News
512 TR coolant
Discussion in 'Boxers/TR/M' started by bazzis, Jan 17, 2006.
  1. bazzis
    bazzis Karting
    Nov 5, 2003
    217
    Sarratt, Herts
    Just a small problem.. in the owners manual it tells you to fill the header tank with coolant to just below the neck of the tank, if I do this , as soon as the car reaches normal running temp',it pumps a lot of water out of the overflow!!. then when cold it has about 2" of coolant left in the tank, whats the normal level???
  3. Steve Magnusson
    Steve Magnusson F1 World Champ
    19,897
    Texas
    What is your reference for this value -- which 512TR OM? The coolant level should be more like ~6 cm below the neck when cold to leave some room for expansion.
    In the 1992 US 512TR OM, it says: "The level must not fall below 6~8 cm from the level of the coolant filler", but I know from other F documentation that this would be better translated as "the nominal (cold) level is 6 cm below the fill neck, and, if the level falls to more than 8 cm below the fill neck when cold, add more coolant (and, if it falls quickly/often, see your F repair shop to find out why)."
