550 headlight upgrade | Page 2 | FerrariChat
Discussion in '456/550/575' started by stan996turbo, Feb 1, 2023.
  1. fatbillybob
    Aug 10, 2002
    28,588
    socal
  2. otoupalik
    otoupalik Formula Junior
    Feb 22, 2004
    715
    Scottsdale, AZ
    Brad Otoupalik
    Oh gosh, I don't think anything is Plug n play!
  3. 308 GTB
    308 GTB F1 World Champ
    11,650
    New Jersey
    Barry Wolinsky
    I've had my 550 since 2007. For me, the OEM headlights are quite sufficient for nighttime driving.
    JohnnyRay likes this.
  4. otoupalik
    Feb 22, 2004
    715
    Scottsdale, AZ
    Brad Otoupalik
    I am sure they are for some. I drive fast. They are not for me, especially here in Arizona. We have had it since 1999 (first owner) and it didn’t bother me much when we lived in Kalifornia. Lots of street lights and ambient light. Here there are no street lights and the only ambient light is from the moon. To be fair the older Porsche we have is awful as well. I don’t like the experience from most new cars but I love the lighting they have.
  5. 308 GTB
    11,650
    New Jersey
    Barry Wolinsky
    I guess I have good night vision.
    My 1995 F355 Challenge had very anemic headlights. I replaced the high and low beam bulbs with LEDs with good results...
    I put yellow LED bulbs in my flashers and wired and switched them for independent use as driving lights while on the track...
    Ferrari55whoa likes this.
  6. otoupalik
    Feb 22, 2004
    715
    Scottsdale, AZ
    Brad Otoupalik
    308 GTB likes this.
  7. 308 GTB
    11,650
    New Jersey
    Barry Wolinsky
    #32 308 GTB, Jun 12, 2024
    Ferrari55whoa and Mirek like this.
  8. JohnnyRay
    JohnnyRay F1 Rookie
    3,496
    Central FL/NW WI
    308 GTB likes this.
  9. otoupalik
    Feb 22, 2004
    715
    Scottsdale, AZ
    Brad Otoupalik
    They run lights to differentiate the class. That is why the Protoss have white and the lower class has yellow. Makes it much easier for the slow cars to know when they are going to get passed.
    does look good though. Those flashers are perfect for that!
    we only ran lights on our race cars for enduros into the dark. =)
    SCantera and 308 GTB like this.
  10. 308 GTB
    11,650
    New Jersey
    Barry Wolinsky
    And that's why I chose yellow (3000K) LED bulbs for my flashers. As my car had its electric door locking mechanisms removed, I use this switch (partially hidden by the shifter) to turn my flashers on and off...
    If I have to flash a car ahead of me, I flick that switch off and use the light stalk.
    otoupalik likes this.
  11. 308 GTB
    11,650
    New Jersey
    Barry Wolinsky
    I've shared the track with prototypes like that one. They come up on me really fast. And I have my pedal to the floor! :)
  12. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    I out in LEDs two years ago and they have been VERY good. Before that I had these cheap HID/xenon kits and they were not good. They used alot of power to start up. When I went from high beam to low beam, or started the car with the lights in on position (most cars are having the lights on always because we have low beams always ON by law here), one of the Zenon bulbs would not come on resulting in dring around with only one bulb lit…. never a problem with the LEDs. But the light is less bright than when I just installed them. The car looks more modern too.
  13. otoupalik
    Feb 22, 2004
    715
    Scottsdale, AZ
    Brad Otoupalik
    308 GTB likes this.
  14. otoupalik
    Feb 22, 2004
    715
    Scottsdale, AZ
    Brad Otoupalik
    I am working with Morimoto to see about the front led projector upgrade now too. I will report once there is progress.
    Lexatx, DPA360, vraa and 2 others like this.
  15. 308 GTB
    11,650
    New Jersey
    Barry Wolinsky
  16. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,860
    MO
    Omar
    Do (US-spec) 456M and 550s use the same fog light bulb size? I guess I’ll check later when at a proper computer.
