5 LUG TESTAROSSA WHEEL UPGRADE | FerrariChat
Discussion in 'Technical Q&A' started by u3246n, Apr 21, 2005.
  1. u3246n
    u3246n Rookie
    Apr 7, 2005
    4
    tamaqua pa.
    jan laurenti
    Does anybody know what newer 17 or 18" Ferrari wheel can be made to work on an 89 Testarossa?
  2. Organiser
    Organiser Formula Junior
    Jan 13, 2004
    922
    West Midlands UK
    Phil Haynes
    Hi,
    The later 512 tr 18" wheel will fit as will the 348 GTC - 512 option comp Speedline 18" Wheel.
    Both are available new but will be expensive, you will also need a Fitting kit from Hill Engineering in the UK to fit them.
    Hope this helps.
    Regards,
    Phil.
  3. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    Why? The knock-off single lug wheels look so much better! You can get larger knock-off single lug type wheels at www.GaRedCars.com .
  4. Rifledriver
    37,288
    Do you really want him to do a retrograde conversion back to the center lock wheels that fall off? An 89 came with the better 5 lug wheels that always stay on.
  5. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,067
    Kansas
    Sean F
    Why do the TR's have such an issue with the single lug wheel, but the 512's it doesn't seem to be a problem. Heck, the early cars had knock offs that you used a brass hammer to tighten up! Just how much torque can you get out of one of those anyway?
  6. Rifledriver
    37,288
    The are as a result of a then current federal requirement, different design. The 512 and previous had a large nut, worked perfectly but a desk jocky in Washington required Ferrari to switch to a bolt. When they were allowed to go back to the nut design (F40) no more problems.
  7. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,067
    Kansas
    Sean F
    Ahhh, I thought they were both nuts. Now I see.
  8. u3246n
    u3246n Rookie
    Apr 7, 2005
    4
    tamaqua pa.
    jan laurenti
    Guys the car has 5 lug wheels on it now! I would like to put 18" wheels on instead of the dated 16".
  9. Chiaro_Slag
    Chiaro_Slag F1 Veteran
    Oct 31, 2003
    7,789
    CA
    Jerry
    #9 Chiaro_Slag, Apr 21, 2005
  10. quattrovalvole
    Dec 13, 2004
    2
    Littleton CO
    Steve
    I put on a set of 360 18" wheels on mine I just had to order lug bolts 5mm longer. 18X10 in the rear and 18 x 7 in the front
  11. p-o-r-s-c-h-e
    p-o-r-s-c-h-e Rookie
    Feb 16, 2004
    21
    Germany
    Is there a photo possible Testa with 360 wheels?
    Juergen
