550 Engine Removal | Page 12 | FerrariChat
550 Engine Removal
Discussion in '456/550/575' started by rmfurzeland, Dec 23, 2012.
  1. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    If we accept as true that this is cavitation damage, and no less of an authority than Mahle has said it is, then we should be looking at the cause which is, by definition, a shock wave transmitted through the liner to the coolant.
    The density and shape of the liner wall will affect the shock wave and its impingement on the coolant. How it does so is not of concern except to hypothesize that the all of the factors present, coolant composition, pressure, temperature, liner configuration, and maybe more may have, in this particular case, led to a "perfect Storm" of conditions that resulted in cavitation damage to the liners.
    It still follows that something caused the shock wave and I'm at a loss to come up with anything other than detonation.
  2. rmfurzeland
    rmfurzeland Formula Junior
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    RifleDriver,
    You said
    "They (No-Rosion) say distilled water is only not recommended if 50/50 antifreeze is not used. Of the several name brand antifreeze makers I have researched all said distilled should be used and RO was ok as well. " Yes, that is what I meant to say when I mentioned "no distilled water" to LamboDriver.
    However you have set me thinking, if 100% distilled water creates an ionic/mineral imbalance that leaches metal minerals out of the engine into solution, why does a 50/50 antifreeze/distilled water pass this test OK . So the assumption is that the 50% antifreeze restores the ionic/mineral imbalance 100% to where it needs to be?
    By the way don't drink distilled water,
    Early Death Comes From Drinking Distilled Water
    Regards,
    Ron
  3. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    FerrariDriver,
    Yes, shock waves .....and I understand all engine cylinder liners move outwards a small amount under the high compression at TDC thus creating a number of vacuum sites for bubbles to collapse and form shock waves and cavitation jets.
    So if an engine is perfectly timed and the combustion/fuel mixture is ideal then there are fewer shock wave interactions? Or if the combustion happens early, and then the piston gets to TDC it adds more outwards pressure? Sounds like some pressure waves add up or "resonate" at a certain frequency and cause cumulative damage. Just a theory ..
    Tendency of bubble formation will also depend on pressure, temperature and composition of the coolant as contributory factors as mentioned under the "coolant maintenance" discussion.
    Ron
  4. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    I think that if we ever discovered the actual cause of the cavitation in your case, which I don't believe we will, we would find that "resonance" played a key role.
    Now we're getting above my pay grade ;)
  5. fatbillybob
    Aug 10, 2002
    28,989
    socal
    Anyone think the liner could have had a deflect? I know mahle rep is awesome etc. But why can't there have been some small inclusion or defect that helped make this problem? I don't know much about cavitation or pitting. Does nicking the liner on original assembly act like a boiling chip to get the process started? It was probably not one thing but several. Maybe you can't duplicate it without the defect. Many cars knock and many have poorly maintained cooling systems, many probably have sub optimal radiator caps. This does appear tobe rare. This is not a ford diesel known for this issue.
  6. fatbillybob
    Aug 10, 2002
    28,989
    socal
    In my minimal understanding of cavitation erosion your definition oversimplifies it. There is more too it like low pressure effects of flow and lower vapor pressure forming collapsing bubbles with the results. That pitting begets more pitting as a nidus for continuing the process. There are plenty of "shock waves" such as the process of combustion, a normal process, that is not "detonation" which is thought of as destructive. All of those things conspire to cause CE. I "think" your implication is that there is a running problem associated with the condition. I don't think there is any evidence to support that hypothesis any more than we could blame poor maintenance. But which is more likely to set up the CE conditions?
  7. fatbillybob
    Aug 10, 2002
    28,989
    socal
    Maybe they use the wrong scientific words for clarity. In the diesel engines you are talking about created venturi effects and low vapor pressure resulting in boiling if you will whose collapsing bubble cavitate. a surface coating may not be able to take that for long but a replenishable surface coating can. In the ford excursion case the coolant additive coated the metal was blown off during cavitation and then reformed on the metal to be blown off again never reaching deep to the metal. That's my hillbilly understanding of it. I drive a Ram diesel megacab but would have bought a diesel Excursion to pull my racecar until I found out this is just one of many problems with the Ford.
