512TR Brake problem issue | FerrariChat
Discussion in 'Boxers/TR/M' started by 512cello, May 30, 2007.
  1. 512cello
    512cello Karting
    Apr 25, 2006
    145
    bree, belgium
    marcel
    I own a 512TR, 1994, Euro specs, ABS, 10.000 miles.
    Problem is following. At high speeds (+125) or at track days my car starts to shake heavily after applying brakes. Rotors are measured by the dealer and they say the rotors are o.k., pads are OEM and in good condition to, normal brake fluid just changed. What could cause this problem. On normal speed car brakes fine and never shakes. Could it still be the rotors, the pads, the fluid or maybe all 3? Why does it shake only when warm or high speed and never when cold and normal speed? Any input is appreciated.
    Marcel
  2. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    Does it shake while the brakes are being applied? Can you feel a pulsing in the steering wheel? What I am getting at is are the rotors slightly warped, and is the heat amplifying the problem. They may still be within spec thickness but warped. If so, you could have them turned for very little, assuming there is enough thickness.
    Just a thought.
  3. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,326
    Palos Verdes
    Vince V
    What they did not tell you is if the rotors were warped. Having the correct thickness is not this problem. It sound very much like warped rotors. Also, very old brake pads might contribute to this. Sometimes I think faulty suspension parts can be to blame, but I'd go with rotors first.
  4. 512cello
    512cello Karting
    Apr 25, 2006
    145
    bree, belgium
    marcel
    The 512 shakes when the brakes are applied! I can feel a pulsing in the steering wheel and also in the brake pedal. Reading your feedback i agree to think they must be warped!
  5. WILLIAM H
    WILLIAM H Three Time F1 World Champ
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    You REALLY need to upgrade if you are doing track days bcus the stock brakes are Not up to it & parts are retardedly expensive & poor quality
    At the least get new race rotors & pads from porterfield, you can use these on the road as well w no problem
    If you want to get really serious get the Brembo F50 kit but you'll need new wheels bcus the front rotors wont clear stock wheels w Brembos on
  6. MS250
    MS250 Two Time F1 World Champ
    Dec 10, 2003
    26,576
    Avvocato
    look for the following :
    1)Weight for the wheels may have come off therefore affecting the balancing of the tire.
    2) Weak ball joint(s)
    3) Broken or nearly broken upper control arm
    4) A shock/Shocks
  7. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,450
    Canada
    Newman
    Actually Rotor thickness variation causes the biggest pulsation. I agree they need to be machined/ground or replaced depending on your preference. If you were to measure the rotor thickenss at various locations you will find it varies and this variation will force the caliper piston to follow the uneven surface.
  8. 512cello
    512cello Karting
    Apr 25, 2006
    145
    bree, belgium
    marcel
    Wheel balance is fine, just had them balanced (all 4) and this didn't help.
    Ball joints checked and seem o.k.
    Upper arm controls look o.k. to, had the left rear lower control arm replaced because of corrosion and the metal was cracking!
    Shocks are o.k. to.
    I came to the conclusion that the rotors must be warped.
    Will change all rotors and pads, read some previous threads about porterfield brake upgrade and will try following.
    4 new rotors, street/race pads front, race pads rear.
    Thanks for all the help, my dealer didn't figure this out after i brought it in 3 times! He kept saying everything is o.k., pherhaps time to look for another F-dealer with good mechanics!!!
  9. 512cello
    512cello Karting
    Apr 25, 2006
    145
    bree, belgium
    marcel
    #9 512cello, May 31, 2007
  10. uzz32soarer
    uzz32soarer F1 Rookie
    Sep 9, 2006
    3,090
    Melbourne, Australia
    Robert Hayden
    You have hot spots in your rotors.
    Both my 88 Testarossa's suffered from the same problems.
    For a recent track day I had the rotors machined and flattened the pads for the event. Car braked well from speeds close to 280, but after three or four hard stops I got bad brake fade.
    Once the rotors were machined the shuddering went away, but the brakes are crap for even moderate track day usage.
    Not wanting to spend the big bucks just yet, I will be taking the first stage upgrade path.
    New original Brembo rotors have been sourced and will be sent out to be radial slotted and then cryogenically treated (spelling?)
    I am going to try EPC Red Stuff Ceramic compund pads as these have worked well for me before on both street / race applications on other heavy cars.
    Braided brake lines to be fitted and the system flushed and then filled with Castrol SRF fluid.
    This should dramatically improve the braking under extreme conditions. Once I can outdrive this setup, then big F40/F50 Brembo's or AP's will have to go on.
