512tr broken diff ! | Page 3 | FerrariChat
512tr broken diff !
Discussion in 'Boxers/TR/M' started by bazzis, Nov 9, 2013.
  1. g4titan
    g4titan Formula 3
    Feb 6, 2010
    1,196
    Around
    Nico
    Does this require a whole engine drop?
  2. ago car nut
    ago car nut F1 Veteran
    5,553
    Madison Ohio
    David A.
    Jaguar 15, check your PM mailbox.
    Ago
  3. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,554
    Canada
    Newman
    No it doesn't but its not easy in chassis either, one I sold for a testarossa was done in the car. The rest were yanked to do the swap.
  4. g4titan
    g4titan Formula 3
    Feb 6, 2010
    1,196
    Around
    Nico
    Thanks! I'm considering nabbing a 512TR the engine was already out for the service but the diff was never done... and I'm debating my next move.
  5. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    Paul just told me they are not $2000 as I stated earlier. It was my mistake. I told him to put my name on the next run as he is already soldout. Paul and Philwozza are about the same price and cheaper than Modena from what I've read.
  6. qwazipsycho
    qwazipsycho Formula 3
    Oct 30, 2004
    1,176
    Utah
    Scott
    You can have mine. I only want $3000 for it. :D
  7. bazzis
    bazzis Karting
    Nov 5, 2003
    217
    Sarratt, Herts
    ferrari charge about £3.300 for the diff, then the bearings are around £200 for the pair, then shims and bits so with 20% sales tax around £4k for parts ....this is for the 512m diff.
  8. Jaguar 15
    Jaguar 15 Formula 3
    Mar 27, 2013
    1,837
    Hunt. Bch/Palm Dsrt/Virginia
    Jim Crawford
    Thanks for the info guys. I understand you should definitely change the side cover also which bumps the price higher. Still looking for a broken one you don't want...
    Qwasi--I already have an $8,000 piece of art hanging on a wall that I framed in 1988. It is a twisted connecting rod and piston from a Maserati Merak that blew up one day after a moron in Hermosa Beach adjusted the timing chain. He was supposed to be a Lambo/Maser/Ferrari expert. Yeah...right.
  9. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,296
    Mel
    "Paul and Philwozza are about the same price"
    That"s correct but only in Phils version all internals are brand new also ...
  10. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,663
    romano schwabel
    #60 turbo-joe, Nov 13, 2013
    all internals in the MODENA are also brand new - and all selfmade by them
    so nothing against all the other diffs. I´m sure they are also more than fine, but I only have own experiences with the MODENA and I could only say good things of this part
    oh. I just see: this is my post no. 1000
    so thank you again to the unknown sponsor who gave me a silver membership :) :) :)
  11. Jaguar 15
    Jaguar 15 Formula 3
    Mar 27, 2013
    1,837
    Jim Crawford
    By "internals" what does that mean exactly.....Direct swithch out?
  12. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    Jaguar 15, the Forza diff carrier is complete including all the internal gears and "silent" clutch plates. The diff is therefore a drop in replacement.
  13. Jaguar 15
    Jaguar 15 Formula 3
    Mar 27, 2013
    1,837
    Jim Crawford
    Thanks Phil....I'm slow but I'm beginning to get your point. All the "junk" inside is included which is indeed nicer than mixing and matching parts.
  14. Melvok
    Jul 25, 2008
    14,296
    Mel
    #64 Melvok, Nov 13, 2013
  15. turbo-joe
    Apr 6, 2008
    9,663
    romano schwabel
    #65 turbo-joe, Nov 13, 2013
  16. ozziindaus
    ozziindaus F1 Veteran
    Aug 16, 2012
    9,799
    Detroit
    Sam
    From the pics above, the failure mode appears to be caused by the weld failure rather than the parent material. In some places, the parent material sheared but more often the weld itself. This is a sign of poor welding parameters, techniques, contamination during welding, inadequate weld cross section at shear line or poor choice of filler material.
    Inclusions or solidification cracking is usually the culprit off the bat. Inclusions are usually cause by contamination such as grease during welding and solidification cracking is usually caused by incorrect material selection or excessive gap during weld.
    Having said that, has anyone investigated simply re-welding the diff......before failure of course?
  17. turbo-joe
    Apr 6, 2008
    9,663
    romano schwabel
    who would weld a new diff or even a used diff again when it looks fine?
    but to try to weld a broken diff would be interesting to see what will happen
  18. Melvok
    Jul 25, 2008
    14,296
    Mel
    Don't give crooks clues ... they may even think about it when they have a broken gb ....
    But in most cases there will be more damage, f.i. the C & P ...
  19. ago car nut
    5,553
    Madison Ohio
    David A.
    I agree with Sam on the welding. Not that I would attempt to weld a good diff. But there is a lot of truth in what he is saying.
    Ago
  20. tbakowsky
    Sep 18, 2002
    20,083
    The Cold North
    Tom
    Maybe we should merge all these diff threads into one, and make it a stickie with a poll.
    The thread I started I requested it to be closed..too many going saying the same thing.
  21. turbo-joe
    Apr 6, 2008
    9,663
    romano schwabel
    good idea howie
    also I would suggest to have an easier overview that we may have two diff threads:
    one for the writing and a second one only ( ONLY ) for pictures to see what happenend to each diff ???
    any other idea someone?
  22. boxerman
    boxerman Two Time F1 World Champ
    20,008
    FL
    Sean
    seems like a great idea
  23. ozziindaus
    Aug 16, 2012
    9,799
    Detroit
    Sam
    Simple. If the chances of a welded diff failing is low, then don't change it, but if the chance was high, then why not reinforce it.
  24. canamlotus
    canamlotus Rookie
    Nov 29, 2013
    3
    Paul;
    What is the right way to check?
  25. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    Hey everyone,
    How can I go about getting one of these carriers so my 87 TR doesn't become a member of the 'broken differential' club? :)
