News
488 Spyder Front Lift option
Discussion in '458 Italia/488/F8' started by Shack, Oct 30, 2016.
  1. Shack
    Shack Formula 3
    Rossa Subscribed Owner
    May 2, 2005
    1,814
    Earth
    I am torn whether I actually need this option. I don't have it in my Speciale and its never been an issue.
    Any comments from 488 owners?
  2. 100badboy100
    100badboy100 Formula Junior
    Sep 15, 2016
    825
    Devon- U.K.
    Michael
    Hi Jon
    I have specked it on my car which is due for delivery next year.
    I did to and fro on it for a while, as I did with the electric mirrors and parking cameras, as all 3 options will be rarely used and they cost a few quid!!
    But in the end I came to the conclusion that none of these options can be easily retrofitted should I change my mind, and I will be cursing myself when I scrape the front bumper up on a curb or car park ramp, scrape the mirror down a narrow lane, or back into a low post that I didn't see...
    So in the end I went with all 3 " save the scrape' options, but bloody expensive for what they are......
    Hope rhat helps?
    Regards
    Michael
  3. Patrick21x
    Patrick21x Karting
    Apr 11, 2014
    202
    Orange County
    I spec'd it on my 488 Spider arriving in Feb. I am in Southern CA and our roads are pretty smooth. But Ill never forget the time I was in my Scud. I went into a shopping center and the exit had a very narrow and steep exit (Only way out). There was no avoiding it, I scraped the front corner. Thankfully I had thee skid plates installed, and it did absolutely no damage, but still I hate that scraping on pavement sound. While in my SUV, I have drove in and out of drives that would have most certainly been horror in a F Car. I remember going through these spots thinking, "Dang, I am so glad I am not in the Scud right now".
    When I saw the 488 had the new lifter option, It was an easy choice to get. I may not ever really need it. But I will sure be glad I have it, should I find myself in a similar circumstance of the past.
  4. Tonza
    Tonza Karting
    160
    Houston
    Anthony
    488 isn't any more issue than 458 wrt driveways. Not necessary for most situations. But when you need it, it is nice to have. I'd skip it if you don't have issues where you typically drive.
  5. BG23
    BG23 Formula Junior
    Jun 16, 2015
    380
    Australia
    I had the same question before ordering my coupe. I don't regret ordering it one bit, it makes otherwise stressful situations a non issue. Just yesterday I had to exit a carpark which had a much steeper exit than the entry. There is no way I would have made it without scraping without the lift.
  6. lamarmotte
    lamarmotte Karting
    Feb 5, 2014
    194
    France
    The front approach angle of the 488 is 8,5° against 9,5° for the 458 ( + 4 cm front overhang for the 488) .
    8,5° is too low for underground parking ramps
    I check this option on my 488 GTB
  7. Shack
    Shack Formula 3
    May 2, 2005
    1,814
    Earth
    Thanks All
    Seems like on balance its worth keeping this option
    Also thanks as did not realise the overhang was longer and that's definitely an issue
  8. bob_Uk
    bob_Uk Karting
    Oct 13, 2016
    98
    I chose the option. I borrowed a dealer car for the weekend before it arrived without the lift and I winced every time I went over a speed hump.
    The lift makes things a lot easier and you feel more relaxed.
    The key is to realise it beeps when it "deploys" but does not when it drops back down. Be very careful as you can miss it!
    I think it is the best value option I purchased as my non-technical mind feels there are quite a few bits added to the car to make it work.
  9. RCorsa
    RCorsa Formula 3
    Apr 5, 2014
    1,345
    West Coast
    I had it in my 458 and never used it. Didn't get it on the 488 and have never missed it. I skipped it on My spider order as well. The 458/488 front end is not that low. Unless you have some crazy driveway save your 7k or use it for other options.
  10. 997usa
    997usa Formula Junior
    Dec 10, 2014
    553
    Chapel Hill, NC
    Robert J.
    Had it on my 458 and used it once; didn't order on the 488
  11. PA Wolfpacker
    PA Wolfpacker Formula Junior
    Aug 19, 2007
    402
    Naples, FL
    Neil
    I will echo those that ordered the lift. Ordered it on my 488 Spider and had it on my 458.
    Didn't need it on the 458 until my club installed composite speed bumps, thank goodness I had the lifter or I would have been unable to drive the car to the club.
    I consider it an inexpensive insurance policy.
