575 block in all its glory | Page 2 | FerrariChat
Discussion in '456/550/575' started by PAUL500, Oct 14, 2017.
  1. tazandjan
    38,042
    Let me know when you need help reading parts catalogs so you do not have to lie to us any more.
    wireless likes this.
  2. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    Freshly bead blasted cam cover, not sure whether to take advantage of the extra bhp the silver of the SuperAmerica spec now gives them, or detune them back to 575 red!
  3. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    Just a little recap.
    Everything that turns and burns on the 612 is the same as the 575, so even if the block and heads of the 612 were cast from unobtanium instead, they are still dimensionally the same and it would not make an ounce of difference, logically the only place those extra horses can come from is via the updated engine management, which uses the same loom and sensors as the 575 and is not from a change in colour of the cam covers and plenums either!.
    Given that the minor tweeks Ferrari made to the SA resulted in no extra gee gees what so ever over and above the 612 spec it was clearly a waste of time and effort, a mistake I shall not be copying.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  4. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
  5. Cribbj
    Cribbj Formula 3
    Paul, there are some really attractive color combinations you can do in red, black, silver & plain or polished cast. I think the trick is to keep it simple, but elegant, and not do too much of one single color (other than the cast aluminum). Here's the direction I was going with my 550's intake system before I lost my mind completely, and decided on ITB's :) With this intake combo, I was going to play with either a red cam cover or a black one and see which one I liked better. If you know someone who's good with photo shop, you can do some amazing things in software first.
  6. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    Loving the black plenums John.
    So far my thinking is silver crackle for the inlet manifold as factory, crackle black side plenums, and matching red crackle top plenums and cam covers.
    I am planning to reverse the inlet so that the actuator is on the front of the engine and the prancing horse to the rear.
  7. Cribbj
    Cribbj Formula 3
    Paul, here are two other color schemes that I collected when I was considering options:
    PAUL500 likes this.
  8. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    greg246 and Bas like this.
  9. Cribbj
    Cribbj Formula 3
    Paul, I just noticed something interesting about your 575M block which is different than my 550 block. My block has dowels to keep the heads located, but yours apparently doesn't use them, or perhaps they remained in the heads when you pulled those? Two of the dowels (one on each bank) are solid, while two are hollow, and allow oil flow to the heads.
  10. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    I will have a check when I see it next and report back. It was a while ago that it was pulled apart and my memory is hazy.
  11. Cribbj
    Cribbj Formula 3
    Here's a pic of my block showing where the hollow dowels are (with the screwdrivers). And the solid dowels are also on the top of each bank, on the opposite corners. Actually, "hollow" is a misnomer because all 4 dowels are hollow; it's just that two of the holes they're pressed into are drilled to provide oil to the heads:
  12. Cribbj
    Cribbj Formula 3
    Paul, I keep remembering little "gotcha's" about my block disassembly experience, and I'm happy to share here:
    1. Be very careful when pulling studs, as many are Loctited in, and in the case of smaller ones (6mm) you'll twist them off before you realise it. So be sure to hit all the studs with a torch before using a stud pulling tool. Also, I would suggest only using the Snap-On type stud puller. If you intend to pull your head studs, you'll need a special collet for the tool, and others have had a helluva time getting it. I'll "loan" you mine if you need it, but I do want it back :)
    2. Have a look inside your block's coolant plenum (top of block) and see if you have any casting slag that needs removing. I had a huge chunk that was plainly blocking flow to the middle cylinders on the right bank. Interestingly, these were also the ones that exhibited the worst pitting from cavitation......
    3. I'm sure you'll be pulling your liners, and you need a clever little tool for this. Mine was made by the Simard Tool Company, and I would encourage you to contact Michael Simard to source one for your engine. Here's a couple of pics of it in action:
  13. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    Superb advice, thanks again, my dads handling that side of things so I will show him this thread. Appreciate the offer of the tool but I am in the UK! :)
  14. JimEakin
    JimEakin Formula Junior
    Jun 13, 2015
    988
    Mountain Living
    Jim
    SuperAmerica exhaust valve part number: 210558.
