512TR Center Console Removal | FerrariChat
Discussion in 'Boxers/TR/M' started by GreigM, Jan 13, 2012.
  1. GreigM
    GreigM Rookie
    Jun 18, 2007
    47
    Hamilton, Scotland
    I'm trying to install a Hill Engineering Slick Shift to my 512TR, and it seems I need to remove the forward switch panel in order to remove and install the gate.
    However the right hand side top (where the AC buttons are) doesn't simply lift out, and I don't want to force it, so can anyone tell me if there are any screws/clips etc I need to remove to loosen the panel?
  2. dontilgon
    dontilgon Formula Junior
    May 30, 2011
    332
    NY/PA
    Joseph
    Start from back to front with removal on the front console. There is a Allen bolt in the center holding the rear box down, then same with the middle piece. Now you should see 2 screws holding the front console in place. Take the ashtray out .Thats all for screws. There nothin else holding the console in place. Be very careful when pulling this up. They crack very easily especially on the sides of the ashtray.It does take a bit of jiggling and don,t forget you have alot of wiring holding it down.
    EZORED likes this.
  3. GreigM
    GreigM Rookie
    Jun 18, 2007
    47
    Hamilton, Scotland
    Thats great, thanks - saves me breaking anything!
  4. kerrywittig
    kerrywittig Formula 3
    1,668
    Ithaca, New York
    Kerry David Wittig
    #4 kerrywittig, Jan 13, 2012
  5. vlamgat
    vlamgat Formula Junior
    Jan 9, 2004
    776
    I too have the same challenge. It's the 2 screws that elude me. Close to or below which control should I be looking?
  6. GreigM
    GreigM Rookie
    Jun 18, 2007
    47
    Hamilton, Scotland
    I got it done today - really very easy - the two screws are at the rear of the front panel (close to the hazard warning switch), but you must remove the rear section to access them - once you have them out the whole front section simply lifts out from back to front.
  7. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,248
    Mel
    Photo above is of the Testarossa version I believe....
    Can you please place some pics here of yours (hope: 512TR version) GreigM ?
    I have a 512TR and would like to see the view of it .
    Or PM me for pics please...
  8. GreigM
    GreigM Rookie
    Jun 18, 2007
    47
    Hamilton, Scotland
    #8 GreigM, Jan 17, 2012
  9. vlamgat
    Jan 9, 2004
    776
    Many thanks
  10. tvu
    tvu Formula 3
    1,351
    Southern California
    Trieu
    Whoa - you have the cassette adapter option? I've never seen that before!
  11. ants2au
    ants2au Formula Junior
    Nov 19, 2003
    792
    Sydney Australia
    Anthony
    I thought they were normal option. I have it on mine as well.
  12. GreigM
    GreigM Rookie
    Jun 18, 2007
    47
    Hamilton, Scotland
    I think all European cars came like that? I'd like to get rid of it however - is there a replacement available?
  13. vlamgat
    Jan 9, 2004
    776
    Thanks for that. I found those screws. They are horizontally set up to grip the plastic tongues of the front plastic console trim. However my front trim remains firmly attached at the front, adjacent to the shift gate. The driver side of that piece seems not to be fixed to anything and sits loosely ontop of the shift gate. But the passenger side is tightly held against the leather edge of the console as if it has another retaining screw. Does it? I have not seen anything that indicates there is anything retaining this front piece of plastic to the console.
    Any suggestions?
  14. GreigM
    GreigM Rookie
    Jun 18, 2007
    47
    Hamilton, Scotland
    If I remember correctly the panel is clipped in at the front and had to be lifted from the rear then slid backwards to release. There definitely was no other permanent fittings (i.e. screws) involved. I suppose it could be glued/stuck down somehow, so maybe get a thin piece of metal under the plastic and see if you can ease it off.
    Whatever you do be careful, I believe this plastic can be brittle.
  15. vlamgat
    Jan 9, 2004
    776
    Thanks. I have already cracked the fram that surrounds the shift gate !#$%# So some super glue welding has to be done. I suspect mine got installed with the entire console out of the car and thus has something extra nailing down that front passenger side corner. Your insight has been so helpful - sure appreciate it as its impossible to see anything and the W/S manual and IPC are silent on the install except to show it as a single sheet.
  16. Zxgarage
    Zxgarage Formula Junior
    638
    MD/ DC area
    Zack
    Me 2 , for my 86 TR.
  17. Melvok
    Jul 25, 2008
    14,248
    Mel
    #17 Melvok, Jan 23, 2012
  18. vlamgat
    Jan 9, 2004
    776
    Thanks for posting those. For me at least, it's the piece in front that I would like to see removed. Something holds them in very definitely in their north east corner.
  19. Silber
    Silber Karting
    Jun 6, 2014
    119
    Switzerland
    Hi All
    Bringing this thread back to life as I sit here with sticky goo all over my hands... How does the the cubby section between the seats come out? The piece that once removed reveals the two screws that need removing.
    Thanks very much
  20. surfitscu
    surfitscu Rookie
    Oct 28, 2015
    4
    morgam hill, CA 9503
    john
    Does anyone know of a resource for the plastic trim that holds the. Emergency button, glove box switch and the round power outlet
    For a 512TR
    john
  21. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,416
    romano schwabel
    what you understand under "emergency buttom" ?
    photo please
  22. lagunacc
    lagunacc F1 Rookie
    4,091
    It's one piece
  23. Doc Chaz
    Doc Chaz Karting
    Mar 27, 2014
    117
    west of Fresno, CA
    An ashtray? That's interesting, and one has a lid with the crossed flags dating back to the 1950s.
  24. rumen1
    rumen1 Formula 3
    Jun 23, 2012
    1,814
    Bulgaria
    Red Bay Cars have such stuff from time to time, not sure if they have it available at the moment, but worth checking.
