570s door problem | FerrariChat
570s door problem
Discussion in 'McLarenChat.com' started by buckwheat, Dec 22, 2024.
  1. buckwheat
    buckwheat Rookie
    Dec 13, 2017
    5
    M. Stephen Martin
    Newbie to 570s here.
    The passenger door won’t open using the interior or exterior switches. The pull strap will unlatch the door.
    The fuse looks ok. The driver side door works fine. The door locks and windows work well on both doors, but the passenger window stays down in the default open position. The warning message states that the passenger door switches are inoperable.
    A micro switch problem? How to remove the interior door panel? What to do next? Any suggestion would be most welcome. Thanks.
  2. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,463
    On the Limit
    Dino
    Most of these guys run to the dealer. The fact that you want to take the door card apart is great. It pretty straight forward. It's in layers. You start with the speaker box. If I remember correctly, they are pressed in and held by clips. Now, just work through the layers. If there aren't clips, there are screws and bolts. There's a little air bag plastic logo towards the rear of the door. It pries off and you'll see a bolt. If you've done this stuff before, you'll figure it out. Don't forget to disconnect the battery or you'll trip an airbag light. If you do that and don't have an MDS, it will yell at you until you visit the dealer! Good luck.
    If you are in AZ and wants some help, you are welcome to come by. I have an MDS too!
  3. buckwheat
    buckwheat Rookie
    Dec 13, 2017
    5
    M. Stephen Martin
    Thx for your help! I removed the speaker grill first using a plastic pry bar between two business cards. The clips are very strong! I cleaned the elec connections that I could access and sprayed contact cleaner. I discovered a 20 amp fuse under the dash labeled ‘ passenger door protection’ and r&r’ed it. Everything worked fine after reconnecting the battery so I’m not sure which activity actually fixed the problem. Possibly just rebooting the computer? Corrosion on the contacts? Thx also for your MDS offer, but I live in Oregon, where our damp climate may be the cause of this problem..
