5 speed conversion | FerrariChat
5 speed conversion
Discussion in '365 GT4 2+2/400/412' started by Godspeed!, Jan 12, 2012.
  1. Godspeed!
    Godspeed! Karting
    Dec 1, 2006
    137
    Mandeville, Louisian
    Dave Foley
    Almost a year ago, I set out to design an adaption of a BW 5spd WC 4wd tranny to my 400A. The WC 4wd has a flange type mounting at rear of tranny which made it a good candidate. Gear ratios were examined with stock rear end and seemed acceptable. Would have to look in file for specifics.
    With the engine and tranny out of the car, careful dimensions were acquired. Mock up was put in place for clr checks.
    Tranny mounts to a chevy bellhousing, an adapter unit with shaft rotating within two large precision bearings was designed to mount to flange on rear of tranny, then to unmodified stock auto tourque tube. A centerforce clutch was spec'd around which a flywheel was designed, allowing use of original ring gear plate.
    I secured a factory new clutch pedal pad, and brake pedal pad for a std tranny car.
    So where I'm going with this is.........................if you are interested, and have the design / engineering cpabilities , I am selling all bits, drawings and SolidWorks models to someone who will take over the project...................if there is no interest, I will part out the tranny and clutch on e-bay after the weekend. But just know someone out there can take this over! And would love to see it completed. Once completed, you can offer a kit to others.
    What you would get is all designs in electronic format for SolidWorks and AutoCad, the tranny which is basically new, bell housing, billet chunk from which to machine adapter, new Ferrari factory clutch cable, both new factory pedal pads, shaft material for pedal shaft, precision bearings for shaft in adapter and Center Force clutch assy for $1000.00 , you pay shipping or pick it up....... I have crate for tranny.
    The hard stuff is done. But work still remaining. I have a complete 2d layout of all parts, and 3d SolidWorks models and some dimensioned 2d working drawings with bearing tols etc .
    Remaing to be designed is shift lever box and speedo cable interface or electronic pick up either of which can be incorporated into the adapter assy. You will machine flywheel, adapter housing, and shaft. You will decide method of clutch operation, cable or all in one TO brg. I can offer suggestions.
    Full time I engage in one off mechanical design work for an "interesting" agency. So this has been well thought out. Many hours invested. Decided to keep auto tranny in this particular car.
    Godspeed!
    Dave
  2. brettski
    brettski Formula 3
    Feb 29, 2004
    1,754
    north of toronto
    brett swaykoski
    very interesting Dave...and i might be very interested...let's talk...PM me your number or call me at the number below.
    thanks,
    brett, 705-435-1990
  3. open roads
    open roads F1 Rookie
    Jan 28, 2007
    3,799
    Sarasota, Fl.
    Stan
    Good luck guys. I hope this happens.
  4. Godspeed!
    Godspeed! Karting
    Dec 1, 2006
    137
    Dave Foley
    Brett,
    Will give you a call a bit later in the day.............
    Godspeed!
    Dave
  5. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    Dave
    Did I understand that this is a 4 wheel drive tranny or does 4wd mean something else? If so, what happens to the front wheel drive outputs?
    Ken
  6. bilodeaulynn
    bilodeaulynn Karting
    May 1, 2005
    58
    If I understand correctly, he is using the 4wd tranny because it has a tailshaft with a four bolt flange instead of a standard spline type tailshaft into which a driveshaft yoke would slip. Normally that four bolt flange would accomodate the transfer case that would then drive the front wheels. Instead of bolting up a transfer case, he plans to bolt it directly to the existing torque tube (or use an adapter and bolt it up).
  7. bilodeaulynn
    May 1, 2005
    58
    I have seen several posts indicating that the turbo 400 tranny bolts to an adapter plate on the back of the engine. A couple of posts state that the tranny bell housing (integrated) is the standard GM bell housing. Is it the chevy bolt pattern, or what everyone refers to as the BOP, meaning Buick, Olds, Pontiac pattern?
    Thanks for any help.
    Lynn
  8. 180 Out
    180 Out Formula 3
    Jan 4, 2012
    1,286
    San Leandro, CA
    Bill Henley
    #8 180 Out, Jan 15, 2012
  9. bilodeaulynn
    May 1, 2005
    58
    So, it appears the chevy bolt pattern. I guess I could have figured that part out from Dave's original post where he said "Tranny mounts to a chevy bellhousing"
    There are so many different bellhousings out there. Lots of aftermarket steel ones as well, such as Lakewood.
