575 | FerrariChat
575
Discussion in '456/550/575' started by rodnro, May 24, 2019.
  1. rodnro
    rodnro Rookie
    Oct 8, 2015
    18
    Can any one help with pinouts (four plugs) on a 575 dashboard binnacle,thanks.
  2. stevepaa
    stevepaa Formula Junior Owner Silver Subscribed
    Apr 5, 2006
    771
    san jose, ca
    steve
    Any pics?
  3. tazandjan
    tazandjan Three Time F1 World Champ Lifetime Rossa Owner
    39,195
    Probably the only people with that kind of info are at FAI. They may not give it to you, but they can definitely fix your instrument panel.
    Franchorchamps of America, Inc.
    935 Sunset Dr Suite A
    Costa Mesa, CA 92627
    (949) 631-6373
    Rod Drew
    [email protected]
    Will White
    http://www.ferrarioc.com/
  4. rodnro
    rodnro Rookie
    Oct 8, 2015
    18
  5. rodnro
    rodnro Rookie
    Oct 8, 2015
    18
    The fault was no backlight,with ignition the high voltage circuit is supplied with two voltages,one about 10volts the other is a PWM controlled from the two rocker buttons on the dash.There was no output from the micro to drive the PWM circuit so i just biased that circuit on from the 5 volt regulator.It just means there is no brightness control of the backlight.No big deal.
  6. tazandjan
    39,195
    One way to do it as long as it does not blind you at night.
  7. rodnro
    rodnro Rookie
    Oct 8, 2015
    18
    No,the customer is very happy.
