550 Engine Removal | Page 15 | FerrariChat
550 Engine Removal
Discussion in '456/550/575' started by rmfurzeland, Dec 23, 2012.
  1. rmfurzeland
    rmfurzeland Formula Junior
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    John,
    BTM with Ruby red laser
    BTM-400PLUS Belt Tension Meter
    Mine is made by Albuquerque Instruments , normally $795 , picked it up on ebay for $220.
    Regards,
    Ron
  2. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    #352 rmfurzeland, Mar 26, 2013
  3. omd78
    omd78 F1 World Champ
    Dec 26, 2005
    13,242
    Breda, Netherlands
    Martin
    333SP in the background..?
    Gr. Martin
  4. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    omd78,
    Probably yes, I went back a few days later and it had gone so unable to verify,
    Ron
  5. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    Dear all,
    Just to end on a happy note, car is up and running with no leaks. I just wanted to thank y'all for your generous support and help during the engine rebuild. It's great to know you are not alone when one has such a tough job to do.
    I have learned a lot, mostly the hard way, and am looking forward to some trouble free driving for a while...
    Ron
  6. tazandjan
    39,176
    Ron- Great job getting her back together and documenting the process.
  7. fatbillybob
    Aug 10, 2002
    29,026
    socal
    Agreed! Thanks for letting us be voyeurs and thanks for the comments from pros too.
  8. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Strong work, Ron. I'm glad that my liner puller gave you some inspiration...
    Best,
    David
  9. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    Thanks for the postscripts, it was your support and inspiration that kept me going during the difficult times like how on earth do you remove a 550 engine, cylinder liner, head nut, header nut, cam cog wheel, etc. These were the real challenges, such that setting the cam timing was relatively relaxing in comparison.
    Just a pity that part prices prevent one from rebuilding as a Stage III upgrade.
    Regards,
    Ron
  10. DZ-96
    DZ-96 Formula 3
    1,907
    South Germany
    Daniel
    Hi Ron
    You should be able to give an answer to my question.
    Is it possible to change the oil pump chain (you have to remove the front housing) with the engine in the car ?
    Next week i want to do this job at my car.
    Daniel
  11. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    #361 rmfurzeland, Apr 7, 2013
    Daniel,
    Interesting question, there is a small inspection cover (2 in diagram) which allows access to see the chain but you cannot slide of the chain or sprockets without removing the main timing cover 17 which means removing damper, front seal, timing cogs etc.
    Both the main cog on the crankshaft and the small cog on the oil pump shaft cam can hen be slid off, so yes it should be possible with engine in situ. See 2 photos.
    Idea: You could try using a motorcycle chain link remover after removing the small inspection cover 2. Then maybe you dont need to remove anything else? But there is hardly any room to do this see 3rd photo.
    Ferrari Parts, Ferrari Accessories, and Ferrari Performance Products - Ricambi America, Inc.
    Regards,
    Ron
    PS start a new thread on this so we can see how you get on
  12. DZ-96
    DZ-96 Formula 3
    1,907
    South Germany
    Daniel
    Hi Ron
    I want to change the bearings also so i have to remove the complete housing.
    0k. i try to take photos from the work, so i will upload them.
    Daniel
  13. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    Daniel,
    The main reason to remove the engine is when you have to separate the lower half of the block (Sump etc) from the upper half (crankshaft and pistons).
    Not necessary just to remove timing cover.
    Thanks,
    Ron
  14. DZ-96
    DZ-96 Formula 3
    1,907
    South Germany
    Daniel
    Daniel
