512tr starting | FerrariChat
512tr starting
Discussion in 'Technical Q&A' started by redtessa, Jun 18, 2014.
  1. redtessa
    redtessa Rookie
    Aug 14, 2006
    5
    north london
    Does anyone experience key starting with 512 tr? Problem is every once in a while car will not fire engine does not turnover so electrical problem. Have fitted direct feed from battery to starter motor through push button and this works every time, but cannot find cause of problem through key, does any one know if this could be caused by faulty relay?
    Many thanks
    Michael
  2. PerKr
    PerKr Formula Junior
    Oct 10, 2007
    278
    Mariestad, Sweden
    Per Kristoffersson
    on those occasions when the car won't start, is there any sound at all when you turn the key or is it just dead quiet with no signs of anything doing anything? if the relay is easily accessible I imagine it wouldn't be too difficult checking with a voltmeter to see if it's the relay or something else causing the problem (with it being intermittent I wouldn't be surprised to find that something else is causing the problem, a relay is a relatively simple device after all)
  3. JIMBO
    JIMBO Formula 3
    1,357
    Bradenton, Florida
    Jim DeRespino
    I've just been through the same thing with my 512TR. The "start" wire from the ignition switch enters the fusebox, runs around in there for who knows why and then exits to the starter solenoid. No relay. When I disconnected the in and out wires from the fusebox and joined them together with a jumper wire, the starter worked perfectly, but I had no lights, AC, turn signals, horn, etc. I think the purpose of the starter wire entering the fusebox is to ground these circuits while trying to start the car (my amateur opinion).
    Sometimes the problem is an aftermarket alarm kill circuit that interrups the wire going from the ignition key to the fusebox. This can cause a drop in voltage. The car will start when cold, but when hot, the resistance increases and the small droipo in voltage may not leave enough to turn over the starter. I also seem to be losing a couple of volts through the fusebox.
    I would like to install a start button also. How is yours installed? is there a relay or a fuse?
  4. oldcoin
    oldcoin Formula Junior
    May 1, 2006
    258
    Reno NV
    Tony Mitchell
    Michael,
    Try wiggling and or disconnecting and reconnecting the 9-pin connector. The 9-pin connector is in the left rear corner of the car in the engine bay.
    Tony
  5. JIMBO
    JIMBO Formula 3
    1,357
    Bradenton, Florida
    Jim DeRespino
    Where exactly is the 9-pin connector?
  6. 4RE Guy
    4RE Guy Karting
    Aug 3, 2008
    90
    resistance gets high in the circuit from age, (battery to key to starter) and voltage drops to level where starter solenoid will not engage(when warm is usually worse) . the easy and solid repair is to put a relay close to(or on) the starter solenoid(30- 50 amp), so there is a 12volt source right where you need it. you can verify what i said with a volt meter if you do not believe me. any qualified Ferrari repair facility can correct issue if you feel you can not complete task yourself.
  7. oldcoin
    May 1, 2006
    258
    Reno NV
    Tony Mitchell
    The connector is at the end of #7 on this diagram. 1/2 of the connector is affixed to the car, the other 1/2 is in the engine bay. The connector is high up in the engine bay and easy to reach. The connector has a ring around it that you unscrew and then it just pulls apart
    Ferrari 512TR Parts : Table 125 - ELECTRIC SYSTEM
  8. JIMBO
    JIMBO Formula 3
    1,357
    Bradenton, Florida
    Jim DeRespino
    #8 JIMBO, Jun 23, 2014
    Because of the hard hot start problem, I did install a relay as you suggested at the starter solenoid and it worked perfectly for the last 35,000 miles. Unfortunately some voltage bled into the circuit (I suspect inside the fuse box), causing the relay to trip and leaving the starter engaged, thus frying the starter. I would prefer to run a push button as an adjunct to the original wiring. If I run a 12v source in the glovebox to the button and then out to starter, should I use a relay and can I run it to the white wire that exits the fuse box and goes to the starter solenoid, or will this result in some feedbck through the circuit board? Should I run the relay output directly to the starter solenoid, or will this produce dangerous feedback through the original circuit?
    Fried starter:
