512 BBi, #51257 ended up in my garage | Page 7 | FerrariChat
Discussion in 'Boxers/TR/M' started by pshoejberg, Oct 21, 2017.
  1. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,516
    Canada
    Newman
    Nice to see things routed properly, you'll find most are not after any servicing has taken place.
    pshoejberg likes this.
  2. Newman
    Dec 26, 2001
    14,516
    Canada
    Newman
    Coolant pipe crossover clamps should have the gear housings under the pipe not on top. The details are so close to correct Im just trying to help.
  3. pshoejberg
    pshoejberg Formula 3
    1,860
    Denmark
    Peter H
    Thanks Newman. Any hints are welcome and much appreciated. There are so many details to investigate and not many reliable sources. That's what makes this forum unique.
    Best, Peter
    turbo-joe likes this.
  4. Newman
    Dec 26, 2001
    14,516
    Canada
    Newman
    Okay good. Im going to check a detail on the breather hose and get back to you.
  5. Newman
    Dec 26, 2001
    14,516
    Canada
    Newman
    I run the breather hose p-clips pointing down and use the lower starter bolt not the upper. This makes the hose pretty much straight, it's a detail I copied from the original 84 I restored.
  6. Ludwig
    Ludwig Formula Junior
    Mar 27, 2006
    307
    Redmond WA
    Ludwig Allegra
    Looks great and very timely. I'm almost exactly at the same point will post later today.
  7. pshoejberg
    1,860
    Denmark
    Peter H
    Newman, one more question now we are at the details; I have used a Colson plastic cable strip to fasten the rubber boot on the starter solenoid but have seen a picture with the boot secured using a steel clamp same type as used on the air intake bellows. What is most correct?
    Best Peter
  8. Newman
    Dec 26, 2001
    14,516
    Canada
    Newman
    Steel clamp is correct just like the bellows on the air cleaner ducts. Earlier cars used a steel wire clip. Never a plastic tie.
  9. Newman
    Dec 26, 2001
    14,516
    Canada
    Newman
    Here's the 84 I did. Shows the orientation of the cotter key in the band clamp and maybe other details that are helpful.
    No matter what I did the air boxes couldn't be lined up with the 90 degree inlet boxes so the bellows are crooked. Drove me crazy.
  10. Newman
    Dec 26, 2001
    14,516
    Canada
    Newman
    The small coolant line from the tank to the water manifold runs together with the large one then splits and goes on its own around the a/c compressor. The coulson plastic ties are used to hold them together. You can see one just above the compressor where its retained to the brake booster hose. If your car had DOT mods that vacuum port on the right plenum might have an angle or Tee there.
  11. Newman
    Dec 26, 2001
    14,516
    Canada
    Newman
  12. dwhite
    dwhite F1 Rookie
    Wow, such a labor of love and talent. Looks wonderful. Peter, which exhaust manufacturer is that?
  13. pshoejberg
    1,860
    Denmark
    Peter H
    Great help Newman. I'm turning clamps and rerouting hoses accordingly and it all contributes to a neat appearance!
    Best, Peter
  14. pshoejberg
    1,860
    Denmark
    Peter H
    Thank you very much. The exhaust system is from Nuvolari in UK and it's made from stainless steel. It's priced reasonably with a similar cost as a original mild steel sports system from Ansa.
    Best, Peter
  15. Newman
    Dec 26, 2001
    14,516
    Canada
    Newman
    The Gearheads on the main crossover face forward. Regardless of the direction they are terrible to access as Im sure you know. At least with a hex head they can be undone with a socket and some patience. The carb cars had them facing to the rear but they were slothead only and without WUR's in the way they could be easily reached.
  16. Newman
    Dec 26, 2001
    14,516
    Canada
    Newman
    Hard to see in the most recent pic but if you look near the drain plug on the top of the compressor you can see the outline of a tab from the coulson tie strap holding the coolant hose to the vacuum hose.
  17. pshoejberg
    1,860
    Denmark
    Peter H
    I see the tie strap on your picture. Unfortunately my vacuum fitting into the plenum is a 90 deg bend and not a straight so I have to improvise slightly with fixation of the cooling hose. I also noticed that I had turned the distributor 240 deg away from the right direction. That explain why I couldn't obtain even adjustment travel around the distributor bolts...-:).
    Engine fired right up yesterday and appears to be running fine. I'm hearing a high pitch whining sound from the the ignition box (I assume). Is this a well known thing or should I be worried? next up is adjustment of ignition and test run.
    Best Peter
    Newman likes this.
  18. pshoejberg
    1,860
    Denmark
    Peter H
    #170 pshoejberg, May 3, 2020
  19. Newman
    Dec 26, 2001
    14,516
    Canada
    Newman
    Spark plugs go inside the loop of the oil filter wrench and are wrapped in wax or parchment paper.
    The pulley looks like a 308 air injection pulley on the rear exhaust cam. I would need to see the other side of it.
  20. Newman
    Dec 26, 2001
    14,516
    Canada
    Newman
    Blue handled pliers are correct for 84 and a black scissor jack, I forget what year yours is.
  21. Newman
    Dec 26, 2001
    14,516
    Canada
    Newman
    Whining sound is normal. In the future when the car starts backfiring and the tach needle bounces its telling you its on its way out.
    pshoejberg and turbo-joe like this.
  22. pshoejberg
    1,860
    Denmark
    Peter H
    Mine is late 84, so pliers should be blue, but at least I got the black scissor jack. I dried my oily hands off in the parchment paper for the spark plugs...you can't win it all...-:).
    Thanks, Peter
    Newman likes this.
  23. Newman
    Dec 26, 2001
    14,516
    Canada
    Newman
    Is your interior Creama or Beige (Tan)?
