575 on the move | Page 14 | FerrariChat
575 on the move
Discussion in '456/550/575' started by Clyde Romero, Oct 4, 2019.
  1. Clyde Romero
    Clyde Romero Formula Junior
    Sep 6, 2019
    760
    Atlanta Georgia
    Clarence Romero
    Brian did the oil filter catch much of the metal from the failure?
  2. Rifledriver
    37,106
    I never cut it open. What I did find was big pieces. I doubt anything went through the strainers on the oil pickups.
  3. Rifledriver
    37,106
    There is no question a good warm up is important.
  4. Rifledriver
    37,106
    I should explain more fully. The bearing did not "wear out" in an accelerated fashion creating fine metal debris. It appeared that the ball cage failed at is welds or rivets holding the balls spaced apart. The cage was broken into pieces and laying in the bottom. When that happens the side load on the bearing pushes the now free to move around balls to one side. The races are now far enough apart on the one side the balls are free to just fall out, which they did. It all collected in the bottom.
  5. Mirek
    Mirek Formula 3
    1,494
    Los Angeles, CA
    Mirek
  6. Rifledriver
    37,106
    I have never seen a lower cam drive bearing even look bad before it was making so much noise we did something about it.
  7. Mirek
    Mirek Formula 3
    1,494
    Los Angeles, CA
    Mirek
  8. Clyde Romero
    Sep 6, 2019
    760
    Atlanta Georgia
    Clarence Romero
    I recently has the suspension system alert light on.
    its the one with the triangles under the wheels
    anyway what I found out is that to get rid of that light
    find a level parking area
    turn the car off
    wait about a minute then turn it back on
    light goes away
    remember these cars are old now and are getting funny with electrics
    f355spider likes this.
  9. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,982
    MO
    Omar
    Mine does that whenever the battery is getting borderline
    Ferrari55whoa likes this.
  10. Mirek
    Mirek Formula 3
    1,494
    Los Angeles, CA
    Mirek
    I found that that light comes on if the car is started a few times without moving the car much.
  11. Auraraptor
    Sep 25, 2002
    13,982
    MO
    Omar
    My 456m did when it sat too long and and accumulators needed replacement. I’ll see if still an issue now I replaced the accumulators….
  12. Clyde Romero
    Sep 6, 2019
    760
    Atlanta Georgia
    Clarence Romero
    my 2003 575 just had a catastrophic engine failure, the driver's side belt slipped. Which caused major engine damage.
    I am going to part the vehicle out. It had 75K miles on it.
    In the market for another one.
    Stuff like this happened it was the timing drive that failed and caused the issue.
    Belts were 2 years old.
    It is what it is.
  13. Clyde Romero
    Sep 6, 2019
    760
    Atlanta Georgia
    Clarence Romero
    Mine just failed and cause the belt to slip and cause a catastrophic failure of the engine.
    Car had 75 k on it
  14. Rifledriver
    37,106
    #339 Rifledriver, Sep 29, 2024
    Do you know what caused it? Many reasons a belt can slip or break.
    Sorry for your experience.
  15. Clyde Romero
    Sep 6, 2019
    760
    Atlanta Georgia
    Clarence Romero
    Belt did not break
    it was the drive cam on the lower part of the engine that failed
  16. Steen Jensen
    Steen Jensen Formula Junior
    Mar 29, 2009
    296
    Sorry for your bad luck Clyde. Were there any unusual noises or clues before the failure?
  17. Clyde Romero
    Sep 6, 2019
    760
    Atlanta Georgia
    Clarence Romero
    No I had just done a 240 mile run
    Parked the car and the issues started with backfiring
    I was lucky to get it to the hotel
    Had it towed from there home
  18. vandevanterSH
    vandevanterSH F1 Rookie
    3,191
    AR
    Stephen Van Devanter
    Cam drive bearings have been the "weakest" part of my '02 575. First failure at 2 1/2 years and 10k miles. 3(?) more replacements with belt changes since then. I'm very paranoid about changes in engine noise...about 10 years ago, the wife mentioned that something sounded different, bad bearing. With next belt change, maybe request replace with Hill Engineering bearings?
    ifeelfree0 likes this.
  19. Clyde Romero
    Sep 6, 2019
    760
    Atlanta Georgia
    Clarence Romero
    I had Hill tension bearings on the drive belts
    Not familiar with the cam drive bearing replacement parts
    I had 75 k on my car
    Was maintained like the airplanes I flew
    I was told this is a weak spot on the 550/575 engines
    You can check for play on the drive shaft when doing a belt change but who knows ?
    Every engine has its weak spots
  20. Steen Jensen
    Mar 29, 2009
    296
    I guess I better get the stethescope out. I hate to hear of failures like this. Worrisome...
  21. Ferrari55whoa
    Ferrari55whoa F1 Rookie
    3,385
    Los Gatos, CA
    Eric
    @Clyde Romero this really stinks, I’ve enjoyed this thread and will look forward to its extension as you find a replacement.
    No affiliation but our friend @stevepaa has a very well attended to 575 that he has owned for a long time that he is ready to sell.
    Clyde Romero likes this.
  22. tazandjan
    39,181
    Clyde- Sorry to hear. I know she was well maintained.
  23. lopena
    lopena Formula Junior
    759
    My 2002 575M (the first U.S. spec 575 made) also suffered failure of the cam drive bearings at 32,000 miles (while in possession of a previous owner). Luckily, a mechanic noticed an “abnormal noise” coming from the front of the engine and caught it in time, thereby preventing catastrophic damage. Nevertheless, the engine had to come out for repairs by the dealer at a cost of $6,200.
    Alan
    N.J.
  24. Rifledriver
    37,106
    Must have been more than cam drive bearings. Those are easily done in the car.
  25. Clyde Romero
    Sep 6, 2019
    760
    Atlanta Georgia
    Clarence Romero
    yes I am in contact with Steve on his car
