512TR Battery Group Size | FerrariChat
Discussion in 'Technical Q&A' started by Methos550, Jan 20, 2017.
  1. Methos550
    Methos550 Rookie
    Oct 20, 2005
    9
    I am Wondering as far as an Interstate replacement?
    Don't want to go with the Italian Cognitive Dissonance of Fiamm this time. Lol
    The Stock Part Number is #188066.
    Thanks All in Advance.
    Marc
  2. Keith360
    Keith360 Formula Junior
    Feb 6, 2015
    570
    Santa Barbara County
    Keith Williams
    Hi Marc, what are the dimensions of the battery? Label each dimension because height and width can be close in number. Also important is the terminal arrangement. Explaining the arrangement is needed because the are several configurations available. Side terminal (+) on left or right. Top post and configuration as viewed from what you call front and rear. Again post left or right. Also, there are really two vertical dimensions, one is the top of the case (to comply with battery hold down. The others is dimension is to the top of the post. That number is required to make sure the battery terminals don't meet some conductive to material.
    Lenght:
  3. Methos550
    Methos550 Rookie
    Oct 20, 2005
    9
    Well it is either the Interstate #MT-36R So Group 36R or the Mysterious Odyssey Odyssey 48-720 Battery (PC1220) so Group 48? Why such discrepancies in Group Size? I haven't had time to measure the battery Dimensions but I will. Thanks Keith.
  4. Motob
    Motob Formula 3
    Nov 11, 2003
    2,368
    Frederick, Maryland
    Brian Brown
    It should probably be an Interstate MT-34R not a 36r.
  5. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,665
    South East
    Jimmie
    There are several battery discussions in the 512/Boxer section which could have helped - often worth looking in the specific section first
  6. Methos550
    Methos550 Rookie
    Oct 20, 2005
    9
    Sorry Grey & Thanks.
