512TR FRONT ground clearance | FerrariChat
Discussion in 'Boxers/TR/M' started by simonetrb, Dec 5, 2012.
  1. simonetrb
    simonetrb Rookie
    Dec 5, 2012
    22
    S.Benedetto Tr ITALY
    Simone
    Hello everybody!
    I'm Finally deciding to buy one...
    ...wonderful red 1992 512TR.
    But the problem is the ramp to go down in the garage.
    Do anybody knows (or could measure) the height of the very front end lip spoiler of the car?
    I will be very thankful!
    bye
    Simone
  2. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    Congratulations, we can't wait to hear/see more about it. I don't have a 512TR so someone else will have to weigh-in on your request. There could be minor variables based on wheels/tires/springs. Does your 512TR have stock 18" wheels with 235/40 ZR 18 & 295/35 ZR 18 tires?
    Height is definitely a factor but exacerbated by how far the nose extends past the front wheels. Thats my issue with my TR and driveway. The street to the sidewalk is OK but my driveway to the sidewalk is too steep so I scrape almost every time. Approaching at an angle can help but not always possible with other cars in driveway. There are commercial solutions (check Griot's Garage for example) available, or build a transition ramp, or others have poured concrete.
    I had 512TR 18" wheels/tires on my TR and when I went back to 16" TR wheels/tires I lost ~1/4" of clearance :( :( :(
  3. Melvok
    Melvok F1 World Champ Owner Silver Subscribed
    Jul 25, 2008
    14,268
    Mel
  4. simonetrb
    simonetrb Rookie
    Dec 5, 2012
    22
    Simone
    so you mean that stock is 9 cm?
    I read on web that the lowest point was 124 mm, and the front lip semt in higher position...
    Need to know about the stock one...
    thank you
    Simone
  5. simonetrb
    simonetrb Rookie
    Dec 5, 2012
    22
    Simone
    nice the partlist with prices...
    any link??
  6. Melvok
    Jul 25, 2008
    14,268
    Mel
    This list was from Ricambi USA ...
    They seem to be a little cheaper in U.K. but don't forget P&P + shipping ...
    For us all: please introduce yourself ... where do you live, married ? ... etc... f.i. I live in The Netherlands ... ;)
  7. simonetrb
    simonetrb Rookie
    Dec 5, 2012
    22
    Simone
    nice but the website seems to work badly now...
  8. BlackTesta
    BlackTesta Karting
    Feb 24, 2012
    173
    Germany
    Sebastian Fischer
    Well, the 512TR has height adjustable coilovers - it´s very easy to lift it a little...
  9. simonetrb
    simonetrb Rookie
    Dec 5, 2012
    22
    Simone
    thank you, i knew about that, but a little couldn't be enough...
    anybody wants to measure???
  10. JoeZaff
    JoeZaff F1 Veteran Owner
    Aug 5, 2007
    5,459
    Philly suburbs
    Joe
    As somebody else pointed out, its not the ground clearance as much as it is how far the nose extends past the front wheels.
    its the type of car that can crash into road crowning as you exit a driveway! You have to be far more mindful of where the front lip is rather than static ground clearance. If you have a driveway that happens to be at an incline in relation to the road, it could mean trouble.
    FWIW, I have really bad OCD and avoiding scuffing that bumper is a major PITA. When we were looking for a new home, much to my wife's chagrin, many a beautiful house was rejected because it wasn't Testarossa friendly :)
  11. tvu
    tvu Formula 3 Silver Subscribed
    Apr 13, 2004
    1,362
    Southern California
    Trieu
    16.4 cm
  12. UpNorth
    UpNorth Formula 3 Owner
    Sep 30, 2006
    1,769
    Quebec, Canada
    Francois
    I use snowplower base plate. They are made to sustain scraping on alsphat winter long. So I use small parts that I have screwed under the front spoiler at each corner. I hear that scraping sound but I know its on something REALLY tough and that can be change easily and cheap.
  13. simonetrb
    simonetrb Rookie
    Dec 5, 2012
    22
    Simone
    THANK YOU!
    Is that stock or with coilovers full high?
  14. simonetrb
    simonetrb Rookie
    Dec 5, 2012
    22
    Simone
    Yes but the nose extension is written on the user manual as 1095mm, so I hai that info.
    The 2 combined are useful to determine the minus angle necessary for Car's safety
  15. RedFlyer512TR
    RedFlyer512TR Formula Junior
    Dec 13, 2011
    386
    Columbus, OH
    Timothy
    I look for the flattest way to exit when fueling and parking. Sometimes those pesky concrete poles next to the fuel pumps will get whacked by my door if I don't pull up just enough to clear it. Sometimes they are painted white so they blend in with the surroundings. I have almost hit one and I really try to slow myself down and make sure I can open the door all the way.
  16. HOU
    HOU Karting
    May 2, 2009
    90
    Houston, Texas
    John S
    150 mm for my 512M. seems to be workable as i do not scrape very often and it gets on the lift with minimum problems
