standard" for quality maintenance !
  3. dgl36
    dgl36 Karting
    Feb 20, 2013
    172
    Canada
    Really, easy out for a 488 or F8.
  4. ADent
    ADent Rookie
    Mar 10, 2020
    11
    A Dent
    Portofino too.
    Timing cover leak is most likely than head gasket although can be both.
    Not covered with Power 15.
  5. ktc9
    ktc9 Rookie
    Jun 25, 2022
    28
    Uhhh please tell me this is super rare among the many thousands of 488 out there...
  6. dgl36
    dgl36 Karting
    Feb 20, 2013
    172
    Canada
    I bet if all 488 cars were to be inspected, over half will have head gasket problems.
    Eric C likes this.
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    From what I understand the cam shaft half shells are fitted in the camshaft cover, so you cannot just let off the cam covers without losing the timing. They have to fit external plates to tie the engine position before letting off the covers.
    SVR and dgl36 like this.
  8. dgl36
    dgl36 Karting
    Feb 20, 2013
    172
    Canada
    You should be happy your car has this defect repaired and under warranty. All 488s will eventually need to have the original head gaskets replaced. My dealer told me the replacement gaskets have been updated and of all the ones they replaced none have come back. Cars with the defect taken care of are worth more than cars without this being done.
  9. Eric C
    Eric C F1 World Champ
    Mar 20, 2009
    11,043
    St. Louis, MO
    Eric
    My dr said nothing wrong with a little seepage
    technom3 and SVR like this.
  10. dgl36
    dgl36 Karting
    Feb 20, 2013
    172
    Canada
    Yes, a little seepage is not of immediate concern, but the leakage and defect has shown it's ugly head. Why wait for more damage?
  11. Eric C
    Mar 20, 2009
    11,043
    St. Louis, MO
    Eric
    The extra lube is nice
    technom3 likes this.
  12. SVR
    SVR Karting
    Feb 9, 2017
    195
    Moscow, Russia
    Of course, because 488 is like Ford F150, people drive for years and never go to the workshop for maintenance, right? So no one knows that half is broken. By the way, why exactly half? Why not 90 or 100%?
    There are ten thousand of picky owners of 488 with internet in the world, and based on 1 (one!) case from the forum you say that everything is terrible.
    mdrums likes this.
  13. technom3
    technom3 F1 World Champ
    18,534
    Phoenix AZ
    Justin
    There has been multiple reports.
    How many 488 owners get on here and complain... If the 20k cars produced... How many post?
    mdrums likes this.
  14. dgl36
    dgl36 Karting
    Feb 20, 2013
    172
    Canada
    I never said, "everything is terrible". Learn to read correctly.
  15. emmholla
    emmholla Formula Junior
    Dec 15, 2018
    256
    I think the problem is people don't drive thier cars. If you drive your cars often and run them up to temp etc then u avoid most or these issue in my opinion. When these cars sit that's when you open yourself up to issues.
    mdrums likes this.
  16. dgl36
    dgl36 Karting
    Feb 20, 2013
    172
    Canada
    The head gasket problem is not because of a lack of lubrication from setting idle. The problem is only evident in the turbo charger versions of the engine. Ferrari has replaced the original gasket with an updated gasket and my dealer says they have not had 1 come back after being updated. This is a maintenance item which owners should expect to have done.
    mdrums likes this.
  17. emmholla
    Dec 15, 2018
    256
    Interesting. I'll be on the lookout for that.
