512TR front fog light housing | FerrariChat
Discussion in 'Boxers/TR/M' started by JIMBO, Oct 13, 2021.
  1. JIMBO
    JIMBO Formula 3
    1,357
    Bradenton, Florida
    Jim DeRespino
    Just got finished washing the 1994 512TR and I noticed the LH front fog/directional light was hanging a bit forward. Upon closer inspection the plastic that holds the threaded clips into which the two 10 mm pins screw (from the center of the bumper) had disintegrated. Are these housings available anywhere or am I going to have to create a repair out of epoxy and imagination? The plastic is starting to disintegrate. I will post photos when the I-Cloud downloads them to this computer.
  2. Zeff
    Zeff Formula Junior
    Oct 8, 2018
    692
    Cupertino, Ca
    Ryan
    Scuderiacarparts.com looks like they might have that part. Check with them to see.
  3. JIMBO
    JIMBO Formula 3
    1,357
    Bradenton, Florida
    Jim DeRespino
    Thanks, Zeff, but at $1,300+, I'll try to repair the original first.
  4. MM355
    MM355 Formula 3
    Apr 7, 2008
    1,152
    GMT + 3
    Buy whatever is available for peace of mind in the future, its good to have stock for whenever you might require them.
  5. Willdief
    Willdief Karting
    Oct 31, 2003
    189
    Mercer Island, WA
    Will Diefenbach
    Jimbo - I had a similar problem with one of the fog lights on my '92 512TR. I kind of ignored the loosening mounting points for years and wound up ejecting the housing and running over it after a sudden stop. I wrote an article for Prancing Horse about the experience in 2014. I can send you the text if you'd like. I wound up having the casing repaired by a company that specializes in polymers and auto lenses called Squadra Nuvolari. And if you were able to find a US spec replacement for $1,300 I would snap it up! It shouldn't be difficult to repair the attachment points, though. Squadra Nuvolari also replaced the lenses on both units with factory looking ones as mine had become pitted and hazy.
    Best,
    Will
  6. JIMBO
    JIMBO Formula 3
    1,357
    Bradenton, Florida
    Jim DeRespino
    Thanks for the advice, Will. Yes, please send me the text.
  7. JIMBO
    JIMBO Formula 3
    1,357
    Bradenton, Florida
    Jim DeRespino
  8. JIMBO
    JIMBO Formula 3
    1,357
    Bradenton, Florida
    Jim DeRespino
    The replacement fog light assembly is "not available", so repair is the only option.
  9. JIMBO
    JIMBO Formula 3
    1,357
    Bradenton, Florida
    Jim DeRespino
    If anyone is interested, I first cleaned the entire area to be repaired with a dremel and a tiny wire wheel and some lacquer thinner. I then took a piece of this metal strapping and bent it to re-approximate the original broken plastic. 2 small screws will hold it in place along with the epoxy. Image Unavailable, Please Login Image Unavailable, Please Login
  10. JIMBO
    JIMBO Formula 3
    1,357
    Bradenton, Florida
    Jim DeRespino
    A trial fit on the car confirmed no obvious interference issues. The center of the straps was opened up and the cage nuts attached, after which the whole shebang was secured with Marine Tex. Like JB Weld, this is a structural 2-part epoxy that adheres well to plastic. The final result should be very strong. More pics tomorrow after full cure.
    EZORED likes this.
  11. EZORED
    EZORED Formula 3
    1,034
    Scottsdale, AZ
    Dennis
    Had to do similar repair on my 512 tr. A PIA but effective. I used JB Weld
  12. JIMBO
    JIMBO Formula 3
    1,357
    Bradenton, Florida
    Jim DeRespino
  13. radlu
    radlu Formula Junior
    Jun 6, 2005
    424
    Strong work!
  14. Willdief
    Willdief Karting
    Oct 31, 2003
    189
    Mercer Island, WA
    Will Diefenbach
    Excellent job, Jimbo! Sorry for slow response - I haven't logged in for a few days. Here's that article and with photos of the repair. Cheers
  15. JIMBO
    JIMBO Formula 3
    1,357
    Bradenton, Florida
    Jim DeRespino
    Thanks, Will. I may purchase a set of Squadra Nuvolari's fog light lenses in case one of mine gets broken.
