550 intermittent limp mode, ASR error, no RPMs | Page 2 | FerrariChat
Discussion in '456/550/575' started by niftyfivefifty, Aug 11, 2019.
  1. dinos575m
    dinos575m Rookie
    Oct 28, 2019
    49
    Dean Pellegrino
  2. dinos575m
    dinos575m Rookie
    Oct 28, 2019
    49
    Dean Pellegrino
    I have been fighting a asr/abs issue also. I'v sent my computers out and came back fine. I lost all guages and speedo and tack
    I'm now getting 4 codes 1674,1675 (same) 1538,1631 and PO460 .I think it is in the CAN system. maybe left side fuel sensor ?
    Checked all fuses related. anyone have any thoughts. I have a 02 575 . had my ASR/ABS module repaired already.
    Love some help ,much thanks Dino
  3. Qavion
    Qavion F1 World Champ
    14,639
    Ian Riddell
    Interesting. On first impression it sounds like an instrument power problem, but let's do a quick review of signal paths.
    The ABS/ASR computer sends speed data directly to the Digitek unit (the digital display in the binnacle) on a single wire (no CAN Bus), via instrument panel plug "B". The Digitek unit processes the signal from the ABS/ASR computer and sends it to the Speedo. It also sends the signal to other components (power steering, engine ECUs, etc).
    The tacho signal (as previous stated) comes from one of the engine ECUs and via a number of splices and instrument panel (plug "A") to the tacho. Again it is a single wire. No CAN Bus involved. The tacho and speed signal wiring is independent. There is one single connector on the 550 I can recall where both tacho and speed data is present, but even if this plug was disconnected, it wouldn't affect the gauges. For info, it's called the Engine Signals Connector and is found to the right of the fuse panel (4 pin plug).
    I really think we should focus on instrument power. As you say, you've checked fuse 5, so we need to trace the wiring from that fuse.
    Here's the diagram:
    https://www.dropbox.com/t/TYe1rNHPP33PtHrQ
    If you follow the wire from the "bottom" of fuse 5, it goes to relay panel plug J (pin 6). The output is split into two green/white wires. One goes to splice "199". This feeds a lot of stuff, including the instrument panel. It basically powers all the main instrument panel gauges. It also powers the oil temp gauge in the centre instrument cluster. The fuel gauge in the centre instrument cluster seems to be powered by the Digitek unit. I'm currently trying to figure out what powers that.
    The good thing about the 550 is that it is easy to check the relay panel outputs. I would be checking the voltage on plug J, pin 6 (with the ignition on).
    Anyway, I'll give you some time to catch up with what I've said
    Ferrari55whoa likes this.
  4. Qavion
    14,639
    Ian Riddell
    For info, the Engine Signals Connector mentioned above also carries instrument gauge power. If the wiring for that has been crushed and shorted together, it does have the potential to take out all the gauges. It is shown in the wiring diagram (plug 23D) in the lower RH corner of the diagram. It's an unlikely scenario, however.
  5. Qavion
    14,639
    Ian Riddell
    There is a mini graphic in my wiring diagram (above) showing the plug numbering, but here it is by itself:
    As always, my wiring diagram hyperlinks self-destruct in 6 days. Cue Mission Impossible theme song :D
  6. Qavion
    14,639
    Ian Riddell
    oops.. missed the fine print. Disregard all of the above. I thought we were talking about the 550 (thread creep). If it's a 575, then CAN bus issues are back on the table. Since there are no wiring diagrams for the 575, I might have to find insight from the setup on the F360.
  7. Qavion
    14,639
    Ian Riddell
    #32 Qavion, May 15, 2021
    ... unless Taz has some diagrams?
    So you've even lost the analog gauges such as oil temperature and pressure? (and fuel) i.e. non-CAN Bus data.
    There are usually two power sources for this generation display. Power comes into the instrument panel on a 12 pin plug. Live battery ("+30") power on pin 1, key ("+15") power on pin 2. Fuse F16 and fuse F34 provide power on the 575.
    Since I don't have any wiring diagrams, the only place to check for power will be on the 12 pin plug. See plug "B"
    Since power and a few of the analog gauge signals go through this plug, perhaps the plug is not connected properly?
    The plug shown in the inset/box (in the above diagram) is the wiring harness plug as seen from the contact side, not the wire side).
  8. tazandjan
    39,392
    Ian- There is probably an expanded 575M section L out there somewhere, but I have not seen it. The only thing in the WSM is the 30 amp F16 fuse in Box C and the 15 amp F34 fuse in Box D.
    Qavion likes this.
  9. niftyfivefifty
    niftyfivefifty Formula Junior
    Mar 5, 2007
    366
    PacNW
    Hi everyone, please check your fuse board. They are a terrible design with 5 layers that separate with heat and age, and the soldering points burn up, leading to significant voltage drops, and other very strange issues that are impossible to solve without addressing the board itself. The issue also leads to alternator burn-out, which only compounds the behavior. Basically every Ferrari made from the 348 to the 575 is subject to this issue, and with the age of these cars and the heat their fuse boards reach during operation, it should be a point of inspection on every PPI and service, both minor and major. My mechanic uses a company in Arizona to build an all new board with high-temp PCB and big fat conductors, ensuring the issue never repeats itself. I would recommend any owner with a 348, F355, 456, 550, 575, and potentially 512TR and 512M to look at the bottom of their fuse board as soon as possible to inspect for board separation and soldering point integrity, or risk further damage to other systems in the car.
    rhern213, franschman and Qavion like this.
