512 bbi front frame paint schedule | FerrariChat
Discussion in 'Boxers/TR/M' started by pshoejberg, Jun 25, 2019.
  1. pshoejberg
    pshoejberg Formula 3
    1,695
    Denmark
    Peter H
    I am prepping my front frame for paint and have one more question for the bbi experts; What type of paint was originally used on the front sub frame? Was it painted with structure paint (Stone-guard stile) like the rear frame or is it a "normal" automotive paint or is it a combination. I have seen several restorations and I have seen both solutions. How about the gloss? Was it a flat paint or a high gloss, or in between?
    Thanks in advance
    Peter
  2. Ludwig
    Ludwig Formula Junior
    Mar 27, 2006
    307
    Redmond WA
    Ludwig Allegra
    As best I was able to tell, it was a primer followed by single stage color same as the body, then a product similar to stoneguard.
    I sandblasted to metal, used DP90 as a primer then single stage black followed by stoneguard. looks pretty well matched to the original other than I used black instead of the corso rosso. I also am not spraying everything with Dinol.
  3. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,155
    Canada
    Newman
    The frames weren't painted with stoneguard. The frame was primed, painted body colour as you mentioned (but sprayed on light unlike the body) then it got the same black you had everywhere else externally on the body thats smooth. The poor prep and paint application created a bit of a texture but it was inconsistent and sloppy with crap in it. Like a dog covered in dirt was required to stand beside each chassis after paint and shake itself off.
  4. pshoejberg
    1,695
    Denmark
    Peter H
    Thanks for much appreciated input guys. Based on this my plan is to start out with an Epoxy primer followed by a 2K automotive lack and finished off with a sloppy layer of Mipa 2K-PU-Truck bed liner paint that has a bit of a structure to it just like the original "Stoneguard" layer that's originally applied on the rear frame and the lower panels.
    Best regards
    Peter
  5. pshoejberg
    1,695
    Denmark
    Peter H
    Hereby a short update. I shot the frame in 3 stages:
    1. Epoxy primer, left for 24 hours drying and then manually prepped with grit 400 sanding material for next application
    2. Several layers of semi gloss black 2K automotive PU paint, left for 20 minutes resting time before application of structure paint (wet in wet)
    3. 2 layers of 2K PU semi gloss to mat Mipa truck bed liner. Did my best to be sloppy, but it is difficult.
    I am very satisfied with the result...very very close to the original appearance in the rear end, but much higher quality of products.
    Here is a few pictures:
    Epoxy paint applied
    2K PU paint completed:
    Structure paint applied:
  6. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    I really love all of the boxer restoration threads! I wonder if in ten years people will be doing the same with Testarossa’s? I suppose its doubtful due to the production numbers.
  7. pshoejberg
    1,695
    Denmark
    Peter H
    I have no doubt that the Testarossa's will be subject for extensive restorations in a few years. It happens to all classic cars nearly irregardless of value and production numbers. The owners get attached to the car and gets carried away at any cost.....Ask me how I know...-:)
    Best
    Peter
    xplodee likes this.
  8. kartboy1234
    kartboy1234 Formula Junior
    Nov 10, 2014
    694
    Palos Verdes, CA
    Michael L
    I'd love to strip my TR down and do a full rebuild. Problem is that I don't have the space to do it, and eventually cost would probably be a factor. But I want to strip things down when I get a full paint job eventually.
    Sent from my ONEPLUS A3000 using Tapatalk
    xplodee likes this.
  9. Ludwig
    Mar 27, 2006
    307
    Redmond WA
    Ludwig Allegra
  10. pshoejberg
    1,695
    Denmark
    Peter H
    You are right Ludwig....I obtained the exact "orange peel" look I was after. I guess it is down to two things; First of all the 2K bedliner product with a lot of "body" to it and setting up really hard and resistant due to the 2K hardener. Secondly I used a high quality gun to apply the product with:
    With this gun there are multiple ways of adjusting the spray pattern and thickness of the layer.
    Best regards
    Peter
  11. dwhite
    dwhite F1 Rookie
    Both of your cars will be spectacular when completed.
  12. Ludwig
    Mar 27, 2006
    307
    Redmond WA
    Ludwig Allegra
    Ill look into that gun- I just have the regular wurth undercoating gun.
    Thanks!
  13. Ludwig
    Mar 27, 2006
    307
    Redmond WA
    Ludwig Allegra
    Peter- do you have a more specific link to the gun you're using- I can't seem to find one that is any better than the undercoating gun I now have
  14. pshoejberg
    1,695
    Denmark
    Peter H
