355 - 5.2 tank draining/siphoning? | FerrariChat
355 5.2 tank draining/siphoning?
Discussion in '348/355' started by krazykarguy, Feb 16, 2019.
  1. krazykarguy
    krazykarguy Formula Junior
    Apr 17, 2014
    732
    Fort Mill, SC
    Matt
    Hi all -
    I did a search and did not find the exact answer I needed.
    My father has begun the teardown in preparation for the major service this winter on their '97 Spider. Of course, he has already started and realized only recently that the car has well over half a tank of fuel in it.
    At this point, a fair amount of the initial work is complete (rear bumper removed, exhaust out, ancillary systems pulled, hydraulic and electrical disconnections, etc.), so I would be wary of re-connecting the battery and either letting the fuel pump push it all out for fear of setting a code only resettable via SD1/2 or ruining something electrical that should have been plugged in but wasn't.
    I am not sure if this is a problem or not, and while he thinks he sees a drain plug on the tank, I seem to recall that there isn't one on this car/tank. The closest thread I could find was the one where someone needed to drain leaded fuel accidentally introduced to the car and in that case, they let the pump do the work.
    Will the car bleed fuel the entire time the engine is out at this tank level? Or will it leak only a certain amount and then stop? Looking at the parts diagrams, it appears that if you kept the main fuel line vertical, capped off, and above the fuel level after disconnecting it from the fuel filter, you might be OK.
    So, TL;DR: is there a drain on the 355 fuel tank? Can you do an engine-out major with a tank full of gas? If no, is siphoning the gas out via the filler the best option for a partially disassembled car?
    TIA
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Matt - unless the major is going to take him years to complete, you don't need to do a thing with the gas - leave it in the tank. Just don't smoke around the car ;)
  3. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,219
    CT
    John Kreskovsky
    Fixed it for you.
    Dave rocks likes this.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,549
    San Carlos, CA
    Mitchell Le
    The drain plug will remove all the gas, but why do you want to do that?
  5. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Drain the tank and replace the pumps rubber gasket and clean out the in tank filter
  6. krazykarguy
    Apr 17, 2014
    732
    Fort Mill, SC
    Matt
    So that’s 2 votes for “no”, and one vote for “yes, and overhaul the fuel system while you’re at it”. :D
    The engine out is not a three year saga, the car will be back on the road this spring. If leaving the fuel tank with gas in it during a major is fine, that’s what we will do.
    Thanks!
  7. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Tim has a great point about the gaskets.
