News
550 Battery "J" Hooks
Discussion in '456/550/575' started by hwyman, Apr 22, 2020.
  1. hwyman
    hwyman Formula Junior
    Jun 25, 2015
    255
    Canada / Los Angeles
    I just installed a new battery and the battery is identical in size to the FIAMM battery Ferrari uses. The previous owner had a crap battery in the car and didn't have the J hooks or the heat shield. I finally found the front top bracket with J hooks and heat shield, went to install it and the hooks are too short. Were there changes to these with different model years?
  3. tazandjan
    33,030
    Most of us have had to use longer J Hooks with the later batteries, especially AGMs. Depends on how the bracket fits as well as on the size of the battery.
  4. hwyman
    Jun 25, 2015
    255
    Figured Taz… I'll order some generic 10" hooks. So do the hooks feed through the L bracket and the heat shield then bolt? Or do you bolt the L bracket down then the stickout goes through the heat shield with another bolt?
  5. tazandjan
    33,030
  6. To remove this ad click here.
  7. tazandjan
    33,030
    Dave- Beat me to it, only I used a 575M parts catalog page from Ricambi.
  8. ferraridriver
    ferraridriver F1 Rookie
    4,031
    Bay Area Calif.
    Dave
    But..... but.......but.............he said.........550
  9. hwyman
    Jun 25, 2015
    255
    Thanks guys! I looked at that image too, so the heat shield holds down the L bracket from the looks of it
  10. ferraridriver
    4,031
    Bay Area Calif.
    Dave
    I used four nuts, two half height for the bracket then two nyloc for the heat shield. Half height between the bracket and heat shield
    308 GTB likes this.
  11. To remove this ad click here.
  12. hwyman
    Jun 25, 2015
    255
    That’s what I was thinking of doing. The holes on the heat shield appear to be wider apart than the holes in the L bracket
  13. ferraridriver
    4,031
    Bay Area Calif.
    Dave
    No, they’re the same
  14. hwyman
    Jun 25, 2015
    255
    Crap I may have gotten a heatshield made by someone other than Ferrari then. Ill drill out the heatshield to match the L bracket then. Sucks these parts are unobtanium and the PO tossed the originals when installing his cheapo battery
  15. 308 GTB
    308 GTB F1 World Champ
    10,031
    New Jersey
    Barry Wolinsky
    I'm afraid that was the fate of many 550 heat shields along the way. Early 550s were delivered without heat shields and some owners had them fabricated later on.
    What you plan on doing is a good solution.
  16. hwyman
    Jun 25, 2015
    255
    Yeah I figure theres a reason the factory installed a heat shield... seeing as the battery sits 3 inches from the exhaust manifold on a big V12. Installed a $400 Braille AGM battery so don't really feel like toasting it if I can prevent it
  17. tazandjan
    33,030
    575Ms came with a multi-layer insulator shield instead of a metal heat shield. Usually missing, too.
