575 FHP Shocks | Page 4 | FerrariChat
575 FHP Shocks
Discussion in '456/550/575' started by vandevanterSH, May 19, 2025.
  1. vandevanterSH
    vandevanterSH F1 Rookie
    3,380
    AR
    Stephen Van Devanter
    Are those a direct "drop-in" for the 575 or are additional modifications needed? Also, do those have a specific part/model number?
  2. Ferrari55whoa
    Ferrari55whoa F1 Rookie
    3,478
    Los Gatos, CA
    Eric
    #Sexy
    Chupacabra likes this.
  3. Chupacabra
    Chupacabra F1 Rookie
    3,584
    Behind a drum kit
    Mr. Chupacabra
  4. vandevanterSH
    3,380
    AR
    I was wondering about electrical connection for suspension warning but seems like they have an additional product for that.
    575M & Superamerica Suspension Error Delete
  5. Chupacabra
    3,584
    Behind a drum kit
    Mr. Chupacabra
    Mine came with that
  6. white out
    white out Formula 3
    Mar 3, 2010
    1,306
    The coilovers are direct drop in for both 550 & 575. The suspension error modules are plug and play but a separate option only available for 575M & Superamerica.
  7. Geoff_kg
    Geoff_kg Rookie
    Jun 23, 2019
    48
    Boston
    Geoffrey S.
    I’m assuming the MSC coilovers don’t retain the adjustable damper technology found in the OEM Sachs? Do people who’ve made the switch not miss that?
  8. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    14,141
    MO
    Omar
    They would not retain electric damping adjustment, no.
    vraa and Chupacabra like this.
  9. Chupacabra
    3,584
    Behind a drum kit
    Mr. Chupacabra
    I’m honestly not expecting to. The simpler the better, IMO.
    vraa likes this.
  10. vandevanterSH
    3,380
    AR
    "Do people who’ve made the switch not miss that?"
    I haven't made the switch, yet, but seems to me that after market coil-overs may be the way to go. One, original Sachs shocks are essentially no longer available, which is a major problem. Two, my reading on this site, seems to indicate that 575s, especially early production without FHP, have very soft suspension and after marker coil-overs may be the most practical and least expensive way to correct this problem. I always run my FHP suspension in sport mode, so not having the ability to change the setting wouldn't be an issue.
  11. Geoff_kg
    Geoff_kg Rookie
    Jun 23, 2019
    48
    Boston
    Geoffrey S.
    I heard that late MY 575s had a system where outer shocks stiffened as you went into corners, and generally people found this to be a very enjoyable sensation. I’ve never driven a 575 with that but supposing I did have it, I would be reluctant to get rid of it
  12. tazandjan
    39,321
    Affirmative, after AN 52556 (late Nov 2003) there is a steering position sensor that provides lead into turn info to the shock ECU.
    vraa likes this.
  13. Chupacabra
    3,584
    Behind a drum kit
    Mr. Chupacabra
    Oh, they’re available…if you feel like dropping nicely-loaded, brand new SUV $ on all four corners. :eek:
    white out likes this.
  14. Chupacabra
    3,584
    Behind a drum kit
    Mr. Chupacabra
    FOW are putting the MSCs on today, I ended up sending them up there because the ASR controller took an eternity to arrive from Italy.
    They asked “how do you want them set?” And I was like, “well…let’s turn ‘em all the way up!”
    Im expecting solid results from these coupled with the MSW bar.
  15. wrgray68
    wrgray68 Karting
    201
    Kansas
    Walker Gray
    That seems insanely high. I had my front pair replaced last year and the total was $8,992. The price for the pair of shocks was $6,310. 4 hours of labor. They also replaced the ball joints.
  16. wrgray68
    wrgray68 Karting
    201
    Kansas
    Walker Gray
    If there is a good independent shop in your area I'd get a quote from them. My guys didn't have any trouble finding OEM shocks, albeit expensive.
  17. Auraraptor
    Sep 25, 2002
    14,141
    MO
    Omar
    That is closer to independent shop costs. From a dealer at MSRP its quite a bit more...
  18. TwoMinds
    TwoMinds Karting
    110
    London
    Colin C
    If anyone is ever in London I'd be happy to get you into my 575, if timing works, to compare. AN 56713 with FHP so possibly as firm as OEM got aside from HGTC.
    Geoff_kg and Auraraptor like this.
  19. tazandjan
    39,321
    Affirmative, she has the HGTC shocks and mounts, too, and stiffer than HGTC rear anti-roll bar. Since she has the FHP steering ECU and HGTC uses the standard steering ECU, she likely feels stiffer. Only missing the waterproof F1 sensor and cable, unless the clutch has been replaced.
  20. TwoMinds
    TwoMinds Karting
    110
    London
    Colin C
    With the terrible condition of many UK roads I do sometimes wish that the bumpy road suspension setting was available for these.
  21. tazandjan
    39,321
    It is, you just have to turn off the sport switch.
  22. TwoMinds
    TwoMinds Karting
    110
    London
    Colin C
    I don't find that makes any discernable difference to ride quality.
  23. Passion_of_V12
    Passion_of_V12 Karting
    Feb 15, 2025
    60
    Denmark (Europe)
    J.A,
    I feel the same way. I can’t sense the sport button making a difference in power or ride quality, neither in shifting speed. It does
    make a huge difference in down shifting, as it gives throttle blips between downshifts - and i love that. Even it’s not good for the clutch wear. But it’s about enjoying the drive. So.
  24. tazandjan
    39,321
    In actual fact synchronizing the throttle on down shifts lessens clutch and gearbox wear, cutting down on the clutch and synchronizer rings having to do the synchronizing of the clutch and gearbox on downshifts as well as upshifts. Try downshifting or upshifting on a dog-clutch or straight gear transmission to demonstrate it to yourself. Having driven quite a few heavy trucks with those transmissions myself, I can guarantee it.
    Chupacabra and Passion_of_V12 like this.
  25. Passion_of_V12
    Feb 15, 2025
    60
    Denmark (Europe)
    J.A,
    Good to know. Makes perfect sense. The boring way would be to put it in neutral when coming to a red light. But I love shifting down the gears. The sound is lovely.