  8. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    FBB,
    A liner defect during manufacturing is always a possibility. But location of the hole in the hottest and narrowest part where 2 neighboring liners face each other at the end of the block makes me think local flow, temperature and pressure effects are more likely,
    Regards,
    Ron
  9. fatbillybob
    Aug 10, 2002
    28,989
    socal
    Agreed that's where cavitation always is. Here is another datapoint. I drive the pi$$ out of my 550. I bet I'm the highest mile car here at near 60K. That is alot of coolant venturi-ing around helping to create the effect or conditions for cav. I have not experienced it yet and if this is a systemic problem one would likely see it as the miles got higher just from plain old use. How many miles on your 550?
  10. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
  11. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    FBB,
    18,000 miles and still a virgin, i.e. never raced
    Ron
  12. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    Well it's been a long weekend, but the engine lower half is back in the car and the bell housing and engine mounts are bolted up! Even fitted one cylinder head!! After studying Pete (Moorfan)'s excellent description I then dived in to fitting the new timing belt and tensioner. Rats, the new belt is hard to get on, anyone got some good tips to help out? I have set the tensioner to its loosest as per Pete's description, but maybe one can make it even looser to help ease the belt on? Tried also loosening the cam cogs, fitting the belt but then cant get cam bolt back in since belt so tight.
    Any tips welcome,
    Thanks ,
    Ron
    Refs to Moorfan:
    http://www.ferrarichat.com/forum/456-550-575/334008-1998-550-maranello-sorting-thread-diy-15.html
    He says
    "....I had placed the cog gears on the cams without securing them. They are able to move somewhat loosely without moving the camshafts at all. At this point I locked the tensioners in their "loosest" position by wedging a prybar onto the tensioner base and cranking the spring out, and then tightening the tensioner bolt (marked "X" in the photo) to hold it at maximum looseness. This makes it easiest to apply the belts, which are quite robust. (Photo 1)
    After sliding the belt in place, which takes some force and a very slight manipulation of the loose cog gears, I had the timing belts on in proper location. "
  13. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    It's the fence on the lower pulley making things difficult. You have a few options getting the belt in without mangling it. Manipulating the cam gears (aka taking them slightly off) is one way of putting the belt in, another way is to undo the lower pulley and slide the belt in together with that pulley, you will need a ring nut tool and new ring nuts. It is not my favorite though since the new ring nuts seem to wear down the threads on the pulley shafts, I would not recommend it as standard procedure.
    Last option is to wait with mounting the tensioner bearing on its mount until the belt is in the car. This is somewhat difficult too, as you will have to tension the bracket sufficiently to get the bearing on.
  14. moorfan
    moorfan Formula Junior
    May 11, 2009
    809
    Central Virginia
    Pete
    Ron,
    glad to see her going back together!
    As I recall I had some difficulty getting the belts back on as well, but putting them on the lower drive gear first (the one with the fence) and then sliding them over the upper cogs worked for me. The inner surfaces of the belt are coated with wax, so some of it may shave off a bit as you slide them over the upper timing gears.
    Regards,
    Pete
  15. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    Hi Pete,
    I am re-reading your description looking for the anything I have missed, it is a great help to me to have your blow by blow account. Yes, I am putting the belt on the bottom cog first. Next I pant and pull it over the top 2 cogs then try to lever it over the smooth tensioner pulley without success. It is so stiff and lacking clearance that I am sure I am missing something:
    either tensioner can be loosened some more or loosening the top cogs helps.
    Loosening the top cogs is problematic since
    a) the Milwaukee impact driver kicks the cam a bit and so moves the reference marks - maybe I should lock the cam?
    b) getting the cog back on the camshaft is difficult with an new belt
    Let me try to see if the tensioner can be loosened some more,
    Thanks,
    Ron
  16. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    #291 rmfurzeland, Mar 4, 2013
    Sideways delivery to put engine back in:
    Note: use of leveler, drivers side wheel removed, only lower half of engine hoisted, cylinder heads will be added with engine in bay, initial tilt then leveled with leveler once clear of cross member. Engine mount arms left off since get in the way when tilt. Rope is to help guide it in for L-R centering.
