575M AC help | FerrariChat
575M AC help
Discussion in '456/550/575' started by vandevanterSH, May 25, 2021.
  1. vandevanterSH
    vandevanterSH F1 Rookie
    3,193
    AR
    Stephen Van Devanter
    575 AC help:
    Recurring topic but nothing recent on search. 2002 575 no longer cooling. A/C went out on the way to Dallas to have routine yearly fluids, etc. Service tech says compressor pressure low despite recharge. Recommends new compressor and also replace expansion valve and A/C system refrigerant accumulator. No shock that the cost is insane.
    About 12 years ago, I was on road trip to San Francisco and my A/C compressor seized up in Winslow, AZ. Flat bed to Scottsdale for new compressor. I have that old compressor. I remember reading about company that rebuilds A/C compressor but couldn't find post. Bottom line, any recommendation for Ferrari A/C repair within 400 miles of Little Rock? Should I send my old compressor for rebuild and take that to be installed? Could a local "Foreign" car shop do the install. Any advice appreciated. (Best I can tell, Ferrari inflates the cost of a Delphi/Harrison compressor x10+)
  2. Joel Delman
    Joel Delman Karting
    May 4, 2021
    152
    Los Angeles
    Joel Delman
    Just out of curiosity, about what price were you quoted for the new compressor etc.?
  3. vandevanterSH
    3,193
    AR
    $16,750.
  4. Joel Delman
    Joel Delman Karting
    May 4, 2021
    152
    Los Angeles
    Joel Delman
    Ouch... Please keep us updated on the solution you go with
  5. Qavion
    Qavion F1 World Champ
    14,337
    Ian Riddell
    Sounds ridiculous. Have you checked the parts manuals for component locations/accessibility?
    The expansion valve is shown on the side of the evaporator unit in the passenger footwell. Item 22
    https://www.eurospares.co.uk/parts/ferrari/575m-maranello/cooling-heating/evaporator-unit-and-controls-36655
    Worst case scenario is having to remove the entire dash, hence the high cost, but you may get access by removing centre console/tunnel panels and, if possible, the glovebox. Expansion valve is U$110 at Eurospares. Check the forum for previous posts on disassembly (550, 456M, etc).
    https://www.ferrarichat.com/forum/threads/550-service-say-it-aint-so.631646/#post-147546477
    @AVIMAX (Ryan) has some excellent photos on evaporator components.
    https://www.ferrarichat.com/forum/posts/147789308/
    I'm not sure what they mean by refrigerant accumulator. Do they mean the receiver/dryer/filter? Item 8
    https://www.eurospares.co.uk/parts/ferrari/575m-maranello/cooling-heating/air-conditioning-system-36654
    U$83
    This part is typically not too hard to access.
    The compressor is the most expensive component at Ferrari parts dealers. Item 20.
    https://www.eurospares.co.uk/parts/ferrari/575m-maranello/electrical-ignition/alternator-starting-motor-and-ac-compressor-36653
    But I'm sure there are plenty of companies in the USA which will be able to repair/recondition these compressors.
    $4000 in OEM parts/materials, $12,750 in labour :rolleyes:
  6. vandevanterSH
    3,193
    AR
    "Have you checked the parts manuals "
    Yes.....Ferrari price ~$6500....other prices ~$4300...and generic price <$600
    This is the label from the factory installed compressor:
  7. vandevanterSH
    3,193
    AR
    My initial thought is to send my original compressor for a professional rebuild then take the part to a reliable shop for install and see how it goes. The other parts mentioned by the dealer are relatively inexpensive and if replacement isn't a huge labor cost then OK but if it is a multi-hour labor charge then just replace the compressor, which is a bit of a PITA but straight forward.
  8. Ferris Bueller
    Ferris Bueller Formula 3
    Mar 23, 2004
    1,864
    New Jersey
    Dominic
    You say the tech said the system was low on pressure and you just had it recharged. You have a leak. The components are fine.
    Find the leak, repair it. Pull a vacuum and recharge.
  9. vandevanterSH
    3,193
    AR
    "Find the leak, repair it. "
    That was my first thought. I'm going to pick up the car Thursday and will try to get more information. When my compressor seized up, it was obvious that there was a major problem just from the noise.