    What LED replacement bulbs are people running?
    I updated my turn signals / reverse lights using Scud Ing units but wanted to eventually upgrade the fogs too now.
    Note US and ROW use different bulbs generally, YMMV
  17. DPA360
    DPA360 Karting
    Jul 16, 2007
    153
    Los Angeles Cali
    Let us know if you come up
    with anything I would love to buy a set as well! I also have the morimoto rear lens, luv!
  18. Vilhuer
    Vilhuer Karting
    Aug 3, 2008
    156
    Helsinki, Finland
    My daily driver winter beater has similar H7 low and H1 high beam setup as 550. When I used best what money can buy halogen Osram or Philips bulbs in it H7 low beams used to die very quickly. Sometimes both sides on same day under two months. Lower light output long life bulbs lasted longer but output was obviously worse. Got fed up of constantly changing low beams which means removing light fixture from car to get access to bulbs and got Philips Ultinon 9100 LED's to replace H7's. They have now been in use for six months without any problems. Light output is better than any halogen I have ever seen. Pattern is also ok.
    Based on above I got 9100 LED's for both low and high beams for 550. Both types have fan at backend of bulb fixture which is small enough to fit inside 550 light fixture. H1 has separate box as H1 bulb is so small that everything needed don't fit to bulb but extra box is small enough to fit inside fixture. Only problem is H1 by design earths itself through bulb body. Philips in their infinite wisdom decided to coat that part of LED bulb with non conductive coating. Once this is removed from right places also H1 works fine. Even without wiring change this is good for main board as LED's are using 23W instead of 55W what halogens use. Meaning amps going through board is also under half from stock halogens. Combined with direct feed from battery I feel this is very good setup even when these LED's are $200 for each pair locally.
    fdekeu and DPA360 like this.
  19. otoupalik
    Feb 22, 2004
    715
    Scottsdale, AZ
    Brad Otoupalik
    I have gotten slammed, but going to get back on this with Morimoto (also motivated by a late-night event last week that reminded me how bad the lights are!) lol
    @Vilhuer thanks for that. I am working to replace the entire projector with a proper LED unit, but if I cannot get that done, I may try your route.
    DPA360 likes this.
  20. DPA360
    DPA360 Karting
    Jul 16, 2007
    153
    Los Angeles Cali
    These sound like a good option, have only taken my lights out once and didnt think about sizing of bulbs inside housing. Good tonknow these fit perfectly. Did you have to take off coating on H1 to get them to work or not needed. I was told by a friend to look into the GTR Ultra 2 that they are a great LED but didn't take into consideration the bulb size and if they would fit into housing. I will more than likely giving the Philips a shot!
  21. DPA360
    DPA360 Karting
    Jul 16, 2007
    153
    Los Angeles Cali
    Looks like I will be following your lead with the GTR Ultra 2. Need an LED upgrade as well, are they a direct bolt on or do you need any other parts to make them fit. DId you do both H7 & H1 for fogs
  22. Cribbj
    Cribbj Formula 3
    For my Durango headlights, they were a direct fit and no additional parts were required. Can’t come out however, on the H7’s and H1’s
  23. DPA360
    DPA360 Karting
    Jul 16, 2007
    153
    Los Angeles Cali
    Got it, I Thought you put them on your 550. Do you know if they would work on the 550?
  24. Cribbj
    Cribbj Formula 3
    Different headlight housings completely. My Durango has a reflector type housing. But the 550 is a projector. The GTR quality & fitment were far superior to any of the others for my H13 headlights but if Morimoto had a comparable pair I probably would have tried them
    DPA360 likes this.
  25. DPA360
    DPA360 Karting
    Jul 16, 2007
    153
    Los Angeles Cali
    A previous FCHATER used the Philips Ultinon 9100 LED which seemed to fit and work. Wouldn't the GTR fit similarly and work like the Phillips 9100?
