488 Turbo | Page 3 | FerrariChat
488 Turbo
Discussion in '458 Italia/488/F8' started by Micheal Sanchez, May 16, 2020.
  1. xav488
    xav488 Rookie
    Feb 10, 2019
    16
    Europe
    Yes please I’m interested to have your return about this. Many thanks . The diagnose is important axis backlash/play on the LH turbo. (Turbo right side passenger is perfect as new). What I think , it’s ok some car or parts can have an problem but Ferrari must do something. It’s not normal so they can show that they support us. Keep safe !
  2. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,257
    Tampa FL
    You said “common problem”...couple issues is not common...this whole post is more like troll post.
  3. Solid State
    Solid State F1 World Champ
    10,466
    Maximus Decimus Meridius
    When a manufacturer states a part is 'consumable' and not covered under warranty than it tells me they expect it to fail long before a major component of the car. Maybe even a couple time during its life. Replacing them down the road could be more than 20% of the cars' value and that's not something to ignore in a used car.
  4. ScottS
    ScottS F1 Rookie
    2,933
    Winter Park
    Scott S
    Common or not I thank the OP for putting it out there.
    As I thank Steve @SAFE4NOW for his insight from his end. He extended my warranty on my F12 and I got more than my money out of it ....
    Both are related because knowledge of potential faults (FF PTU) and incidence factor in the value and utility of NPW and extensions.
    Prior to the post had not been aware. If I was keeping my 488 past warranty I would extend.
    Let me ask Steve - would a 488 with all service be covered for turbo failure under factory/extension warranty (or NPW) or is it a consumable?
    SAFE4NOW and mdrums like this.
  5. AlfistaPortoghese
    AlfistaPortoghese Moderator
    Mar 18, 2014
    3,778
    Europe, but not by much.
    Nuno
    I actually think Ferrari’s warranty program is great. Suffice to say you can have official Ferrari warranty on your car past the 10 year old mark, and I can’t extend my BMW’s factory warranty past 4 years no matter what.
    I look at car or health insurance like having a gun: it’s better to have it and not needing it, than needing one on the spot and not having it.
    Kind regards,
    Nuno.
    SAFE4NOW and ScottS like this.
  6. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,808
    Dallas Texas
    If you know you know
    4th and 5th year warranty is literally an extension of the original 3 year factory warranty, so if an item is covered under the 3 year initial warranty, it would be covered under the 4th and 5th as well.
    I have asked for clarification since it is not listed in the New Power Warranty book, I will reply by tomorrow.
    Happy to help,
    FWIW, you can actually have " official Ferrari warranty " for over 15 years ..... < wink >
    S
    AlfistaPortoghese likes this.
  7. AlfistaPortoghese
    Mar 18, 2014
    3,778
    Nuno
    Back when I bought the 458, I think it was 12 years. They must have extended to the 15 year old mark in the meantime, and I missed it. Thanks Steve.
    Kind regards,
    Nuno.
    SAFE4NOW likes this.
  8. vjd3
    vjd3 F1 Rookie
    2,706
    Massachusetts
    Vic
    There is a mileage limit, though, correct?
  9. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,808
    Dallas Texas
    Yes, but who ever reaches the mileage limit... LOL ( I know I know , some do! )
    FWIW regarding the addition of a compression test being required during the new power warranty inspection:
    Engine compression test is required on vehicles older than 5 years old or with more than 31,068 mi.
    Most of the newer cars, like 458 on... the initial test can be performed electronically, much simpler than mechanically.
    S
  10. scott61
    scott61 F1 Rookie
    Feb 11, 2004
    2,606
    North of Boston
    Trying to follow along here but can't find if a blown turbo is covered under original warranty?
  11. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,808
    Dallas Texas
    Turbo failure would be covered under factory warranty , as well as 4th and/or 5th year warranty extension**
    Turbo failure is not currently a covered item under new power warranty
    ** Assuming no outside influence like no oil changes as outlined in the owners manual or aftermarket driveline add-on's , etc
    Turbo malfunction would be a covered component under factory warranty.
