512TR engine out | FerrariChat
512TR engine out
Discussion in 'Technical Q&A' started by surfitscu, Oct 29, 2015.
  1. surfitscu
    surfitscu Rookie
    Oct 28, 2015
    4
    morgam hill, CA 9503
    john
    other than the cam belts, seals, cam angles, water pump rebuild, alternator rebuild/check, clutch check/replacewhat else should be done?
    Is it smart to pull and permantely remove the two thermostats?
  2. Rifledriver
    37,104
    Why on earth would you want to remove a thermostat? They are there for a very good reason, leave them.
  3. Steve Magnusson
    BANNED Lifetime Rossa
    26,822
    (To put a few more words of explanation around Brian's comment) The thermostat in a 512TR is not a simple 2-way (open or closed) valve -- it is a 3-way valve that closes one path and opens another. See the figure on page B76 in the 512TR WSM for a diagram of the two (separate) flow paths. If the thermostat is left out completely, coolant will just mostly recirculate within the engine and will overheat (i.e., the path the thermostat blocks when warm forces the coolant to flow thru the radiators).
  4. radlu
    radlu Formula Junior
    Jun 6, 2005
    424
  5. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,217
    Georgia
    Wade Williams
    Yeah, what he said !
  6. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Welcome to the forum John. :)
    No, please do not remove the thermostats. :D
