512 TR SN for Transmission Number 1513 | FerrariChat
Discussion in 'Boxers/TR/M' started by tazandjan, Feb 19, 2014.
  1. tazandjan
    39,141
    Has anyone found the actual 512 TR serial number when the upgrade to the forged differential carrier was made? Using some basic math, I get around SN 96153, but do not have any SN and Transmission Number pairs to anchor the data I used. 1513/2290 disregarding spares and SNs from 89100 to 99743 gives 96153.
  2. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,260
    Mel
    Yes Terry, we do ! It 's in one of our Gearbox postings ...
    Shamile posted it ...
  3. evandaalen
    evandaalen Formula 3
    Feb 7, 2004
    2,394
    Deventer, NL
    Edvar van Daalen
    Please note that a higher serial number or VIN doesn't automatically mean that it also has a higher gearbox number. So, always check the gearbox number to make sure.
  4. 134282
    134282 Four Time F1 World Champ
    40,647
    California
    Carbon McCoy
    Hi, Terry, is 96153 a 512 TR? Is that confirmed?
    Also, is 1513 a transmission number or a transmission type?
  5. Melvok
    Jul 25, 2008
    14,260
    Mel
    #5 Melvok, Feb 20, 2014
    It took some time to re-find it again for you Terry; thanx to posting from Fchat member Shamile ...
    His posting/quote:
    SB 30-23 describes the new forged differential housing, part number 155099 that was incorporated in the 512TR somewhere around the 1994 model. It replaced the previous welded type. Checking the gearbox serial number will indicate which housing your 512TR has. The SN break is 1370 and later.
    Another improvement was made at SN 1513 whereas a later ring gear mated to the differential with dowel pins and bolts of finer thread than previously. My 1992 has gearbox SN 314 which is much prior to the forged differential. The SB states that the forged differential will also fit the Testarossa but does not mention the Boxer series.
    SB 30-23 also announces a new, stronger bolt to attach the ring gear to the differential. It is the courser thread allowing you to retain the older ring and pinion gear and could be used with either the welded or forged differential. I had planned to install these bolts when I do an engine out early next spring, but my fear is increasing enough about the welded differential that I may replace it also.
    SB 30-18 describes a new heavier propeller shaft incorporated in the 512TR commencing with engine number 31108. My engine number is 29896 so this probably occurred in 1993. The propeller shaft is what was previously pictured and referred to as the quill shaft. It transmits power to the transmission from the gearbox attached to the clutch housing. When I had the gearbox off to work on the throwout bearing this shaft slipped right out of the transmission. The female end goes in the transmission and male into the rear gearbox. The earlier shaft was 17 mm diameter while the improved shaft #151651 is 20 mm diameter. If my calculations are correct that is 38% more mass to the diameter of the shaft. The new shaft will fit the Testarossa and the 512BB according to the SB.
    I think the above production improvements of the late 512TR's carried over to the 512M with the same part numbers but don't have an M parts book so cannot verify this.
    End of quote .... :D
    Where to find that number under the car ? Looking from the back: on the left, lowest part of gearbox (GB)?
    (1st pic here the gb is on a bench, upside down, sorry, no better one for now)
    Found two more nice pics .... :)
  6. 134282
    40,647
    California
    Carbon McCoy
    Hi, Mel! How are you? I hope all is well. Is the first photo a photo of your gearbox? I notice that the gearbox number (stamping) is N263, and the gearbox type (casting) is 124859. The earliest 124859 type gearbox I can identify is on 90871 (Tipo 124859, #N 40). But I see F110 AB gearbox on much earlier Testarossas - the earliest F110AB type gearbox I can identify is 57769 (Tipo F110AB, #N312).
    Did type 124859 replace type F110AB? I have identified type F110AB gearboxes on much later cars (512 TRs), so I'm not really sure if 124859 conflicts with F110AB?
    Also, you posted pictures of another gearbox (N1129) - do you know the serial number of the car that has that gearbox?
  7. evandaalen
    Feb 7, 2004
    2,394
    Deventer, NL
    Edvar van Daalen
    Carbon, just in case you don't know it yet: mine (s/n 98932) is showing the gearbox type "124859" too. Gearbox number is N2178.
  8. 134282
    40,647
    California
    Carbon McCoy
    Thank you, Edvar! Now I have your engine number, assembly number, gearbox number, registration, exterior and interior colors - now all I need are the rear axle number, the body number, the date of production and the numero interno. :D
    The pursuit is never-ending.
  9. Melvok
    Jul 25, 2008
    14,260
    Mel
    Hi Carbon Friend, I don't know by now but most likely it is mine of the 512TR !
    But I have seen SO many broken gb's and loose housings by now ...
  10. 134282
    40,647
    California
    Carbon McCoy
    Do you know which one is yours? Because your pictures show two different gearboxes.
  11. evandaalen
    Feb 7, 2004
    2,394
    Deventer, NL
    Edvar van Daalen
    Carbon, in case you're interested in it: Last weekend I saw 512 TR s/n 93120. The engine number is 30525. The gearbox number is N508 (type: 124859).
    Regarding my own car, I guess you might still miss the window code: 98932FKS. :D
  12. barryr
    barryr Formula Junior
    Oct 16, 2010
    276
    Regina, Canada
    #12 barryr, Apr 24, 2014
  13. evandaalen
    Feb 7, 2004
    2,394
    Deventer, NL
    Edvar van Daalen
    That's a Testarossa, not a 512 TR. They had different ranges of gearbox numbers.
  14. tazandjan
    39,141
    Funny thing is, nobody yet answered the original question of what 512 TR serial number matches up with transaxle number 1370, where the change to the forged carrier was made.
    To answer Carbon's question, no, I am not sure 96153 is a 512 TR, that is just where the math approximation came out. 96151 is a 512 TR, 96156 is a 348, the two closest serial numbers, but irrelevant now.
    Using real data of 98932 and 2178 and 93120 and 508, we can calculate a closer WAG, and that is serial number 96120, not too far off from the original WAG. And 96119 is a 512 TR. So likely the change was made around SN 96000-96200.