    I've replaced one, under factory warranty, on a Pista. The failure logged seconds after cold start up under full load... covered, with only standard questions asked.
    S
  12. scott61
    scott61 F1 Rookie
    Feb 11, 2004
    2,606
    North of Boston
    I'm still a little confused by wording? First says "Turbo failure would be covered under factory warranty , as well as 4th and/or 5th year warranty extension". Then next sentence says "Turbo failure is not currently a covered item under new power warranty". Is "new power warranty" different than "factory warranty"?
  13. bml71
    bml71 Karting
    Mar 2, 2019
    88
    Virginia
    Bradd Lewis
    Yes it is different. You can extend the factory warranty for either 1 or 2 years to total 4/5 years of full factory warranty. There are only certain times you can do this however. In addition you can get a New Power warranty that only covers certain parts of the drive train post warranty for up to 15 years in total
    scott61 likes this.
  14. scott61
    scott61 F1 Rookie
    Feb 11, 2004
    2,606
    North of Boston
    Thanks, now get it.
  15. RaceMX-M3
    RaceMX-M3 Formula Junior
    Dec 15, 2010
    540
    Frisco, TX
    Scott
    Interesting read. FWIW my 488 has 9600 miles and turbos are humming along good as new. :)
    blkdiablo33 and Mighty Joe like this.
  16. Mighty Joe
    Mighty Joe Formula 3
    Sep 3, 2010
    1,127
    Atlanta, GA
    Joe
    Mine too!!!!:)
  17. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,808
    Dallas Texas
    Years 1-3 are " Factory Warranty " failure of components covered under this warranty
    Years 4 and or 5 are " Warranty Extension " , exactly what it sounds like, this is an extension of the first 3 years of factory warranty
    Years 6+ are New Power Warranty , only covers listed items for failure
    Optional:
    Years 8+
    only for cars 2012 or newer, " Main Power Warranty " , same as New Power Warranty with the addition that the next years annual service is included as well
    Technically all of the above are " factory warranty " as Ferrari SpA is the underwriter for the claims and payment of the claims. But the above description breaks it down in simpler terms.
    Hope this helps,
    Steve
  18. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,369
    AUSTRALIA
    ANGELO
    You have a greater chance being stuck at the servo with a flat battery than a blown turbo.
    Trust me it will hit you when less expected. Suggest getting a battery charger. You can thank me when you need it
  19. bml71
    bml71 Karting
    Mar 2, 2019
    88
    Virginia
    Bradd Lewis
    Yes I am on 3rd Ferrari and I still am perplexed by how Ferrari can’t solve an issue that for the most part the rest of the industry did 30 years ago... 350k for a car you can’t leave off a battery tender longer than 48 hours
  20. scott61
    scott61 F1 Rookie
    Feb 11, 2004
    2,606
    North of Boston
    3rd? If I my AC decides it needs a break again I wont be making it to a 2nd
  21. RaceMX-M3
    Dec 15, 2010
    540
    Frisco, TX
    Scott
    I own a portable charger. Need to plug it in and charge it.
    MANDALAY likes this.
  22. Solid State
    10,466
    They cover everything not wear related for first 3 years then with the 2 year extension of the bumper-bumper. After that its just drivetrain. Turbos are listed in the exhaust section of the parts diagrams and thus not covered and considered disposable like mufflers - a $30k set of mufflers. Since they made a lot of cars with these it seems rebuilds can be an option. I am amazed at the reliability demands of such a part on a high performance engine. Personally I will no longer even crack a nut on an exhaust system.
  23. MANDALAY
    May 23, 2013
    14,369
    AUSTRALIA
    ANGELO
    Guaranteed one day you will need it. As the add goes never leave home without it.
    Shadowfax likes this.
  24. RaceMX-M3
    Dec 15, 2010
    540
    Frisco, TX
    Scott
    It's been sitting in the front of my car for couple of years. I think it's dead. Too bad Escort gave it to me at a car show where we drained my battery. It looks expensive.
  25. MANDALAY
    May 23, 2013
    14,369
    AUSTRALIA
    ANGELO
