550M NO START | FerrariChat
550M NO START
Discussion in 'Technical Q&A' started by kdross, Apr 15, 2021.
  1. kdross
    kdross Formula Junior
    887
    NJ
    Ken
    NO IGN.,FUEL PRESSURE OR INGECTOR PLUS CHECK OB2 CONEXTOR AND READS NO CODES , WILL NOT LINK UP TO ECMS. DROP FUSE BOX AND CHECK ALL FUSES, GOOD. LIGHTLY HIT FUSE BOX AND CAR STARTED. BAD FUSE BOX
    Qavion likes this.
  2. kdross
    887
    NJ
    Ken
  3. Qavion
    Qavion F1 World Champ
    13,919
    Ian Riddell
    Did you punish it? :D
    Good tip.
    I thought you may have disturbed a relay by doing this, but I can't think of any which would cause this behaviour. No comms probably means you're either not getting battery or ignition power to the Motronic ECUs. Battery power goes through fuses, not relays. Ignition power comes straight from the key.
    If it happens again, check for live battery power on fuses 8 and 9. Or live battery power at plug G (pin 9 red/blue wire) and pin J (pin 5, red/blue wire).
    spaghetti_jet likes this.
  4. kdross
    887
    NJ
    Ken
  5. kdross
    887
    NJ
    Ken
    THANKS FOR REPLY , WHEN NO START FOUND ALSO OB2 READER DOSENT WORK AND THEN WHEN IT LIGHTS UP IT POST P0600 CODE.DO YOU HAVE WIRE DIAGRAM SO I CAN CHECK POWER AT ECUS. POWER AT ALL FUSES BUT DONT KNOW IF AT PIN ECU. THIS CAR HAD ALARM BY-PASS BY ECU SPECIALIZED, SEEMS TO BE WORKING. THE CD I HAVE SPECK OF POWER SUPPLY RELAY?? MORE THAN WILLING TO PAY FOR INFORMATION 1-856 547 6522 STAN
  6. fatbillybob
    Aug 10, 2002
    28,638
    socal
    car running now?
    Qavion likes this.
  7. Qavion
    13,919
    Ian Riddell
    Do you have a workshop manual reference? The ECU does control relays, but only after it has been supplied with battery and ignition key power.
    The workshop manual should have wiring diagrams, but they have lots of errors. They misidentify the engine banks and mislabel the pins on the ECU. My diagrams may be easier to follow.
    Right engine bank
    https://www.dropbox.com/t/VptLUbkk7VI1HxJx
    Left engine bank
    https://www.dropbox.com/t/qP3bUJo1pB24MTzF
    The other side of the engine/dashboard plugs
    https://www.dropbox.com/t/Fzoff2HDTdiLDfq9
    Immobiliser and some OBD2 wiring
    https://www.dropbox.com/t/68mGUZkcHEF3tQIe
    The links expire in 6 days
    The ECU needs key power to be able to send data to the OBD2 port. I believe the OBD port is powered by the cigarette lighter fuse (no relays, live battery power). I think you already understand that the immobiliser needs to be deactivated on unmodified cars for the ECU to be able to communicate with the OBD2 port.
    Sorry, I only offer free, unqualified advice. I'm sure there are a few Ferrari specialists in NJ.
