512TR problem........ | FerrariChat
Discussion in 'Boxers/TR/M' started by bazzis, Apr 29, 2005.
  1. bazzis
    bazzis Karting
    Nov 5, 2003
    217
    Sarratt, Herts
    I have a Euro spec early 512TR, it has had cats removed and Tubi test pipes fitted,both thermocouple and oxy sensors are connected to the test pipes. Problem is the 1-6 test light keeps flashing on and off which seems to cut the engine out, there is also a 'chattering' sound which seems to come from behind the drivers seat(RHD) in time with the dash warning lamp,could be a relay cutting in and out, or some sort of switch. Has anyone had a similar problem?? I could live with the warning lights,but not the engine dying.!! many thanks.
  2. WILLIAM H
    WILLIAM H Three Time F1 World Champ
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    I had a simalair problem but it went away quickly. Have your mechanic check the switch behind the ignition in the dash. Check the O2 sensors also.
    Have you ever replaced the printed circuit board ? Might have to do that too
  3. Steve Magnusson
    BANNED Lifetime Rossa
    26,822
    bazzis -- When you say "1-6 test light" do you mean the "SLOW DOWN 1-6 CYL" light or the "CHECK ENGINE 1-6 CYL" light?
  4. steve f
    steve f F1 World Champ
    Mar 15, 2004
    12,119
    12cylinder town
    steve
    the ECU'S are behind the drivers seat on a rhd car well they are on a f512m cant see there being any difference
  5. RUFRUF
    RUFRUF Rookie
    Apr 28, 2005
    28
    So. Ca.
    Marco
    I had the same issue with my 512M and come to be that the spark plug wires were loose, check to make sure they are all clicked in also check your gas cap that by being loose in might triger the sensors. Finally, I took off my spark plug wires to check them and a few of them were faulty. I replaced them with aftermarket ones. Let me know if you need the name of the manufacture....the car runs like new now.
    Hope this helps my friend.
  6. WILLIAM H
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    I need the name, which wires did you use ? what model # ? Thanks
  7. bazzis
    bazzis Karting
    Nov 5, 2003
    217
    Sarratt, Herts
    Thanks for all your imput, found the problem!! it was a combination of multi pin plugs on the right hand bank (1-6) of the engine,the ones that are around the spark plug leads, needing to be cleaned and fitted properly, many thanks............
  8. ExcelsiorZ
    ExcelsiorZ Formula 3
    1,267
    Beverly Hills
    A Euro spec 512, Nice! Better lamps and no motorized seat belts! Color?
  9. bazzis
    bazzis Karting
    Nov 5, 2003
    217
    Sarratt, Herts
    Rosso with crema trim, best ferrari I've ever had, six years now with,touch wood, no problems, two cambelt services, tyres, brake pads, thats it,even has the same battery !! 12,000 miles in that time, what more could anyone want.................
