550 LED light conversion | Page 3 | FerrariChat
Discussion in '456/550/575' started by cwwhk, Apr 3, 2012.
  1. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,137
    Bay Area Calif.
    Dave
    Sorry, I got mine on eBay long ago then bought bulbs from the retrofit site
  2. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    Would love to drop by and take a look sometime so I can learn more. Thanks.
  3. ferraridriver
    Aug 8, 2002
    4,137
    Bay Area Calif.
    Dave
    It looks like the Valeo D1S projector with a 2.5" lens will work as well, those are easier to find and the wiring is easier. If I had it to do again that's probably what I would choose. The ignitor is contained in the bulb as I understand it.
    m5shiv and F456M like this.
  4. Davidspop
    Davidspop Formula Junior
    Dec 23, 2019
    394
    Lance Malcolm
    So does anyone know which resistor was being replaced in the flasher module to allow for use of LED bulbs in rear turn signals?
  5. Davidspop
    Dec 23, 2019
    394
    Lance Malcolm
    @Qavion do you have any thoughts on a source for the resistor that @cwwhk used to make the stock flasher work with LED turnsignals?
  6. Qavion
    Qavion F1 World Champ
    11,556
    Ian Riddell
    Sorry, no idea. I only just figured out that "&#937" is Unicode for the ohms symbol (omega).
    So that means 249 kilohms. Red/Yellow/White/Orange/Gold
    There are different part numbers for Hazard/Turn modules depending on the number of turn lights fitted (varies with country). Substituting various resistor values, you could get the flash rate correct. I don't know if cwwhk's car is a Hong Kong car or a Japanese car.
    Then you have to worry about the shunt resistor for making the turn signals "hyperflash" when one or more bulbs have blown:
    If you check your lamps regularly, you wouldn't need to worry about the hyperflashing function.
    Note that on some cars, you would also have to factor in the resistance of the turn indicator bulb in the instrument binnacle. Is this incandescent or LED on the 456M?
  7. Davidspop
    Dec 23, 2019
    394
    Lance Malcolm
    Took me a while to figure out what "&#937" was.... So a 150 micro ohm resistor.... it sure looks like replacing that one shunt resistor with a 150 micro ohm version. Reading through the original thread it looked like he determined the only resistor that needed replace was this one resistor... the others appeared to not be needing replacement to achieve the 88 flashes per minute.. which makes sense as the timer is not needed to change just what determines when to trigger hyper flash.
  8. Qavion
    11,556
    Ian Riddell
    Where did you get that value from? Are you talking about the "shunt"/hyperflash resistor or the flash rate resistor? The existing hyperflash is "milli-ohms". The flash rate is "kilo-ohms"
    Either way, you have to know what cwwhk's light configuration is. Does his car have turn side-repeaters?
  9. Davidspop
    Dec 23, 2019
    394
    Lance Malcolm
    I was referring to the hyper-flash resistor, he called it a shunt resistor.
    Mis-stated, yes "milli-ohms".... I went through as many threads as I could it looked like his did not have the side repeaters.... I am going to try it out and see what I can find!
  10. Davidspop
    Dec 23, 2019
    394
    Lance Malcolm
    I have to restate above... I just went through the posts again and I do think Cwwhk had side "repeaters".... I need to get that calculation and recalculate without those as mine is U.S. spec... more fun with my soldering gun!
  11. Davidspop
    Dec 23, 2019
    394
    Lance Malcolm
    So recalculating, I am installing an 8w front turn bulb and two 5w rear lights... plus the dash indicator.. I calculate a 105 milli-ohm resistance should reset the hyperflash to a "bulb out" situation in my U.S. spec car... I am ordering but will take pix and share results on this thread.
  12. Davidspop
    Dec 23, 2019
    394
    Lance Malcolm
    Partial SUCCESS!!! So I found a flasher relay that matches our Ferrari relay it's a Werhle see pic.
    If you open it up and replace the shunt resistor (the silver wire looking resistor pictured) with a 10a 50v Schottky Diode, you can gain proper flash rate with all LED bulbs front and rear. Caveat.....you lose bulb out functionality...I believe replacing with a 100 to 120 milliohm resistor will achieve same but retain "bulb out hyperflash"....I have ordered but will take some time..
    Will report more then but till then all flashers and turn signals working with all LED bulbs!!
    Qavion likes this.
  13. Davidspop
    Dec 23, 2019
    394
    Lance Malcolm
    By the way, I bought the replacement flasher from Pelican Parts off ebay for $40....it is a direct replacement so even of you just want to replace your flasher it's readily available....it fits several models/years of BMW cars.
  14. Qavion
    11,556
    Ian Riddell
    How did you come up with the idea of using a diode instead of a 249kohm or similar resistor? I thought Schottky Diodes had minimal resistance in the forward direction.
  15. Davidspop
    Dec 23, 2019
    394
    Lance Malcolm
    I actually found a lead in reading an thread from 2009 on a BMW forum about adapting their 7 pin flasher for LEDs using a Schottky diode.... got me looking at their flasher, so I ordered one and confirmed the pin layout matched our flasher.... the theory of using a diode with a 0.5-1.0v voltage drop seemed to make sense.
    Decided to give it a try and it worked....but since it's a diode and not a resistor, the "bulb out hyperflashing" does not work.... I am still looking for the right resistor value (0.1 to 0.13 ohms) to achieve full functionality including "hyperflashing" but the diode works if you don't care about "hyperflashing".... I have 19 additional diodes if anyone wants to give it a try....
    Qavion likes this.
  16. Qavion
    11,556
    Ian Riddell
    So the flash rate was ok with standard bulbs? Just wondering if it’s suitable for cars with turn side repeaters.
  17. Davidspop
    Dec 23, 2019
    394
    Lance Malcolm
    Flash rate was exactly same as OEM flash relay.... but mine is U.S. Spec, so no side repeaters........ not sure what size those bulbs are, but I would not think that substantive.
    Also, for all LED switch over, I would opine that the current "diode" solution works regardless of the number of LED bulbs in that circuit......but others with more electrical knowledge likely could say differently?
  18. Qavion
    11,556
    Ian Riddell
    The hazard/turn module part numbers are different on US and Euro cars, so there will be some effect on either flash rate or hyper flashing.
  19. Davidspop
    Dec 23, 2019
    394
    Lance Malcolm
  20. Davidspop
    Dec 23, 2019
    394
    Lance Malcolm
    Well...I now have to retract my success announcement.....it seems all works correctly with ignition on but engine off...start engine and turn signals hyperflash......odd...I out in the BMW module and it works correctly engine running or not, but no bulb out functionality.... I will need to noodle this some more...I don't see why it would act differently with ignition on engine off versus engine running....hmmmm
  21. msark
    msark Formula Junior
    Feb 18, 2017
    279
    Southern California
    Might be the amperage going through the system from the alternator active vs the battery alone. The "cranking amp" rating on the battery isn't available unless there is a commensurate draw. That why you can use jumper wires right to a car battery and connect the smallest bulb without blowing it up .... You are clearly going to work this out to the benefit of us all ....
  22. Davidspop
    Dec 23, 2019
    394
    Lance Malcolm
    So, I purchased 0.15 ohm resistors, desolder, resolder... and now I can report success. Not sure if it was the indicator bulbs in the instrument panel that were not in my original calculation, but the 0.15 ohm resistor provides proper flash rate and when pulling one bulb the hyperflash "bulb out" functionality appears to operate correctly. I am now done with this project.
    I have 20 or so extra resistors if anyone is interested in doing this let me know.
    Ferrari55whoa and Qavion like this.
