328 - O2 sensor removal | FerrariChat
Discussion in '308/328' started by msouza, Apr 15, 2005.
  1. msouza
    msouza Formula Junior
    Mar 14, 2005
    292
    Tennessee
    Milton Souza
    I need help from the experts. How do I remove the O2 sensor? What do I need to disassemble to get to it? Please help...
    Thanks.
    Milton
  2. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,632
    E ' ' '/ F
    Enzo Gorlomi
    Just went through this. This is from memory, and the car's not here, so forgive any errors.
    Jack up the car, put it on jack stands
    Get underneath and remove the rear undertray -- about 8 10mm bolts
    The O2 sensor is the big thing plugged into the top side of the exhaust pipe at the inlet of the cat. It's on the passenger side. Just unscrew it.
    The wires (on mine) had some zip ties on them.
    Up top, take off the air box.
    At the rear corner of the engine compartment, there will be a connector with a green wire and a two-wire connector. That's the upper end of the O2 sensor wire. Uplug, and drop through to the bottom.
    You can buy a replacement sensor at O Reilly auto parts, kinda pricey.
    See this thread for an illustration
  3. msouza
    Mar 14, 2005
    292
    Tennessee
    Milton Souza
    Tillman,
    Thanks a bunch for the instructions, I'll get to it this afternoon. I'll be taking pictures of the procedure, and will write detailed instructions. I anyone is interested, let me know, and I'll post it or email direct to you.
    Thanks.
    Milton
  4. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    I'd like to see, as I'll be doing this next week sometime.....post or PM me your pics/instructions. I have an 84 QV, you'd be surprised how much is the same with your 328.
  5. PMDDMD
    PMDDMD Formula Junior
    Apr 1, 2004
    362
    Please post pics and instructions when done...I'd appreciate the info!
  6. msouza
    Mar 14, 2005
    292
    Tennessee
    Milton Souza
    #6 msouza, Apr 17, 2005
    Tillman's instructions were perfect. So I am not editing them. I would like to add another O2 source, the 1987 328 uses Bosch #13957, it can be found at Checker Auto - $144.99.
    Here are the photos of the entire procedure.
  7. Tricycle
    Tricycle Formula Junior
    Dec 21, 2004
    636
    LA Cnty 4,083sqmiles
    Reviving an old thread
    Amazon has them for only $55.08 in limited quantity
  8. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,931
    Mike 996
    I paid $63.99 for the Bosch O2 sensor for my '89 328 at Advance Auto parts locally (in Annapolis)
