488 wheels on 458 | FerrariChat
488 wheels on 458
Discussion in '458 Italia/488/F8' started by mikesun001, Dec 17, 2016.
  1. mikesun001
    mikesun001 Karting
    172
    Shanghai, China
    Mike Sun
    Just upgrade the 458 with 488 Diamond wheels, happy with them.
    [​IMG][​IMG]
  2. Shinigami
    Shinigami Formula Junior
    Aug 2, 2005
    465
    Gland Switzerland
    Heikki
    I do like those rims, very nice :)
  3. 338Lapua
    338Lapua Formula Junior
    Sep 5, 2015
    802
    Michigan
    Tony
    Looks nice! Since the body lines are "similar" between the 488 and 458 it's now obvious to me that they should look great on the 458. I may need to think about this when I get my 458! Thanks for posting.
    458 Spider 0414 likes this.
  4. DK308
    DK308 F1 Rookie
    Aug 13, 2013
    2,738
    Europe, way north.
    AB
    They must sit very far out in the rear. Seeing that the 488 rears are 0.5" wider and have an offset of 20 mm less.
  5. mdslone
    mdslone Formula Junior
    Sep 8, 2016
    332
    South
    FerrariM
    Wow! Great choice. Looks really nice.
  6. kramsay1234
    kramsay1234 Formula Junior
    Jul 16, 2009
    347
    Toronto, Canada
    Looks aggressive.
  7. 458italia2014
    458italia2014 Formula 3
    Aug 3, 2013
    1,048
  8. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,112
    Mel
    Quite right .... that is very important, more important than just looks ... and how about tyres ... ?
  9. mikesun001
    mikesun001 Karting
    172
    Shanghai, China
    Mike Sun
    Just use the 458 tyres.
  10. Melvok
    Jul 25, 2008
    14,112
    Mel
    Not that simple Mike ! Offset is very important ... wheels may be too far out or inwards ...
  11. DK308
    DK308 F1 Rookie
    Aug 13, 2013
    2,738
    Europe, way north.
    AB
    As Melvok said, it's not that simple. That 38.5 mm offset in the rear will create a lot more understeer than the stock wheels with 58.5 mm offsets.
    I'd definitely try to see if either 265/30R20 or 275/30R20 tyres would clear the front fenders if I had installed the 488 wheels to combat the understeer associated with the shallower offsets in the rear. This size of course combined with the OE 295/35R20 rear tyres.
  12. Llenroc
    Llenroc F1 Rookie
    4,806
    Colorado
    Vern
    #12 Llenroc, Jan 3, 2017
    I thought I would share my 488 wheel change on my 458. My original wheels were the std unit with chrome paint option which I like but the style fits the California better. It reminds me of a refined design that looks better on a GT car vs the more aggressive look of the 458.
    I started out looking at the optional forged wheels that are available on the 458, but they have to much of basic look to them, i.e.; lacking style/design imagination.
    Thanks to Chris at exoticcarauto who listed this set of factory forged take offs from a 488. They have a much more artistic engineered look to them then the 458 wheels available from the factory(std. or opt.) also they are 1/2 inch wider and slightly lighter on the rear, fronts way exactly the same.
    The wheels on the a 458 are set in to far in the fender well, apparently some regulation(what else is new) requirement. Anyway the tire sidewall now is flush with the top of each fender front and rear. I used the same tire size, 295 35, on the rear but changed to 245 35 on the front vs. 235 35. The reason for the frt tire change was to get a little more tire on the rim, the 235 looks small on the std wheel and probably would be worse on the 488 wheel being that it is 1/2" wider. the height is almost the same but the section width is about 5/8" wider.
    To address the concerns of any problems that were mentioned above… there aren't any.
    In either sport mode or the 3 settings in race mode. I think between the suspension ecu/nannie aides and tire pressure adjustments IF there were any handling problems they were handled electronically or I could have fine tuned tire pressures. As always pictures don't quite do the look justice.
    C.W likes this.
  13. SECRET
    SECRET Formula Junior
    935
    Anyone know the wheel sizes, offsets, and tire sizes between:
    · 458
    · 458 Speciale
    · 458 Speciale Aperta
    · 488 GTB
  14. DK308
    DK308 F1 Rookie
    Aug 13, 2013
    2,738
    Europe, way north.
    AB
    The 458Spec and SA uses the same spec wheels.
    458
    20”, PCD 5 X 114.3 mm
    Front 8.5 X 20 ET 46.5mm, Rear 10.5 X 20 ET 58.5 mm
    458 Speciale
    Front 9 X 20 ET 44.7 mm, Rear 11 X 20 ET 48.4 mm
    488
    Front 9 X 20 ET 44.7 mm, Rear 11 X 20 ET 38.5 mm
  15. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,059
    Fort Washington, PA
    John S
    Very cool, I like the OEM+ look!
  16. Llenroc
    Llenroc F1 Rookie
    4,806
    Colorado
    Vern
    Thanks, That was my thought too.
  17. f12luke
    f12luke Karting
    Jan 2, 2017
    76
    United Kingdom
    Luke Tarbuck
    I think it looks great! Enjoy the car!
  18. Llenroc
    Llenroc F1 Rookie
    4,806
    Colorado
    Vern
    Thanks, I think it turned out better than I originally envisioned.
  19. RosserMcIntosh
    Jul 2, 2015
    2
    Atlanta
    Zack McIntosh
    I'm interested in hearing some owners opinions on the difference between the 458's sound the the 488. I know the 488 is turbocharged which reduces the noise but from some owners, how would you compare the sounds? Is the 488 really more muffled or are they both great, just different?
    Thanks guys!
  20. DK308
    DK308 F1 Rookie
    Aug 13, 2013
    2,738
    Europe, way north.
    AB
    If you do a search here on the board, you'll see that the subject of the 458 vs. 488 sound has been beaten to death a million times. Frankly I think we can do without another round of that.
    In any case, you should start your own thread and not hijack this as it will take if off topic.
  21. Fezza328GTS
    Fezza328GTS Rookie
    Feb 11, 2015
    27
    thanks for posting. looks fantastic.
  22. Exoticar Auto
    Exoticar Auto F1 Rookie
    2,990
    Tampa Bay FL.
    Exoticar Auto
    #22 Exoticar Auto, Jan 6, 2017
    Not only do they fit but they fit well. Very nice Vern! We currently have satin black, gold, and diamond in stock if anybody would like to make the switch!
    We are a proud Fchat sponsor and between us and Mr. Taz, we have created the Ferrari OEM wheel specification PDF. Give us a call guys, were working hard over here for you, thanks. Stand by for the TDF wheels on the normal F12.
    488 GTB wheel Weights
    24.5 front and 26.5 rears
    Compared to the 458 wheel weights
    http://www.ferrarichat.com/forum/458-italia-488/525346-ferrari-458-factory-wheel-weight-comparison.html
  23. YellowMurci
    YellowMurci Formula 3
    1,824
    NyC Baby!
    Harry
    looks good!
  24. Wynand van der Merwe
    Oct 22, 2017
    3
    Pictures available of Black set on a red car?
  25. Exoticar Auto
    2,990
    Tampa Bay FL.
    Exoticar Auto
