The new door seals i got from Kerry work great. They look the same to me as the ones that werre replaced. I had the installer relocate the joint to the lower front 90 degree bend. The previous location was adjacent to the upper shoulder belt anchor point. (very visible and a bit unsightly) the joint is now a tight butt joint at the lower front door which should be more durable. thanks Kerry.............
Can you post a pic please? I want to understand the joint relocation better. I'm about to try getting a set from him as well. Thanks!
