500 horse power? | FerrariChat
500 horse power?
Discussion in '308/328' started by PittsS2APilot, Oct 6, 2009.
  1. PittsS2APilot
    PittsS2APilot Formula Junior
    Jun 29, 2007
    857
    Gulfport MS
    Joe
  2. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    29,386
    E ' ' '/ F
    Trailer Swift
    Once....
    Actually, with a big turbo, intercooler, and a port nitrous system you could probably get close for brief periods of time. You'd need a LOT of fuel flow, and some stronger-than-stock head sealing. I can't see that as a 500 HP real world motor.
  3. GrigioGuy
    Nov 26, 2001
    29,386
    E ' ' '/ F
    Trailer Swift
    Of course, my buddy Aaron has gotten 700 HP out of a Toyota MR2 motor.
  4. Driftracer3
    Driftracer3 Formula Junior
    Jan 5, 2006
    640
    Its very possible, its not difficult to make 500hp. Proper engine management, fuel system(42lb injectors, pump), and the turbo/IC, fairly easy actually.
  5. Jedi
    Jedi Moderator
    Moderator Lifetime Rossa Owner
    Mar 18, 2008
    31,528
    Seattle Area
    Dave
    1000 miles?
  6. Earthboundmisfit
    Earthboundmisfit Formula Junior
    Aug 7, 2009
    886
    Ontario
    Steve
    I like this line in the ad:
    "With 1000 Kg, the ratio power/weight is very low"
    In that case, no thanks
  7. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,517
    Cerritos, CA.
    And 735 HP on my friends VW GTI Turbo
  8. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    Of course there's a lot of nonsense in the ad, but it's a pretty cool toy.
  9. SMS
    SMS F1 Veteran
    Jan 7, 2004
    6,772
    Indy
    Bill S.
    It was on www.race-cars.com and says sold there.
    Looks like a real race car on that site. Full race 308 turbo cars can make 800. 500 should be reasonable for a 3.2 V8.
  10. bert308
    bert308 Formula 3
    1,776
    Roermond Netherlands
    Bert Kanters
  11. 328turbo
    328turbo Formula Junior
    Jun 15, 2009
    306
    nyc
    it is probably an estimate of hp @ the crank.
    but it is also probably not far from the truth.
    mine is pumping out well over 400 @ the crank without an intercooler, low boost, and on pump gas.
    Norwood tuned it rather conservatively andshe drives around town Better Than Stock. we believe that with proper dyno time, there is room for more power with no further mods. we will be exploring this over the winter
    ........stay tuned for that
    turbocharging is without a doubt the most efficient way to maximize the power for any given fuel quality on a street car. in this case a race car :)
    you definitely need lots of fuel.
    i feel 500hp is realistic and obtainable in a street situation -at least @ the crank.
    crank hp and wheel hp are VERY different in these cars.
    but expensive! :eek: ive seen many grand nationals and turbo supras that make MUCH MUCH more power than this on engines with very similar displacement. what kind of fuel they are running and how streetable these engines are, thats another story. ;)
  12. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,685
    Mike 996
    Well, with forced induction or nitrous, streetable is usually not an issue since the car can behave almost exactly as stock until the boost comes up/nitrous comes in. The level of boost applied or N2O amount (and appropriate additional fuel) injected will determine the HP which, along with how long and how often it is applied, will determine the longevity and reliability of the motor. Generally, it is considered that HP increases of around 33% will not adversely affect stock engines/drivetrains. Beyond that and it depends greatly on how the engine was designed in the first place.
  13. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Years ago one of my 308 mechanics was an F40 specialist too. Look at the specs, see anything familiar?
    Displacement 2.936 liter / 179.2 cu in
    Bore / Stroke 82.0 mm (3.2 in) / 69.5 mm (2.7 in)
    Valvetrain 4 valves / cylinder, DOHC
    Aspiration Two IHI Turbos with two Behr intercoolers
    Power 478 bhp / 357 KW @ 7000 rpm
    Torque 577 Nm / 426 ft lbs @ 4000 rpm
  14. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Long Beach / Phoenix
    Luigi
    #14 RVIDRCI, Oct 7, 2009
    500hp ? Absolutely possible with efi / engine managment and forced induction.
    I'm making nearly 400hp with my bolt on blower and K-jet CSI, stock ignition with a CDI box. (330+ rwhp). I think mke (Mark Eberhard) on this forum was making 500+ hp from his seriuosly supercharged QV motor.
  15. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    Looks like it's one of them there new fangled plug-in hybrids (see pic 12).
    At least there's a solid looking roll cage in the car to save your noggin when all 500hp kicks in on boost/nox...
  16. scuderiatc
    scuderiatc Karting
    May 20, 2006
    126
    Phoenix, Arizona
    Tee
    Is your car a 328, QV or 2V?
    -Just curious.
    I completely agree BTW. In fact, there are 3.2 litre race engines out there all over the place making 400 nat aspro hp with EFI.
  17. venusone
    venusone F1 Rookie
    Mar 20, 2004
    3,238
    #17 venusone, Oct 8, 2009
  18. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Luigi
    Mine's a Eurospec 308QV, very late production 85. Check my profile.