    Lynn
  10. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Barrington, Ill. USA
    Ross
    Our cars use the Chevrolet bell housing pattern for sure.
    Ferrari has already done the hard work to get the front of a Chev pattern trans to fit, it is the adaptation to the enclosed driveshaft that presents the challenge, along with clutch and gearchange operation.
    I'd would be very pleased to see this project come to fruition.
  11. JeremyJon
    JeremyJon F1 Veteran
    Jul 28, 2010
    7,569
    Calgary, Canada
    being that the Ferrari uses the standard chevy bolt pattern (unlike the Jaguars which used TH400 also) then even better then a T5, is a Tremec TKO transmission, is possible as well, which will allow moving location of the shifter should that be needed
    but for adapting to a TQ tube, the T56 came in such configuration, though it is a larger and heavier transmission, the benefit is a 6th speed also
  12. bilodeaulynn
    May 1, 2005
    58
    So, has any one checked out the possibility of not using the enclosed driveshaft? I understand it acts as a torque tube, but that can be accomplished other ways.
  13. Godspeed!
    Godspeed! Karting
    Dec 1, 2006
    137
    Dave Foley
    All, back in town now after quick run up north. Fresh nice to be back in warm weather
    Trust me , there is a lot to this. Will answer and maybe post pics later .............
    WC is the World Class version of the T5 with better brgs. 4wd designates a flanged rear tail section and simple splined tail shaft Yes there is a machined adapter between back of tranny and torque tube flange.
    Retains original design intent.
    Spoke to Brett, he has first dibs and is interested......"......
    Godspeed !
    Dave
  14. lmaldoon
    lmaldoon Rookie
    Feb 5, 2005
    30
    La Quinta CA
    Lee
    This thread has come up a few times before, and since we are talking about automatics, what is the opinion here about buying a converted automatic? Would you buy one? I've owned my 400ia for eight years and love it. I can't lie, there are times when I wish it had better pick up, that it always seems like I'm starting in second gear but once it get in the power band it a great drive. Most of us covet the 5speed manual over the automatic but I think this is a great cruiser and well suited for an automatic 99 percent of the time i just wish it had more gears. This brings me to my real question, instead of converting to a manual how about installing a modern 6 speed auto with a lower 1st gear and a higher final o/d, ie the TCI6x auto? Would you buy one if available? What effect would this have on the value of the car? What effect would a automatic to manual conversion have on the value of the car? Would a change like these make the car vertually unsaleable?
  15. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Ross
    I would consider more low & mid ratios a plus, even if it were a different autobox.
    Four speed auto boxes will generally have the same ratios as we already have plus an overdrive which isn't needed. Any auto trans with more than 4 gears is going to have computer control to adapt.
    Nice idea but not very practical.
  16. lmaldoon
    lmaldoon Rookie
    Feb 5, 2005
    30
    La Quinta CA
    Lee
    The reason I suggested the TCI6X (although somewhat costly, approx $6000 for full kit plus install) is that the gear ratios are 1st 2.97 2nd 2.23 3rd 1.57 4th 1.18 5th 1.00 and 6th .75. This would give about a 20% lower 1st gear and more mid range gears to help keep the car in its power band. It also has a standard GM bolt pattern and a tail that could be addapted to the original torque tube. You could have the car still look original if so desire. I toy with this idea a little more than a manual conversion due to the complexities of adding a clutch system to a automatic car. The cost is not what keeps me from doing the conversion but rather the battle within on keeping the car original or "improving" the cars drivability.
  17. ricar116
    ricar116 Formula Junior
    Aug 2, 2005
    409
    Bolivar, Missouri
    Rick Carr
    Have you guys looked into an older GM 700R4. That would be 3 speed plus overdrive, non computer controlled
  18. Ak Jim
    Ak Jim F1 Veteran
    9,624
    North Pole AK
    The problem is the first three gears are the same ratios as the three speed and there would be no off the line improvement in acceleration. If you could get the 4.30 gear end gears from a manual transmission car it would be a great set up.
