Anyone had experience installing ceramic brakes on a '04 575 ? What was your experience after the install...
When you decide to do it let me know. I can supply you with the Novitec system. Novitec Composite Ceramic Brake System (NCCB), includes: two 8-piston brake calipers and 380mm ceramic discs in the front and two 4-piston brake calipers and 380mm ceramic discs in the rear; 2 brake cooling ducts, steel-flex brake lines; brake pads. Weight savings compared to OE: 45lbs. Requires 19" Novitec wheels for clearance. Red, silver or black calipers* $32,229
