5.7 engine for Countach | FerrariChat
Discussion in 'LamborghiniChat.com' started by Chadbourn Bolles, Dec 23, 2020.
  1. Chadbourn Bolles
    Chadbourn Bolles Formula Junior
    820
    Leesville, SC USA
    Chadbourn Bolles
    I have the parts to build a 5.7 engine for a QV Countach
    Also have crank to build a 5 ltr for Espada/Jarama/Countach using the 4 ltr engine.
    You have an engine down and want more power, this is the way to go.
    Adamo Cerquozzi likes this.
  2. Adamo
    Adamo Karting
    May 17, 2014
    142
    CANADA
    Adamo Cerquozzi
    Is it a crankshaft, rod and piston package?
  3. Chadbourn Bolles
    820
    Leesville, SC USA
    Chadbourn Bolles
    It is a crankshaft/rod package as I would not know what the customer would want for a final piston bore or compression ratio.
    Pistons with rings and the correct pin location and compression ratio will run around $3700.00 for the set.
    Depending on the QV block used, crank may have to have the # 2 and # 6 main bearing oil holes plugged.
    In my 409 engine I got rid of that (in my opinion) stupid oil system, and went back to the 4 ltr system which is almost the same for all Diablos.
