News
512M 3000 RPM MISS
Discussion in 'Boxers/TR/M' started by HOU, Oct 5, 2009.
  1. HOU
    HOU Karting
    May 2, 2009
    87
    Houston, Texas
    John S
    i am starting a new thread. the other one is getting too long and also digressive.
    1. engine diagnotic codes for 1/6 are 4114 and 1111 and then they repeat and repeat. 4114 is Top Dead Center control. 1111 is hot wire airflow.
    2. codes for 7/12 are 1211 and 1121 and then they also repeat. 1211 is lamda regulation. 1121 is rpm sensor.
    3. i will look at the air flow meters first since they are easy access
    4. i will also order a set of NGK DCPR9EIX, if the Rifle driver approves. The Champion A-GC6s were installed at engine out service 1500 miles past (in 2008). I have not had good luck with Champion in the past and these plugs are out of date anyway. i usually try to put a bosch plug in if it is a bosch ignition which the M is.
  3. Melvok
    Melvok F1 World Champ
    Silver Subscribed Owner
    Jul 25, 2008
    13,289
    Amersfoort, Holland.
    Mel
    #2 Melvok, Oct 6, 2009
    HOU, how did you get these codes ?
    Your description gives me a picture like I described in the other thread: airflow meter, sensors....
    IMHO you don't need new plugs.....
  4. HOU
    HOU Karting
    May 2, 2009
    87
    Houston, Texas
    John S
    1. the check engine light for the bank tested flashes out a code when you push the test button on the ecu for 2 to 5 seconds.
    2. see fuel injection section, tab c in the service manual.
    3. i will remove, check, clean the 1/6 airflow meter tonight and see what happens.
    4. i do not like the Champion plugs and rationalize that plug technology today has surpassed 1995.
    5. i am hoping for a response from rifledriver on the NGK DCPREIX iridium
  5. Melvok
    Jul 25, 2008
    13,289
    Mel
    Kee, I will follow your info !
  6. HOU
    HOU Karting
    May 2, 2009
    87
    Houston, Texas
    John S
    1. i drove the car on two 20 minute trips yesterday. the 3000 rpm miss problem seems to have been solved, although the idle seemed to be a bit rough.
    here is what i did the previous night:
    2.removed the 1/6 air cleaner and box. removed the air flow meter.
    3. the air flow meter cable connectors had clean grease in them but it appeared to be dried out. i cleaned both with aersol contact cleaner. i cleaned the road grime from the meter, looked at the hot wire and temp sensor, and reassembled all.
    4. the rpm sensors for 1/6 and 7/12 are both located on the lower right cam very near the air flow meter so i decided to check and clean those connections. this was a deviation from my plan of one repair task and then test drive.
    5. after cleaning the area with solvent (it was very dirty), i noted a vacuum hose physically in contact with both sensor cables and pushing on the connectors. i rerouted the hose away from the cables. the conections looked good but i cleaned them anyway with the contact cleaner then reassembled everything.
    6. last night after the 2 successful test drives, i checked the error codes on the motronic 2.7 ecu(s). the same codes appeared as in my first reading before the fix. this was unexpected because i had erased the memory and the reset so only new codes would be stored.
  8. Melvok
    Jul 25, 2008
    13,289
    Mel
    #6 Melvok, Oct 8, 2009
    Thanx for the discription HOU, last part was dissapointment for you I guess...
    I get info soon from another TR (not 512TR) driver with Slow-Down problems which were solved just today...
    Will inform you when I have received this info.
    Any other driver with information /help on this topic ?
  9. Melvok
    Jul 25, 2008
    13,289
    Mel
    Whaaaauw... just seen the bill of the official F garage for solving this TR Slow-Down Lights problem .....
    All connectors cleaned, CO measuring, synchronising fuel injection system valves: Labour € 522,50
    Parts: Thermocouple ECU bank 7-12: € 523,60 and little parts € 16,00. In total 1.263,52 incl VAT.
    The problem is solved indeed.... but the driver is happy about that !
  10. HOU
    HOU Karting
    May 2, 2009
    87
    Houston, Texas
    John S
    1. yesterday after numerous drives and higher rpm blasts up the freeway on ramp, i am pleased to report the 512M is running great again. no missing and apparent full power.
    2. summarizing my previous report, the electrical connections on the air flow and rpm sensor were the problem. contact cleaner and the dissassembly/reassembly process solved the problem.
    3. this experience reconfirms my general feeling about older cars, the electronics are usually good. it is the corroded and resulting high resistance cable connections that cause the problems. most common example is the battery.
    4. i do yet not understand why the diagnostic codes are still present......maybe i did not perform the reset properly. will perform the battery disconnect reset and see what happens.
    thanks for all the responses..............
    js
  11. Melvok
    Jul 25, 2008
    13,289
    Mel
    Hi HOU,
    Is the fault reporting fixed now ?
  13. oldcoin
    oldcoin Formula Junior
    May 1, 2006
    258
    Reno NV
    Tony Mitchell
    I used to have a 96 XJ-12. I used the code reading tool to rest the check engine lights, but the old codes stayed stored for something like 20 to 30 start/shutdown cycles, then they went away
    Tony
  14. Melvok
    Jul 25, 2008
    13,289
    Mel
    Thanx Tony !
  15. Melvok
    Jul 25, 2008
    13,289
    Mel
    We replaced a 1211 code over here: 2 new lambda;s were installed.
    Problems are away...
