1/12 Ferrari 312 P Le Mans 1969 Build | FerrariChat
Discussion in 'Collectables, Literature, & Models' started by PeterWPro, Oct 7, 2016.
  1. PeterWPro
    PeterWPro Formula Junior
    Nov 6, 2015
    685
    Florida
    Peter
    #1 PeterWPro, Oct 7, 2016
    Christian.Fr likes this.
  2. Christian.Fr
    Jun 9, 2005
    21,596
    Christian.Fr
    Incredible....another supplier, complicate to change?
    But how many are you building at the same time?
  3. PeterWPro
    Nov 6, 2015
    685
    Florida
    Peter
    Only this one on spec. A fairly crude kit with a lot of potential.
  4. PeterWPro
    Nov 6, 2015
    685
    Florida
    Peter
    #4 PeterWPro, Oct 12, 2016
  5. furoni
    furoni F1 World Champ
    Jun 6, 2011
    13,983
    Vila Verde
    Pedro Braga Soares
    I love this car....most beautiful sports car ever made!!
  6. furmano
    furmano Three Time F1 World Champ
    Jul 22, 2004
    32,215
    Colorado
    Furman
    Love it! What kind of paint do you use for the red?
    -F
  7. PeterWPro
    Nov 6, 2015
    685
    Florida
    Peter
    FER300 base coat
  8. tomgt
    tomgt F1 Veteran
    7,153
    Netherlands
    Tom Wiggers
  9. PeterWPro
    Nov 6, 2015
    685
    Florida
    Peter
    #9 PeterWPro, Oct 17, 2016
    The difference is negligible. Never had a dispute in 25 years. This is nit picking ;) This color can change based on who mixes the paint and what manufacturer, the primers used, etc. To be as consistent as possible I always use the same brand and the same grey primer.
  10. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,259
    Black Forest Germany
    Martin N.
    Grey primer actually makes FER300 looking similar to Fiat 120. So it's a nearly perfect match. I recently made a color template on a piece of sheet metal for my real car, painted in FER300 (Glasurit solvent based base coat + clear )
    With grey primer it was completely wrong. With white primer the FER300 template matches my car perfectly, but maybe too bright for these old race cars.
    One could also debate about the gloss. Actually today's two pack paint systems are much too glossy. But who would want such a dull finish like on the real cars?
    Best Regards
    Martin
  11. tomgt
    tomgt F1 Veteran
    7,153
    Netherlands
    Tom Wiggers
    correct about the gloss.
    Ferrari did not use clear coat on the racing cars in the sixties and early seventies
    primer + red paint
  12. PeterWPro
    Nov 6, 2015
    685
    Florida
    Peter
    This has been going on for a long time. I clear all of my models over the decals to preserve them. I also wet sand and polish them to tone down the hard gloss. 95% of my clients prefer this over exposed decals. Some companies like BBR put the decals over shiny paint which is a production decision but the paint should be toned down in my opinion.
  13. PeterWPro
    Nov 6, 2015
    685
    Florida
    Peter
  14. Martin308GTB
    Jan 22, 2003
    4,259
    Martin N.
    So it's unnecessary to put a thin layer of clearcoat prior to the decals?
    I always performed this to prevent 'silvering' and never tried without.
    Like said, a VERY thin coat, to prevent too much build-up.
    Best Regards
    Martin
  15. PeterWPro
    Nov 6, 2015
    685
    Florida
    Peter
    Totally depends on the quality of the decals and the color of the base coat. I do a scratch coat on most metallic colors especially silver. Also when painting multiple colors. In this case there is virtually no carrier film on the decals and no transparent areas so it's not necessary.
  16. Dexter Models
    Dexter Models Karting
    Dec 22, 2006
    60
    Reims - FRANCE
    FACON Bob
    Very nice work Peter !
    For the decals, all depends of the technical tolerances imposed by the printing.
    But In this case, the width of the carrier film (varnish) is 0.15mm (0,0059').
  17. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    19,164
    michigan
    john
    well done!
    looks quite nice
  18. furmano
    Jul 22, 2004
    32,215
    Colorado
    Furman
    You actually use automotive paint? Glasurit (PPG) FER300 is a two part paint. Is this what you use or some kind of equivalent?
    -F
  19. PeterWPro
    Nov 6, 2015
    685
    Florida
    Peter
    Yes...have been for the last 20 years. I rarely use hobby paints.
  20. furmano
    Jul 22, 2004
    32,215
    Colorado
    Furman
    Cool! Looking really great.
    -F
  21. PeterWPro
    Nov 6, 2015
    685
    Florida
    Peter
  22. furoni
    Jun 6, 2011
    13,983
    Vila Verde
    Pedro Braga Soares
    That paint looks amazing!!
  23. PeterWPro
    Nov 6, 2015
    685
    Florida
    Peter
    #23 PeterWPro, Oct 22, 2016
    Thanks. As a side note the holes will be covered with photo etched riveting so I am not concerned if some got covered. Here is a sample of how they will look in the end.
  24. furmano
    Jul 22, 2004
    32,215
    Colorado
    Furman
    I'm curious, if you don't mind, what clear coat do you use and what polishing compound do you use?
    In the past I have used Tamiya's acrylic clear coat so it doesn't eat the decals and Griot's polish because that is what I have on hand but I'm not sure they are the best combo.
    -F
  25. PeterWPro
    Nov 6, 2015
    685
    Florida
    Peter
    I rarely use "hobby" or commercial products. That said...
    Two coats of 2 part Nason Urethane Clear [medium temp] scratch coat that is wet sanded flat with 1000 wet/dry, followed by two more coats of the clear...then:
    I wet sand the clear with a 1000 wet/dry paper first [using soapy water] until the clear is completely flat. I follow this with a 2000 wet sanding and finally a 5000 sanding with a rotating pad. I then machine polish with a cotton attachment on my Dremel hand held at low speed very carefully with minimal pressure. I start with 3M cutting compound and finish of with Finesse It.
    My secret is now out. Expect to spend 5-6 hours for the whole process [minimum on a 1/12 like the 312P]