  12. graphicdisorder
    graphicdisorder Formula Junior
    Jan 11, 2015
    408
    Johnson City, TN
    Used it a few times on my 458, probably only REALLY needed it a couple times so it was nice to have but honestly most of the time not needed.
  13. lamarmotte
    lamarmotte Karting
    Feb 5, 2014
    194
    France
    The design of the front bumper of the 488 is different, with the front overhang +4cm the fornt approach angle is reduced
    I prefer spend 7k in an useful option than a cosmetic option
  14. bob_Uk
    bob_Uk Karting
    Oct 13, 2016
    98
    I am guessing no one lives in the UK - as soon as I approach home the lift goes on as it really does make that difference where every other puddle is probably a pothole. Every route I take has some kind of speed bumps from short cut residential roads to the Supermarket entrance road.
    The UK is the other reason I have full PPF - it's about half a mile of single track road to home with tight hedges each side and potholed passing places.
    Also in the UK the lift was £2,880 inc taxes so at just over 1% of the car price was one of the best value options. Must be serious mark up elsewhere if 7k is either dollars or Euros.
  15. Shack
    Shack Formula 3
    May 2, 2005
    1,814
    Earth
    Thats the problem as its US$10k for me hence the question. At £2,880 i would not care
  16. ferr9000
    ferr9000 Formula Junior
    Feb 13, 2013
    803
    SFF
    In my country front lift is a must due to streets and access. I ordered it for my 70 anni 488
  17. RCorsa
    RCorsa Formula 3
    Apr 5, 2014
    1,345
    West Coast
    What do I care how anyone spends their own money. There is no wrong answer. Just the OP wanted opinions from owners. Like I said I had it in one car and not the other and it made zero difference in my ownership experience or how well the car held up, cosmetics or resale. I live in a big city and put around 4000 miles a year on these cars. Just my experience, nothing more....
  18. mdslone
    mdslone Formula Junior
    Sep 8, 2016
    332
    South
    FerrariM
    I do not have the lift option in any car I own, and I rarely scrape. If I do it is not a big deal at all. However, everyone I have talked to about the 488 including the dealer said for resale it is recommend. So I went ahead and did it on the 488. Hope this helps
  19. Shack
    Shack Formula 3
    May 2, 2005
    1,814
    Earth
    Yep, same reason from my dealer. I will decide when I lock the spec as if I do keep the car longer than my normal 1-2 years I wont bother
  20. IDriveM5
    IDriveM5 F1 Rookie
    Jul 2, 2012
    2,574
    Central Ohio
    Raj
    I'm going to skip the front end lifter (and save the costs) and instead have skid plates installed.
  21. fastmover
    fastmover Formula Junior
    Mar 9, 2009
    518
    Canada
    I have the carbon fibre front spoiler and I ordered the lift on my car. I used it the first week I had the car going down a steep decline into a parking lot I have never used. If I didn't have the lift I would have had to choose between scraping my front or trying to reverse 50ft up a hill and hoping no one would show up behind me.
  22. kev360
    kev360 Formula Junior
    Feb 19, 2006
    422
    Not sure how helpful this will be but thought I would offer it up. I have a 2016 F12 and cracked my $6k carbon front splitter on a parking curb at Starbucks. I have the lift and front camera so I was being stupid and non attentive. The lift, if I am smart enough to deploy it, helps me clear the parking curbs. Saves me a ton of stress. I don't own a 488 but the F12 has a long nose and it's tough to judge where the front nose is.
  23. lamarmotte
    lamarmotte Karting
    Feb 5, 2014
    194
    France
  24. mdslone
    Sep 8, 2016
    332
    South
    FerrariM
    I have an SLS along with an F430 and neither have the lifting capabilities. Out of 5 years driving each car I have only scraped the ground twice. Once in each car. I am conflicted my self on whether to keep the lifting option on my 488 spider due to it being so pricy. In my opinion it is an option that would rarely if ever get used, but could help you somewhat on resale. ALSO your Ferrari dealer can install the factory lifter on the 488 no problem.
  25. Graz
    Graz Formula 3
    1,700
    New Jersey
    Thomas
    Absolutely 100% recommend the lift. I don't care how your roads are where you live. Sometimes you're in areas where there not so great. This should be standard (fat chance) on all these low slung cars. I had it in my 458 and it saved the underside on more than one occasion. Leave out some other options but not this one.
