550m Air Bag Warning Light | FerrariChat
Discussion in '456/550/575' started by fifthwave, Jun 27, 2006.
  1. fifthwave
    fifthwave Rookie
    Mar 20, 2006
    15
    Surrey, England
    Hi I just had my 99 550M resprayed, and during this process the garage let the battery go completely flat. we then jump started the car, and since i have had numerous electrical issues: 1. the driver seat electric motor fuse keeps blowing, and 2. the AirBag warning light is now on full time...The manual tells me i need an ECU reset?? is this a major issue...
  2. darth550
    Jul 14, 2003
    61,150
    In front of you
    BCHC
    Airbag ECU is gone. $1300. Sorry.
  3. stephens
    stephens F1 Rookie
    Feb 13, 2004
    4,647
    Australia
    Stephen S
    I've got a "redundant" airbag ECU if you're interested. No more airbags in my car...
  4. nerd
    nerd F1 Rookie
    Oct 12, 2003
    2,535
    Coronado, CA
    RSK
    Airbag warning lights may indicate MANY different malfunctions one being the ECU.
  5. rmfurzeland
    rmfurzeland Formula Junior
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    Good news , I dont think the airbag ECU is gone. This ECU does not have a permanent memory or backup battery so when the main battery is out for a long time the ECU goes into default mode=show warnig light. Only the Ferrari dealer can reset this proprietary code.
    Ferrari of Houston reset mine for $100.
    Good luck,
    Ron
  6. Frari
    Frari Formula 3
    Nov 5, 2003
    1,194
    brisbane australia
    tony
    $100.00 for a 5 minute job, what a rip off. I have had the odd warning light come on from time to time and the ferrari dealer I go to will reset for nothing as a service, takes but a few minutes.
  7. stephens
    stephens F1 Rookie
    Feb 13, 2004
    4,647
    Australia
    Stephen S
    Same here, $100 is better than $1300, but is a total rip for plugging in SD2 and clearing the error code, which is literally a 5 minute job.
  8. fifthwave
    fifthwave Rookie
    Mar 20, 2006
    15
    Surrey, England
    Thanks for the advice - i will go down to our local "ferrari" expert and see if he has the SD2, if not it's main dealer time.
  9. fifthwave
    fifthwave Rookie
    Mar 20, 2006
    15
    Surrey, England
    Thanks for the offer - i will keep that in mind, should the ECU need replacing.
  10. darth550
    Jul 14, 2003
    61,150
    In front of you
    BCHC
    They tried to do mine twice for free. FWIW, I have a friend who has the software on his TREO. He uses it to shut off check engine lights for his friends with test pipes.
  11. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    But FoH did give me free coffee and a chance to read their Cavallino mags!
    Anyway the solution is clear you just need to reset the airbag ECU status if you do any long jobs on the 550 with the battery disconnected.
    Either that or you hook up a temporary supply to the ECU.
    By the way,the quiz for today is where is the ECU located? Since it took me some time to find it, I throw it out as a challenge to the rest of you for giving me a hard time over the $100.
    Regards,
    Ron
  12. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    It's obviously right behind the air bag, and I don't own a 550!
    Get rid of the air bags!
    Save you life!
  13. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    Wrong, sorry, not behind the airbag,
    Anybody else want to try?
    Ron
  14. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    I am kidding!
  15. stephens
    stephens F1 Rookie
    Feb 13, 2004
    4,647
    Australia
    Stephen S
    Which ECU are you talking about, there are close to 10 of them in the car?
  16. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    Dear Stephen,
    We were talking about the location of the airbag ECU,
    Taraaa....its on the top of the transmission tunnel underneath the carpet.
    Most drivers probably rest their elbows on it without even knowing its there underneath!
    Anyway if you ever have to replace the airbags, you also have to replace the ECU and then get it reset by the dealer.
    Regards,
    Ron
  17. MARANELLO328
    MARANELLO328 Karting
    Dec 2, 2005
    210
    Oean City, Maryland
    Dorsey
    Algar Ferrari told me if you unhook the battery for any reason to hook it back up and start the car without touching anything including the gas peddal and let it idle for 15 minutes and the ECU will reset. It's worth a try.
  18. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    They mean the engine igniton/injection ECUs (one per side) which have default settings for startup. The above discussion is for the separate ECU for the airbag and its default startup condition is "failed" for safety reasons (or is it to make the dealer rich?).
    Regards,
    Ron
  19. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    I forgot to add, the airbag ECU does hold its memory for some time, not sure how long, presumably weeks, since its has a bank of capacitors inside that can hold a charge.
    Regards,
    Ron
  20. BlueMaranello
    BlueMaranello Karting
    May 29, 2004
    70
    London, England
    Steve
    Whilst this has little to do with air bags it is closely related. My '98 550 suffered a suspension problem and initially a Ferrari main dealer told me that it needed new suspension units and controls. I took it to a non main dealer specialist who spent a lot of time investigating the problem and eventually established that the ECU wasn't talking to the units. They reprogrammed the ECU for relatively little cost and it now works fine. Ferrari said that at some point in the car's past it must have had the battery disconnected or flat for a year or so for the ECU to have lost it's memory.
    Having read the above accounts, the puzzling thing is, if the car was disconnected for that long why didn't all the ECUs lose their memory?
    Steve
  21. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    Most likely the main engine ECUs have their programs and default parmeters stored in permanent computer memory, i.e. memory which does not need electrical energy to maintain the storage. Just like the bootup memory on your PC.
    The smaller ECUs for the suspension and airbag on the other hand probably use the cheaper type of memory that requires a small power source. When the main battery is disconnected - the stored energy in the power supply capacitors will last for a few weeks but not forever.
    I am curious about your suspension problem, what symptoms of malfunction did you have? Suspension warning light and anything else?
    Regards,
    Ron
    PS for background reading on memory types see
    http://www.answers.com/topic/non-volatile-memory
  22. BlueMaranello
    May 29, 2004
    70
    London, England
    Steve
    Ron,
    I actually did a post on the suspension problem on 22nd Sept 2005 so I won't repeat but would add that there were no warning lights at all - the car didn't know anything was wrong, if you know what I mean.
    Actually, when I first got the car I posted on the FOC owners club about what I thought was oversteer and was told that this was not possible unless I drove like a complete hooligan. Thinking it must be the way 550s were I carried on with it as it was for nearly two years.
    Steve
  23. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    Dear Steve,
    I found and read your post. So the only way to know is from experience of how it should handle or a full system checkout . Since my battery was disconnected for a long time, I guess I will never know for sure if the rear units are responding correctly.
    Anyway, feels fine and tightens up nicely in Sports mode and with ASR off.
    Regards,
    Ron
  24. BlueMaranello
    May 29, 2004
    70
    London, England
    Steve
    Dear Ron,
    Good news I think on the basis of what you say. My car never felt any different between sports and normal mode before I had the work done, I guess I just thought sport mode made no difference - I was wrong.
    You should be OK
    Regards
    Steve
  25. garysp7
    garysp7 Formula Junior
    Mar 28, 2004
    436
    Florida
    Gary
    Hey Darth:
    You mentioned you had a friend who has the SD2 software on his Palm Treo?
    Do you know where someone might obtain a copy of the software? How do you hook up a Palm Treo to the 550? What type of cable and connection do you need and where is it hooked up to?
    I have been lucky in that I have not had a check engine light for about three thousand miles, after resetting it about 8 times. Nothing needed fixing but now it seems to be alright. I think for owning the cdar long term, maybe having the sd2 software and a palm treo anf cable in the glove box might be a smart idea.
    Any thoughts?
    Gary
