512BBi emergency window handle operation | FerrariChat
Discussion in 'Boxers/TR/M' started by rovexienus, Jan 13, 2021.
  1. rovexienus
    rovexienus Formula Junior
    564
    Sainte Colombe, France (near Lyon)
    Jean-Michel Savary
    I tried to operate the emergency window handle on my 512BBi. The mechanism appears to be stuck for both doors, I obviously did not try to force the handle. The windows are operating normally using the electric switches.
    Is there a special procedure I am not applying for this operation?
  2. Rifledriver
    34,117
    Austin TX
    You need to be sure the handle is pushed all the way in and it needs to be turned uncomfortably hard.
  3. pshoejberg
    pshoejberg Formula 3
    1,696
    Denmark
    Peter H
    I had same issue with my BBi and didn't dare to apply too much torque.....Then I started thinking if I ever will need this function. Have anyone ever operated their window(s) with the emergency crank?
    Best, Peter
  4. Rifledriver
    34,117
    Austin TX
    Yes. Many times.
  5. rovexienus
    564
    Jean-Michel Savary
    Thanks to all for your inputs, next time I visit the car, I will try again.
  6. Ludwig
    Ludwig Formula Junior
    Mar 27, 2006
    307
    Redmond WA
    Ludwig Allegra
    I ran into the same observation after completely rebuilding the motors and re-cabling. I really saw no reason to stress it and didn't try very hard.
  7. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    2,780
    Going from memory:
    The handle insertion acts on steel balls which act like a clutch throw-out mechanism to disengage the driven gear from the pulley for the cable. This requires uncomfortable force to push in the emergency crank handle. Then after inserted, the cranking of the emergency handle requires slightly less, but only slightly less uncomfortable force to turn imho.
    Doesn't help knowing that those parts are nylon, and breaking them makes dollar signs dance :oops:.
    Rifledriver likes this.
