512TR Engine Compartment Release Cable | FerrariChat
Discussion in 'Technical Q&A' started by 94 512TR, Sep 12, 2006.
  1. 94 512TR
    94 512TR Rookie
    Jan 10, 2006
    41
    Houston, TX
    John Glover
    #1 94 512TR, Sep 12, 2006
    I am in the process of replacing the rear engine release cable on my 512TR. I was pulling the new cable through the firewall area with anticipated success but the duct tape connection between the old and new cable failed. In retrospect, I should have crimped the actual inner wire cables together.
    I am now finding it necessary to remove the trim panel in front of the seat belt actuators. I am hoping this will enable me to pass the new cable through the firewall. I
    have removed two small screws holding the lower portion to the car. The top portion appears to be anchored to both the trim piece parallel to the rear side window and also to the large door frame trim piece.
    Does anyone have experience in removing this trim piece? Also, is there any better way to approach this installation?
    Thanks in advance,
  2. jungathart
    jungathart Guest
    Jun 11, 2004
    3,376
    NoVA, AmeriKa
    Komrade Jung
    When I had to do this, I left the sheath in place and merely swapped out the inner cable itself. Can you still do this, or did you pull out the sheath as well?
    Best wishes otherwise.:)
  3. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Thats the easiest way to go about I think also. :)
  4. Rifledriver
    37,106
    What they said.
  5. Kds
    Kds F1 World Champ
    I just did this on my car like they said.......I bought a $2.00 piece bicycle cable and threaded it thru.......works perfectly.
  6. 94 512TR
    94 512TR Rookie
    Jan 10, 2006
    41
    Houston, TX
    John Glover
    Thanks for the replies.
    I need to start riding my bike more often and ask more question here.
    Unfortunately, the sheath pulled through.
    So I am going to have to do it the hard way.
    Does anyone know how to remove the trim piece in the picture?
    I assume it is the same procedure if one wanted to remove the seat belt mechanism behind the trim panel.
    It appears that by removing the seat belt actuator I will have access.