    Problems: lack of clearance of bottom of bell housing on back chassis cross member and drive shaft spindle on pressure plate. Solved with iterative use of jack under sump and jack under rear bell housing. Future idea would be to try grinding the top center of cross member say 3/8" deep by 4" long.
    It took 4 tries to find a solution that worked, no brute force was used, I did it single-handed.
    "Abandon all hope all ye who enter here" (Dante-Inferno, inscription on the Gates of Hell),
    Ron
  17. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    #292 rmfurzeland, Mar 4, 2013
    With engine rear resting on rear cross member I then switched to :
    jack under sump, remove hoist from side to front and put sling at front;
    This gave me more lateral movement to shove the engine back (the leveler was constraining it ).
    Note: Engine mount arms added back in, jack under rear of sump (not visible).
    Lots of creative work here ,
    "Lasciate ogne speranza, voi ch'intrate"
    Ron
  18. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    So if you enjoyed these pictures, and are skilled in fitting new stiff timing belts, please let me know the trick,
    Thanks,
    Ron
  19. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    Ron,
    Step 1: Verify that Ricambi did not send you belts for 360 (or Toyota camry) :)
    Step 2: Do NOT lock the cams. I was advised by more than one "prominent" ferrari mechanic that slipping the matchbox covers under the cams can bend the cam caps out of round. Secondly, it won't hold the cams totally still with an impact gun so the point is a little moot.
    Step 3: Get the maximum extension out of that tensioner. I put a flathead under the squared nub of the tensioner piston and compressed the spring all the way, followed by tightening the bolt on the tensioner bearing to hold it in place. I wonder if you just need a millimeter more ;-)
  20. Cribbj
    Cribbj Formula 3
    Now there's an innovative way to get the engine in; hang the car off the wall, then shove the engine into it sideways, as per the last pic :)
    Sorry Ron, you're probably not in the mood for a little humor right now.......
  21. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    Ron,
    The other thing I would say is put the belt on the bottom gear, but DON'T then put it on the two timing cogs all the way and then try to bend it over the tensioner. Put it on the bottom gear, and then line the belt up simultaneously with both cogs and the tensioner bearing.....then take a rubber mallet and tap the belt on a little at each place sequentially (tensioner bearing, then cog 1, then cog 2, then back to tensioner bearing). Inchworm it on like that.
    Regards,
    Pete
  22. bretm
    bretm F1 Rookie
    Feb 1, 2001
    4,577
    Northern NJ
    Bret
    I've only helped doing the timing belts on a 550 once, and admittedly I don't remember how we put them back on. On my 308 though, I usually put the belt on the lower pulley and one of the upper pulleys. I leave the second upper pulley off its cam and slip the belt onto that. Then I push that pulley onto its cam. It's much easier this way as the pulley only seats maybe 1/4" on the cam, whereas you're trying to slide the belt something like 1" by pushing it on the front of the pulleys with them all in place. ie, the deflection is much less and therefore the distance is much shorter.
    Of course, it means you have to remove one of the pulleys. But, I assume after all this work you're going to re-time the engine anyway so that's a moot point.
    By the way, for guys like myself who hope to own a 550 someday, this has been a great thread. Thanks for taking the time to post it up for all of us to share. It's very cool of you.
  23. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    #298 rmfurzeland, Mar 4, 2013
    John,
    Yep, this sideways trick was used to get the oil to stay in the oil filter when you screw it on ! Or was I so tired that night that my head was tilted?
    Humor is fine now that the damned thing is in.
    Ron
    PS don't you have one of those modern desktop LCD screens that rotates, or even a tablet?
  24. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    Pete,
    Pretty much everything you said I tried last night, even the rubber mallet, after all I have your magic ring nut remover and that gives me the power to read your thoughts. I will re-try the simultaneous tap idea that sounds like a possibility.
    assume it is OK to leave cam bolt in place in cog1+2?
    Thanks,
    Ron
  25. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    Bretm,
    yep tried this, removed cog1, got belt on all wheels but could not get cog1 back on the end of the cam.
    Glad to hear your suggestion though,
    Ron