  10. vandevanterSH
    3,193
    AR
    Anyone have experience with "Automotive Budget" rebuild services, located in Port Richey, FL?
  11. Rifledriver
    37,114
    Austin Rebuilders in Austin are very good, very reasonable and fast. I use them a lot.
  12. vandevanterSH
    3,193
    AR
    Thanks a $6,300! Just for future search information on the subject, I went to a local shop to see if they could source the same Delphi compressor...no luck. Another option maybe mondoautoricambi, the site is in Italian but they have the compressor listed for 915 euros.
    For me, sound like Austin Rebuilders is the best option.
    JSP likes this.
  13. vandevanterSH
    3,193
    AR
    " Rebuilders in Austin"
    Any recommendation for A/C installer for Maranello in Austin or Dallas?
  14. Rifledriver
    37,114
    Me in Austin or Boardwalk Ferrari in Dallas.
    And it is not Rebuilders in Austin. I said Austin Rebuilders.
    https://austinrebuildersinc.com/
  15. Ferris Bueller
    Mar 23, 2004
    1,864
    New Jersey
    Dominic
    Stephen
    You just had one of the best independent Ferrari mechanics reply to your post.
    Take advantage of this. Contact him and use him.
    dsd and Konadog06 like this.
  16. Boy Wonder
    Boy Wonder Karting
    May 23, 2014
    171
    Boulder, CO
    Fred Wolf
    OMG
    just open the windows'
  17. vandevanterSH
    3,193
    AR
    "just open the windows"
    Drove ~350 miles yesterday with the window open....it was only 88 degrees F, so was tolerable. When I grew up in the 40s, 50s, there was no home or car A/C and the family took multi-week road trips in July or Aug. I'll just suck it up until I sort out getting it fixed.
  18. vandevanterSH
    3,193
    AR
    Progress report:
    With Brian's suggestion, just sent compressor to Austin Rebuilders, Inc. for evaluation for rebuild. One step at a time!
    dsd and Qavion like this.
  19. Dal308
    Dal308 Karting
    132
    Coppell, TX
    Dude
  20. vandevanterSH
    3,193
    AR
    Thanks for the info....
    Pick up the car from dealer yesterday....asked about leaks, etc. Service rep. said no leak in system but no pressure on "either side" of system..ergo bad compressor.
  21. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    I replaced my AC kompressor and paid 800 euro for it at the official Ferrari workshop in Modena Italy. Don’t get screwed!
  22. vandevanterSH
    3,193
    AR
    Interval follow up:
    Austin Rebuilders called this PM. Received the compressor today, ran it on the bench and it seems to be OK with pressure and clutch. Strange situation, this is the compressor that was removed about 10-12 years ago when it "locked up'' and caused an ungodly screeching/howl from the engine, (belt slipping in locked pulley?) It was replaced in Scottsdale AZ and has been sitting in storage since then. I told them to tear it down for complete inspection and replace anything suspicious. (I am impressed so far with Austin Rebuilders customer service....) Just another odd F-Car situation!!
  23. vandevanterSH
    3,193
    AR
    Follow up...Austin Rebuilders called this AM, rebuild complete and shipping out today. Cost ~$325 + shipping.
    SteveVT, Joel Delman and Qavion like this.
  24. Rifledriver
    37,114
    That can happen if it is overcharged or if an expansion valve gets plugged. Does not always mean the compressor is bad.
    Qavion likes this.
  25. vandevanterSH
    3,193
    AR
    Follow up on 575 A/C issue. Drove to Dallas Sunday with the rebuilt compressor for install at Norwood Auto Italia Monday. (Fortunately left home early and heat remained tolerable until last hour or so, when I needed the towel that I brought to mop sweat. :>) ) They retested the existing system before starting installation. Initially about a # low on refrigerant, refilled and high and low sides of compressor were within spec. Inspected for leaks, then vacuum tested system. Removed belt covers and inspected belts, compressor, etc. Refilled and rechecked pressures which were OK. On max cool, vent air was about 48 degrees. Not sure what the problem was/Is but decided to leaves current system in place and see how things go. During the 350 mile drive home, the A/C was excellent.
    First time I have been to Norwood. I was impressed with the fact that they spent 3+ hours trying to identify and solve a problem rather than replacing parts and at a very reasonable cost.
    Qavion likes this.
