512tr radiator cap: long or short neck | FerrariChat
Discussion in 'Boxers/TR/M' started by ants2au, Jun 4, 2023.
  1. ants2au
    ants2au Formula Junior
    Nov 19, 2003
    793
    Sydney Australia
    Anthony
    in the fiat world, there is concept of long and short neck radiator caps.
    now I have checked the one on the 512, and it currently has a short style cap.
    I think it is incorrect.
    I checked my 124 sport, and the depth in the header neck is the same as the one on the 512,
    the 124 uses the long neck style cap.
    just wanted to confirm before I change the cap on the 512.
    the short style is the usually the generic caps you get at auto part stores (not that that is what is on the 512).
    it was more for visualisation :)
    also can someone confirm that it is a 0.9 Bar (13PSI) please.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,727
    Central NJ
    Dominick
    I spent a lot of time researching and don't even remember what I researched now .. but I ended up getting a 10230 cap from Stant
    That was 16 PSI
  3. ants2au
    Nov 19, 2003
    793
    Sydney Australia
    Anthony
    the WSM states 0.9Bar though... 16PSI is quite a difference.
  4. ants2au
    Nov 19, 2003
    793
    Sydney Australia
    Anthony
    Here is a picture of each type
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,727
    Central NJ
    Dominick
    Iirc Ferrari made the recommendation to change to 1.1 bar
    I think if you search for 10230 you will have a few threads on it
    Usually when i research something to the point of buying the item I would say I would bet on it being right :)
    Non vented 1.1 bar
    ants2au likes this.
  6. EDoug
    EDoug Formula Junior
    Apr 19, 2005
    261
    Southern Florida
  7. Rifledriver
    36,855
    The workshop manual was printed in 1991. Is it possible the specification changed in the intervening 32 years?
    ants2au likes this.
  8. ants2au
    Nov 19, 2003
    793
    Sydney Australia
    Anthony
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,727
    Central NJ
    Dominick
    Not sure I follow ..out of the two you show i would.think.the shorter one is the correct one .. did i miss something
  10. ants2au
    Nov 19, 2003
    793
    Sydney Australia
    Anthony
    my shorter one is shorter than yours..
    thats what is on the 512,,
    but yours is shorter than my long one (which is on the Fiat)..
