512BB oil capacity | FerrariChat
512BB oil capacity
Discussion in 'Boxers/TR/M' started by jww427, Jul 20, 2017.
  1. jww427
    jww427 Karting
    Oct 31, 2016
    148
    White Post Virginia
    john w. warner IV
    Anyone know how many quarts?
    thanks
    JWW
  2. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,371
    Canada
    Newman
    14L roughly.
  3. Steve Magnusson
    26,606
    One point is that the amount needed for the first fill from new and/or rebuilt, or "dry-to-wet" (this is what usually appears in the documentation) will be more than what can be removed during an oil & filter(s) change, "wet-to-wet".
  4. jww427
    jww427 Karting
    Oct 31, 2016
    148
    White Post Virginia
    john w. warner IV
    Just to be clear, thats 14 liters, yes?
    Check level when warm after 1/2 hour to let oil settle, yes?
    Thanks!
  5. John B
    John B Formula 3
    May 27, 2003
    1,564
    NJ
    I use 13 quarts w/ new filters, "wet to wet".
    Make sure to check the level in the dry sump hot when running.
  6. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,419
    romano schwabel
    NO NO ! ! !
    as john b has written:
    it is a dry sump, so only check oil level when engine is running
  7. Steve Magnusson
    26,606
    #7 Steve Magnusson, Jul 21, 2017
    This doesn't always apply to dry sumps depending on how the oil stream is being returned back into the oil tank (as, in some designs, the returning oil can splash oil onto the dipstick, or cause waviness in the oil level top surface, giving a false reading). The Boxer OMs indicate that the oil level should be checked a few seconds after warm engine shutoff (and a few minutes wouldn't matter much as not that much oil will run down thru the engine clearances, but I wouldn't wait 30 minutes).
  8. turbo-joe
    Apr 6, 2008
    9,419
    romano schwabel
    right steve
    but I always check during engine runs and between min. and max I think it is about 2 ltr., even more and so it makes not much difference if there is 1 ltr left or not.
    I only wanted to say that it is not ok to check after long time not running. because then the dipstick says nothing and when you fill up it may be ok, but when the engine runs the oil comes out of the reservoir - so happy cleaning then :)
  9. miurasv
    miurasv F1 World Champ
    Nov 19, 2008
    10,608
    Cardiff, UK
    Steven Robertson
    Just so that new owners of 365 Boxers know that the engine has a wet sump and not a dry sump as the 512 Boxers have.
  10. Newman
    Dec 26, 2001
    14,371
    Canada
    Newman
    yes
  11. Newman
    Dec 26, 2001
    14,371
    Canada
    Newman
    NO NO ! ! !
    Warm, shut off and check.
  12. turbo-joe
    Apr 6, 2008
    9,419
    romano schwabel
    my NO NO ! ! ! has referred to the 30 min waiting until checking
  13. Newman
    Dec 26, 2001
    14,371
    Canada
    Newman
    #13 Newman, Jul 22, 2017
  14. Steve Magnusson
    26,606
    True, but the OM instructions for checking the engine oil level for a 365 Boxer are the same as a 512 Boxer due to the not-insignificant volume of the oil cooler and lines.
  15. dwhite
    dwhite F1 Rookie
    #15 dwhite, Jul 22, 2017
    When I had my bbi apart last year and all the oil was out. When it was ready to restart the car, this is what I did: filled the filters before installing them, filled the tank to the full level which required between 12 -13 us quarts. Let it sit overnight. Cranked engine with coil wire off til oil pressure came up, then reconnected coil wire, fired and let run, set timing.
    Took car out for a drive couple days later, shut down after good 40 mile run let sit a couple mins and checked oil level. It was unnecessary to add any.
    Afterwards, I check after a long drive when it's fully warmed and everything is at operating temp and I only let it sit a couple mins. Never an issue, but I drive a bunch and I believe it helps with killing off condensation in the system. I don't use much oil at all.
  16. turbo-joe
    Apr 6, 2008
    9,419
    romano schwabel
    right
    and so I do always
    but I only put the pipstick in, never turn it and take it out again
    then I see at the lowest point how the level is
  17. jww427
    jww427 Karting
    Oct 31, 2016
    148
    White Post Virginia
    john w. warner IV
    Thanks for the advice.
    This is the reason my crew chief never let me near the race car...
    JWW
    STP anyone?