  11. WILLIAM H
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    While you are at it, if you continue w track events you will want to install an aftermarket oil cooler as the oil warms up very fast when car is pused hard, also some racing harnesses would be good
  12. Animate
    Animate Formula Junior
    May 21, 2004
    275
    BC,Canada
    William H: What have you managed to get the weight of your track car down to?
  13. WILLIAM H
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    still working on it, I have a new engine which I will rebuild normally aspirated full race, looking for 800 hp :) w the Penske shocks & that engine I should be able to run w Porsche 962s :)
    Next year
  14. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,699
    wisconsin/chicago
    bo
    A little bit off track here, but:
    Are porterfield pads that much different than other pads? My porsche has mintex pads, and the brakes are hard to lock up at speed (no power braking). Would switching to porterfield pads be a significant upgrade in friction/stopping power, or is it more of a "fade" preventative?
    Bo
  15. 512cello
    512cello Karting
    Apr 25, 2006
    145
    bree, belgium
    marcel
    Send 2 mails to porterfield but no reply? Guess i need to look for substitute, any suggestions?
  16. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    I have porterfield pads on my 512 (no ABS). I have both road pads (R4S) and track pads (R4). I can lock the brakes with both, no problem. I have had the car on track once, and I put the pads on for fade resistance. I probably would have been OK with street pads, because I didn't push them very hard. But the track pads worked well, though they squeal like crazy just driving around.
    I got mine from Ricambi (www.ricambiamerica.com).
    I don't think they are some vast difference from any other good aftermarket pad, but they work as promised and are priced well.
  17. ajimbo
    ajimbo Karting
    Feb 27, 2007
    139
    Kelowna BC Canada
    A Jimbo
    Wheel bearings most likely.
  18. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    I had this problem on my 91 Testa. (series II discs ) At higher speeds applying the brakes lightly, they would vibrate and shake the steering wheel. If you stomped on the brakes, no reeeal vibrations.
    In my case it was definately warped rotors. I had the "warped" pair machined and they came out true. But....after applying the brakes and with heating, the rotors still had the "memory" and would warp. After a new pair, the problem was completely gone.
    Shamile
    Freeze...Miami Vice !
  19. 512cello
    512cello Karting
    Apr 25, 2006
    145
    bree, belgium
    marcel
    Did you just replaced the front rotors or all?
  20. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Didn't know if you were asking your question to me? I only replaced the front rotors as those were the only ones that were warped. The rear discs don't really do much work so don't really heat up much. After a week of driving, take a look at how much brake dust is on the front wheels compared to the rears.
    Shamile
    Freeze..Miami Vice !
  21. ajimbo
    ajimbo Karting
    Feb 27, 2007
    139
    Kelowna BC Canada
    A Jimbo
    again. I would check the wheel bearings for wear. Checking for wear is easy. lift it, wiggle on the wheel, and if there is play, replace them. :)
    This often happens, but people seems to overlook. It's not always the disks. Yes, disks do cause that, but from my experience, wheel bearings seem to cause this more and people don't think about it. On a heavy car like V12 Ferraris, I would say there is a good chance.
    I deal with races cars all the time, and they do have that same issue, so, I am almost sure that is the case for your car, too.
  22. 512cello
    512cello Karting
    Apr 25, 2006
    145
    bree, belgium
    marcel
    Will check disks and wheel bearings in about three weeks. Will inform via this thread what it was exactly. Thanks everyone for the good advice, always feels good when people know the solution for you problems.
  23. vlamgat
    vlamgat Formula Junior
    Jan 9, 2004
    776
    I second this comment. But this type of wheel bearing wear is more common on track and race cars. However since most F-cars are not driven regularly wheel bearings also deform from carrying the weight on one spot for a long time thus further supporting this theory.
    But I would still replace the rotors because the TR brakes are so inadequate for track usage so the rotor warp just has to be the most likely cause.
  24. 512cello
    512cello Karting
    Apr 25, 2006
    145
    bree, belgium
    marcel
    Had the rotors machined, they were warped and will try on a track day tomorrow first with normal brake pads, then after some sessions with pagid blue. I am curious to find out if this was the cause of pulsing when applying the brakes. Second i am curious to find out if i can feel and notice the differences in the brake pads. Didn´t check the bearings yet but i will tomorrow. Will inform you.
  25. 512cello
    512cello Karting
    Apr 25, 2006
    145
    bree, belgium
    marcel
    Did a track day, was bs! When warm and applying brakes still pulsing in the steering wheel. Changing pads no different, problem still there. Have to change rotors now, didn't check the bearing but will do next week.
