512BB valve lift | FerrariChat
512BB valve lift
Discussion in 'Boxers/TR/M' started by simonc, Jul 12, 2023.
  1. simonc
    simonc Formula Junior
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
    Please, does anyone know what the valve lift is on the inlet and exhaust camshaft lobes on a 512BB? I cab't find this spec anywhere.
  2. samsaprunoff
    samsaprunoff F1 Rookie
    4,464
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Simon,
    Attached is taken from the 365 and 512 BB/BBi service manual. I could not find any specific references to which car the data is for and so I assume it is correct for all models. If not, perhaps one of the experts can chime in.
    Cheers,
    Sam
  3. Steve Magnusson
    26,826
    Never seen "40% PMS" nor "48% PMI" before for specifying a cam timing event -- any one know how to translate, or are those just typos ;)?
    turbo-joe likes this.
  4. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,540
    romano schwabel
    also never have seen this. valve timing is measured in degrees ( ° ) and not in %
    sorry, never have measured
  5. simonc
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
    #5 simonc, Jul 13, 2023
    Thanks Sam, I have that manual but all references in it relate to the 365BB unless labelled as 512BB. I am sure the 512 cams are different from the 365 cams, hence my question.
    Re the timing figures I think they have % sign instead of a degree sign. This diagram is also in the Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login WSM
  6. Steve Magnusson
    26,826
    Thanks, those figures do a lot to explain things, and I now get why PMS = TDC and PMI = BDC in Italiano -- with "S" = superiore = upper (top) and "I" = inferiores = lower (bottom).
  7. Rifledriver
    37,106
    Valve timing is different for each model.
  8. turbo-joe
    Apr 6, 2008
    9,540
    romano schwabel
    the main question has been not about the timing, it was about the valve lift and there in still no answer
  9. Rifledriver
    37,106
    Asked and answered. I knew they were very close to 9mm and thats what the only book on the subject says. The heads are nearly identical and the valves are identical. There would be no reason to change.
    The 365 had 66 degrees of overlap. the 512BB had 70 degrees and the BBi 22 degrees.
  10. turbo-joe
    Apr 6, 2008
    9,540
    romano schwabel
    the overlap says nothing about the valve lift
  11. samsaprunoff
    4,464
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Romano,
    You are taking the "%" symbol too literally. The document was no doubt (hand) typed at a time (pre desktop computers) where the user's typewriter did not have a degree symbol and so they use the "%" symbol instead.
    Cheers,
    Sam
    ingegnere and turbo-joe like this.
  12. samsaprunoff
    4,464
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Rifledriver,
    I knew this for valve timing, but was unsure about the lift.... e.g. if it was the same across the models or not. Sadly, my comment was not as specific as it should have been. That said, thanks for clarifying!
    Cheers,
    Sam
  13. Rifledriver
    37,106
    I am unaware of any Ferrari engine other than competition versions or a great many special ordered that ever used more than 9 mm lift. That naturally decreased when 4 valve heads were adopted.
  14. simonc
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
    I measured the valve lift on my 512BB cams tonight and it is 8.10mm on both the inlet and exhaust. I guess I’ll have to assume this correct.
    I’m in the middle of a full engine rebuild and was asking what lift should be so I can compare to my cams
  15. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,043
    Brian: In addition to the Tipo 130 Colombo competition camshaft, The 275 Two-Cam Tipo 213 camshaft also is 10 mm lift at the valve (less lash).
  16. Steve Magnusson
    26,826
    #16 Steve Magnusson, Jul 13, 2023
    Have you measured the intake duration and compared them to the intake duration values calculated from the BB512 OM and BBi512 OM cam timing specs? They are different:
    BB512 intake duration = 260 deg
    BBi512 intake duration = 244 deg
    (Exhaust duration is 244 deg on both, and what Sam posted must be 365BB as it doesn't match either on intake nor exhaust.)
    Wonder if you have BBi512 cams as that relatively lower intake lift (and less duration) is something that they did on the various K-Jet models (as K-Jet requires less overlap vs carburettors).
    turbo-joe and Ferraripilot like this.
  17. Rifledriver
    37,106
    Thanks Dwight. I have a little experience with both.
  18. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,852
    Atlanta
    John!
    That is what I'm thinking. I have only had one of these apart, an early 78, and the cams were the exact same spec as a 76-77 308 intake camshaft with about 9mm lift and 235 duration @ .050.
    Adding to this: I have now seen Daytona's with 2 camshaft specs now. One with 252 duration @ .050 and the other 235 @ .050, both with about the same lift, 9mm.
  19. simonc
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
    I will check the duration when the engine goes back together and report back.
