550 front hood corrosion | FerrariChat
Discussion in '456/550/575' started by ken qv, Sep 20, 2021.
  1. ken qv
    ken qv Formula 3
    Oct 25, 2006
    1,916
    Florida
    Ken Roberson
    Bubbles under the front hood are common I’m told by some owners plus your usual YouTube videos.. ok so maybe it’s an easy fix, but what is the modification needed to prevent a reoccurrence? What strategy are owners using?
  2. JC1720
    JC1720 Karting
    Jan 21, 2016
    102
    Make sure to towel it dry after washing or a wet run - it’s a water trap.
    May be a more scientific way of doing it but this helps for a non-daily driver.
  3. ken qv
    ken qv Formula 3
    Oct 25, 2006
    1,916
    Florida
    Ken Roberson
    I wonder if leaving the hood open for some time after washing would help.. or a leaf blower to help force some air in there
  4. root
    root Formula Junior
    472
    Bay Area, Ca
    That's how I do it. I avoid spraying directly at the front of the hood facing the car. After drying the exterior I lift the hood and wipe off the underside then take my time wiping off the accessible areas of the engine. That should minimize water getting trapped in the hood's leading edge and enough time to move it out if a few drops got in there.
  5. tazandjan
    38,083
    Aluminum, so it cannot rust. Can corrode, but probably not from water. Galvanic corrosion, possibly.
  6. root
    root Formula Junior
    472
    Bay Area, Ca
    Doesn't moisture promote galvanic action by acting as electrolyte? If so then by eliminating the electrolyte one could substantially reduce galvanic corrosion.
  7. tazandjan
    38,083
  8. henryr
    henryr Two Time F1 World Champ
    21,699
    Atlanta
    Juan Sánchez Villa-L
    correct. it is a hard bubbling from the aluminum coming in contact with some other metals.
    they all have some sort of it or will
  9. marce
    marce Formula Junior
    Jan 30, 2014
    433
    Australia
    Marcel
    got rid of the corrosion on the 550, had it under the lip if the hood and also against the rubber trim of the windscreen... it was like magic.
  10. scottevestceo
    scottevestceo Karting
    Apr 16, 2023
    142
    Scott Jordan
    Curious how big of an issue this is. If you see this in one area of a vehicle, and it is fixed properly, how likely will it reappear in other areas of the car? Thanks.
