550 One coil with no spark….. | FerrariChat
Discussion in '456/550/575' started by rcgalore, Jul 2, 2025.
  1. rcgalore
    rcgalore Karting
    Sep 8, 2014
    66
    San Juan, PR
    I am having a problem……. tried starting car today …it cranks..but does not starts…..I checked the Coil packs…and I have spark on plugs on coil pack fro banks 7-12, but no spark on coil pack plugs on bank 1-6…. do have positive power on plug that goes to coil pack bank 1-6.. I tried an extra coil pack I have on bank 1-6 and same problem…no spark… What might it be?
  2. Qavion
    Qavion F1 World Champ
    14,238
    Ian Riddell
    Are the injectors working? Fuel pump?
    I think you said you've changed the crank sensor, so I'm assuming that's ok.
    Sounds like an ECU issue or timing sensor ... or something is not plugged in... or something is plugged into the wrong slot.
    (EDIT: re the last... we've seen folks mix up cam sensor and knock sensor plugs on 355's and 360's. I don't know if this is a possibility on 550's)
  3. fatbillybob
    Aug 10, 2002
    28,912
    socal
    1-6 is the passenger side using the passenger side ECU about where the passenger right foot would be below the A-piller. The A-piller on passenger side leaks water from rain and washing. Check the passenger ECU by taking it out and looking for corrosion on the ECU and plug pins.
    theunissenguido and Qavion like this.
  4. rcgalore
    rcgalore Karting
    Sep 8, 2014
    66
    San Juan, PR
    all good on that. No corrosion. no leaks.
  5. fatbillybob
    Aug 10, 2002
    28,912
    socal
    passenger footwell swap relay b with o...they are 7/12 and 1/6 injector control. fusebox internals are always suspect. A few of us have completely rewired or changed them
    Qavion likes this.
  6. Qavion
    14,238
    Ian Riddell
    I just noticed something odd in the Ferrari wiring diagrams. Looks like they've made an error. The RH (1~6) coil pack gets its power directly from the key via pin 11 of a plug above the ECU. Key power also goes to pin 11 of the plug above the LH ECU, but it goes no further in the wiring diagrams. It's like they forgot to draw a wire in. There is another wiring anomaly in the coil pack wiring, so I'm assuming they have drawn it incorrectly.
    Anyway, coil pack power is not an issue, so @fatbillybob 's suggestion sounds good. The RH injector relay provides power to the injectors, fuel pump relay coil, secondary air pump relay coil, RH O2 sensor heating, MAF (on the left hand side), RH idle speed regulator, cam sensor, RH Cat Thermocouple ECU, RH Anti-Evaporation Solenoid, the Modular Manifold Solenoid Valve, the RH Check Engine Light and probably a few other things I haven't thought of.
    To check the relay panel for power output from the injector relay, go to pin 8 and 9 of plug J
    rcgalore and fatbillybob like this.
  7. Qavion
    14,238
    Ian Riddell
    rcgalore likes this.
  8. rcgalore
    rcgalore Karting
    Sep 8, 2014
    66
    San Juan, PR
  9. rcgalore
    rcgalore Karting
    Sep 8, 2014
    66
    San Juan, PR
    yes. I installed brand new fuse board from Uninsegundo. I will make the swap
    Aerosurfer likes this.
  10. Qavion
    14,238
    Ian Riddell
  11. rcgalore
    rcgalore Karting
    Sep 8, 2014
    66
    San Juan, PR
    i found relay for 7-12 bank ( B) that the 86 prong was retracted inside the relay. Apparently when I installed, as the fuse board was new, I installed wrong. See relay at right of photo.
    Ferrari55whoa and Qavion like this.
  12. Aerosurfer
    Aerosurfer Formula 3
    1,878
    Indianapolis
    Nick
    That's incredible.... and sad build quality, but hopefully the root cause of your issues.
    Thanks Ian for your time and sharing those wiring diagrams too. For many of us, they are more valuable than you could possibly realize
    Qavion and Ferrari55whoa like this.
  13. rcgalore
    rcgalore Karting
    Sep 8, 2014
    66
    San Juan, PR
    #Qavion thanks! Great help on diagrams.
    Qavion likes this.
  14. rcgalore
    rcgalore Karting
    Sep 8, 2014
    66
    San Juan, PR
    I will try to start car tomorrow . I will have a few helping hands. Let’s see….
    Ferrari55whoa likes this.
  15. tazandjan
    39,141
    Good sleuthing.
  16. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,651
    Argent/Brasil
    Guido
    This can happen. The female connectors on the fuse box are very tight!! You don't want the relays to fall out while driving. Did you check if those female connectors were just before the opening, like in this picture? You can correct them if necessary with a small knife before tightening the screws.
    rcgalore and Ferrari55whoa like this.
